Arduino - Multiple Servo Control With Arduino
32,616
184
14
About: Arduino, Raspberry Pi, esp8266, Tutorials, Projects
In this tutorial, we will learn how to use multi-servo with Arduino. We will control 4 servo motors with Arduino PWM outputs.
You can implement your robotic arm projects with reference to this tutorial. Of course we will use external battery / power when doing this. In the next tutorial, I'll show you how to use multiple servos with potentiometers.
Do not forget to subscribe. Thank you for your support.
Step 1: Hardware Required
- Arduino Board
- Servo Motor x4
- Battery
- Wires and Breadboard
Step 2: Connections
- The external battery VCC / GND connect to the breadboard.
- The Arduino GND connect to the breadboard's GND input
- The servo connections we use in this project are as follows;
Orange Input -Signal Input
Red Input -Power Input (VCC)
Brown Input -Ground Input(GND)
- The Servo1 VCC and GND connect to the breadboard's VCC / GND inputs
- The Servo1 Signal connect to the Arduino Digital PWM 3
- The Servo2 VCC and GND connect to the breadboard's VCC / GND inputs
- The Servo2 Signal connect to the Arduino Digital PWM 5
- The Servo3 VCC and GND connect to the breadboard's VCC / GND inputs
- The Servo3 Signal connect to the Arduino Digital PWM 6
- The Servo4 VCC and GND connect to the breadboard's VCC / GND inputs
- The Servo4 Signal connect to the Arduino Digital PWM 9
The potentiometer
Two outer pins are power (VCC) and ground (GND)
Middle pin is signal pin
- Potentiometer's one outer pin connect to the breadboard VCC input
- Potentiometer's other outer pin connect to the breadboard GND input
- Potentiometer's middle pin connect to the Arduino Analog 1 input
Step 3: Code
I did not share the code because it is short and it varies according to the number of servos.
You can write code by watching the tutorial. This is a better way to learn.
I will continue to share long and complex codes.
    • Arduino Contest 2019
    • Classroom Science Contest
    14 Discussions
    PhilippeG1monusuthar2016
    Reply 3 months ago
    votre lien youtube porte sur la mesure de distance avec des ultra sons et des centaines de milliers de personnes connectent des servos à des cartes arduino, votre idée n'est donc pas originale, brevetable vous n'êtes pas le seul au monde à en avoir eu l'idée, on vient ici pour partager du savoir pas pour en revendiquer lapaternité
    congelata
    1 year ago
    Hi, this is awesome!
    Just a question:
    How can I have different degrees and delay for each servo?
    I'm new in this "arcuino's world"... please forgive my stupid question :)
    AthiamaanRcongelata
    Reply 1 year ago
    yes u can......only if u r about to add gyro to ur model
    kenwood120s
    1 year ago
    The way you word it, it implies servos have to be onPWM pins. They don't: any pin, even the analog inputs a0-a5 will drive servos with the servo library.
    kenwood120s
    1 year ago
    I'll bet those are 4.8-6V servos: why are you powering them from a 9V battery?
    techietech
    1 year ago
    kool video, I love it!!
    JoeMannix
    2 years ago
    I always wondered how to do this.
    Techno craft
    2 years ago
    Plz give the codes
    And the tutorial of writing any code
    Sparta53535@gmail.com
    jradzevi
    2 years ago
    Thats a 9V battery, correct?
    alsalmi616
    2 years ago
    Thank you very nice job
    CarlosF78
    2 years ago
    Thanks a lot!
