Arduino Nano: Temperature and Humidity DHT11/DHT21/DHT22 Sensor Module With Visuino
44,968
150
13
DTH11/DTH21/DTH22 and AM2301are very popular combined Temperature and Humidity Arduino sensors.
In this Instructable, I will show you, how easy it is to program Arduino to use them, with Visuino - an easy to use graphical development environment for Arduino.
Supplies:
Step 1: Components
  1. One Arduino compatible board (I use Arduino Nano, because I have one, but any other will be just fine)
  2. One DHT11 Sensor Module I got from this cheap 37 sensors set
  3. 3 Female-Female jumper wires
Step 2: Connect the Humidity/Thermometer Sensor to Arduino
  1. Connect Ground(Black wire), Power(Red wire), and Data(Gray wire) to the DHT11 Module (Picture 1 shows 2 different types of DHT11 sensor modules. As you can see the pins may differ, so connect carefully!)
  2. Connect the other end of the Ground wire(Black wire) to Ground pin of the Arduino board(Picture 2)
  3. Connect the other end of the Power wire(Red wire) to the 5V power pin of the Arduino board(Picture 2)
  4. Connect the other end of the Data wire(Gray wire) to Digital pin 2 of the Arduino board(Picture 3, and 4)
  5. Picture 5 shows where are the Ground, 5V Power, and Digital 2 pins of the Arduino Nano
Step 3: Start Visuino, and Select the Arduino Board Type
To start programming the Arduino, you will need to have the Arduino IDE installed from here: http://www.arduino.cc/ .
Please be aware that there are some critical bugs in Arduino IDE 1.6.6.
Make sure that you install 1.6.7 or higher, otherwise this Instructable will not work!
The Visuino: https://www.visuino.com also needs to be installed.
  1. Start Visuino as shown in the first picture
  2. Click on the "Tools" button on the Arduino component (Picture 1) in Visuino
  3. When the dialog appears, select Arduino Nano as shown in Picture 2
Step 4: In Visuino: Add and Connect DHT11, and Formatted Text Components
  1. Type "dht" in the Filter box of the Component Toolbox then select the "Humidity and Thermometer DHT11/21/22/AM2301" component (Picture 1), and drop it in the design area
  2. Connect the "Sensor" pin of the HumidityThermometer1 component to the "Digital" input pin of the "Digital[ 2 ]" channel of the Arduino component(Picture 2)
  3. Type "form" in the Filter box of the Component Toolbox then select the "Formatted Text" component (Picture 3), and drop it in the design area
  4. Connect the "Out" output pin of the FormattedText1 component to the "In" input pin of the Serial[ 0 ] channel of the Arduino component(Picture 4)
Step 5: In Visuino: Add and Connect Text Elements, and Specify Formatted Text
  1. Click on the "Tools" button of the FormattedText1 component (Picture 1)
  2. In the Elements editor, double click 2 times on the Analog Element to add 2 of them (Picture 2, and 3), then close the Elements editor
  3. Connect the "Temperature" output pin of the HumidityThermometer1 component to the "In" pin of the AnalogElement1 of the FormattedText1 component (Picture 4)
  4. Connect the "Humidity" output pin of the HumidityThermometer1 component to the "In" pin of the AnalogElement2 of the FormattedText1 component (Picture 5)
  5. Set the value of the Text property of the FormattedText1 component to "Temperature: %0 Humidity: %1" (Picture 6). The %0 will be replaced with the value from AnalogElement1, and %1 will be replaced with the value from AnalogElement2
Step 6: Generate, Compile, and Upload the Arduino Code
  1. In Visuino, Press F9 or click on the button shown on Picture 1 to generate the Arduino code, and open the Arduino IDE
  2. In the Arduino IDE, click on the Upload button, to compile and upload the code (Picture 2)
Step 7: And Play...
You can see the connected and running Humidity and Temperature sensor on Picture 1.
If you open Serial Terminal in the Arduino IDE or Visuino, you will see the Temperature and Humidity measured by the sensor (Picture 2)
On Picture 3 you can see the complete Visuinodiagram.
Congratulations! You have created a temperature and humidity measuring Arduino project in Visuino.
Also attached is the Visuino project, that I created for this Instructable. You can download and open it in Visuino: https://www.visuino.com
2 People Made This Project!
  • Fandom Contest
    Fandom Contest
  • Woodworking Contest
    Woodworking Contest
  • Classroom Science Contest
13 Discussions
ErvinP8
1 year ago
Sketch uses 9100 bytes (28%) of program storage space. Maximum is 32256 bytes.
Global variables use 399 bytes (19%) of dynamic memory, leaving 1649 bytes for local variables. Maximum is 2048 bytes.
_____________
So? can i get help on this please?
himanshu321
1 year ago
sir, how to use simple 16 pin 16 to 2 lcd display in same project.
sir pls upload the visuino diagram.
GeeksTipsDotCom
2 years ago
Well done! Although I have this senaor in my projects, i onestly recommend DS18B20 1 Wire because of the power consumption less than a uA and measurements delay under 1 second. But no humidity do...
https://plus.google.com/107944587749396190662/posts/5oo987tnB54
BoianMcarlsandra2005
Reply 2 years ago
The DHT component in Visuino has property that you can set to have in F. You can also use the "Celsius To Fahrenheit" component in Visuino to get both temperatures at the same time ;-)
BoianMrabeh_b
Reply 3 years ago
Yes, I also did yesterday a version with 2 ESP8266 connected over WiFi . Will see to make Instructabe on it as well :-)
sel303
3 years ago
Very easy instructions. Visuino made this super easy. Thanks!
XTL
3 years ago
This is an advert for a 20USD product. I don't mind really but IMHO you should say so.
BoianMXTL
Reply 3 years ago
Actually this is a tutorial for a $10 product ;-) . Very similar to very much any other Arduino, LinkIt ONE, etc. Instructable. The boards are also products, and cost similar amounts. This simply teaches people how to use the product, as I got flooded with requests for tutorials, and finally got some time to prepare them.
