Arduino Nano CH340
237,653
82
58
About: Hello, My name is Samuel, I am a student. I love micro controllers like arduino, they are my favorite interest. I also do geocaching, a worldwide treasure hunt game. I hope you enjoy my instructables! Samuel
If you are like me and ordered a cheap arduino nano clone from a chinese website like aliexpress or banggood, chances are that they come with the cheaper CH340 USB to Serial chip. This is a cheap chip that manufacturers exploit to make the clone a lot cheaper. This can also be a downside. For me, being a mac user, I had a real hard time finding drivers etc for it. In the end I found some drivers, which were pretty good and I finally could get a blink sketch uploaded. I now want to share my experience for future buyers so you can get it working a lot faster. Enjoy!
Step 1: Drivers
Basically, let me put it this way. Buy from chinese site, get chinese drivers. I got my drivers from here. Once you have downloaded the file. Unzip the install file and start the install process. Once this is done, reboot your computer. ALTHOUGH WAIT. If you have mac and are running yosemite. You will need to follow the instructions in the next step. If you are not a yosemite user, please skip the next step and restart your computer.
Step 2: If You Have Yosemite
For the drivers to work for you, you will have to do this before you reboot your mac:
1. Open terminal
2. Write the following (just copy from here): sudo nvram boot-args="kext-dev-mode=1" Do not ess up here. It may ruin your computer if you write the wrong code.
3. Once you have pressed enter, terminal will prompt you for your user password. Insert this and press enter.
4. Once done, restart your computer.
Step 3: Testing
If everything is done correctly and there were no errors appearing. You should be able to restart your arduino IDE and see the port. For my mac it is usually like above in the picture but sometimes it changes. You will also notice that once in a while (maybe 1 time of 3) you will get errors when uploading but you do not have to care, the code will usually upload either way.
I hope this tutorial helped you and remember that the CH340 chip is a bit complicated and it may also be used in other cheap arduino board clones. Thanks for reading and once again, I hope it helped you.
Samuel
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
58 Discussions
Bagoongnas476
Reply 7 weeks ago
Probably the same drivers. I see they're labeled ch34x - so will cover 340 and 341, I assume. (You've probably got your answer by now - I'm just putting this here for posterity)
Bagoong
7 weeks ago
Just a quick comment re Linux installation - year is now 2019 and Arduino IE is version 1.8.8.
Tip 1: don't use apt get to install Arduino IDE on Ubuntu, Elementary or other Debian/Ubuntu distros. The repos do not have nice new versions of the IDE. Download instead from arduino.cc site and follow instructions. Simple.
Tip 2: do not forget to add the current user to the dialout group. 'sudo usermod -a -G dialout $USER'
Tip 3: In the IDE under tools make you may need to set your "Processor" to ATmega328P (Old Bootloader) . Depending on the generation of the CH340 and esp. if you get message "programmer is not responding".
Comment: Because of the situation with the repos in Tip 1, I did not even try to install the IDE from the openSuSe repos. I downloaded the IDE from arduino.cc and used that in my openSuSE machine.
So, I have Arduino Nano CH340x working on Mac OS (Mojave), Ubuntu 18.04, Elementary Linux (forget version) and openSuSE Leap 42.3 Malachite.
It was not at all necessary to install drivers or make them on the Linux machines - but I did install them for the Mac. Downloaded from the Chinese site. A bit of a challenge as I don't read Chinese - but the little cloud symbol with a down arrow kind of gave me a clue. Info on Github is really good too. https://github.com/adrianmihalko/ch340g-ch34g-ch34x-mac-os-x-driver
Also see http://www.wch.cn/download/CH341SER_MAC_ZIP.html
Good luck.
schaude
7 months ago
As a linux user (Ubuntu / Linux Mint 17) I had difficulties with the cheap Nano with the CH340G chip getting it to work properly - the upload of any code didn't work at all. Of course I had installed the Arduino IDE (apt-get install arduino) but was not able to program the Arduino nano. Then I found in a german web article that from time to time you have to reinstall the IDE after a system update of the kernel, so that the serial USB interface works again. I didn't do it but my Nano started to blink when connected to the USB port so I thought it couldn't be out of order and should work anyhow. After connecting it to USB in the /dev folder you should find a file called ttyUSB0 or ttyUSB1 or so. In my /dev folder I had found it. So I started again, setting the Arduino IDE platform tool menu "Tools" and "Board" to "Arduino Nano w/ATmega328" (in my case) and "Tools" "Serial port" to "/dev/ttyUSB1" (in my case). Now, the code from the "Blink" example in the IDE could be uploaded to the Nano board as it should be and the LED started to blink... it's magic!
Southerner
10 months ago
I went to
http://www.wch.cn/download/CH341SER_ZIP.html
for the driver download as you suggested but I see no download link for any of the files and I do not read or speak Chinese. Do you have links to the driver downloads that are not html pages?
JonathonT
11 months ago
This is super helpful!! Thanks for posting! Wouldn't have been able to get this working on my own without these drivers.
PaulH477
Question 1 year ago on Step 2
I ran this step without having Yosemite, then restarted. My Mac won’t turn on, the led on the charger won’t either. Anyone familiar with solutions ?
PaulH477
Upon restart my Mac remained off. I can’t seem to turn it on via the power button, and the charger LED remains off.
vicgig10
1 year ago
This is the MOST ANNOYING issue I have found using a Mac. I did the csrutil thing and just can´t make this thing work. Anyone having the same issue with a USB-C only MacBook Pro??
JesseS154
1 year ago
Oops you can't copy paste that you'll have to write it down...lol
JesseS154
1 year ago
Thanks! So helpful...
If your running Sierra or later get your driver here:
http://www.mblock.cc/docs/run-makeblock-ch340-ch34...
Driver installation complete...press restart ...hold ⌘-R during start up.
In recovery mode now, select Utilities -> Terminal and copy paste:
$ csrutil enable --without kext
Press enter, type:
$ reboot
Login and open Arduino IDE (appears to reinstall) -> Tools
Board: "Arduino Nano"
Port: "/dev/cu/wchusbserial1420"
Test it with Examples -> Blink.
This worked first try for me thanks to all of you.
Lolman4000
1 year ago
Thanks so much for this instructible!
LucM15
1 year ago
Thanks, works fine (Win7 -64)
leon-geyer
1 year ago
Ou ou. I missed the step 2, shame on me, just installed without "sudo nvram boot-args="kext-dev-mode=1" and now the screen freezes after starting the computer, Keyboard and trackpad non-reactive, not even a plugged one. How can I revert that? Argh. On Sierra with a MBP 5,1.
carlos66ba
3 years ago on Introduction
Yes, these CH340 may have drawbacks but they have a HUGE ADVANTAGE vis-a-vis the FTDI's: they are not bricked on Windoze. Be careful guys and girls, the FTDI chips get bricked with the new Windoze drivers.
stu.tgcarlos66ba
Reply 1 year ago
I can't get this working with Windows 10 - I run the install for the driver then Windows takes over and tries to load its own drivers - then I keep getting Code 31 in device manager on the nano
Hilleskog
2 years ago
Thank you! Works well!
FTWingnut
2 years ago
I am running Mac Sierra, and after following your instructions, installing the driver and running the boot command "csrutil enable --without kext" listed below, my Mac now kernel panics and reboots when plugging the Arduino Nano into the USB port. What do I do now? How do I uninstall the driver?
AnhT51FTWingnut
Reply 2 years ago
Use this link https://github.com/adrianmihalko/ch340g-ch34g-ch34x-mac-os-x-driver
