Arduino Nano USB Not Recognizing (Fix).
62,989
83
28
Supplies:
Step 1: Arduino Nano Clones
Unfortunately an original Arduino Nano could cost you more plus shipping so it makes sense to search for an alternative source. There are also some chinese clones that are around five times cheaper, even with worldwide shipping.
But wait! There’s always a reason why a clone of something is cheaper than the original product. In this case there can be two pitfalls you need to know about.
Step 2: Original FTDI for Data Communication
Sometimes the FTDI chip which makes the USB communication possible is a counterfeit. This could cause problems when you install the official FTDI drivers and they just refuse to work.Usually there is no bootloader on the microcontroller. You need to upload it yourself and that means you need to have an appropriate programmer on hand.
Step 3: The Bad Part About Cheap Chinese Clones
So what makes this clone cheaper than the others? Well, most probably two things:
1.The headers are not installed.
2.It uses a different chip (CH340G) for serial-USB communication than the others.
The different serial chip on the other hand was something I was a little bit worried about but I’ve found my fears to be baseless. When I connected the board to the computer with a miniUSB cable it was instantly recognised by Windows as a virtual serial port.
Step 4: USB Not Recognizing
Step 5: Download Driver for CH340/CH341
The chipset used for USB-to-serial is CH340/CH341, drivers for which can be downloaded here.
http://www.wch.cn/download/CH341SER_EXE.html
Step 6:
Step 7: Unzip & Install the Driver
Step 8:
DONE!!
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    28 Discussions
    wadael
    6 days ago
    I had lots of trouble making my clones work.
    Most issue solving tuts are for windows, I am on linux
    To sum up : the cable was the culprit then I use : Arduino Duamilanove ou Diecimila , Atmega 328P, AVR ISP
    https://wadael.wordpress.com/2019/05/19/solved-che...
    HIH
    Jerome
    IvanM273
    21 days ago
    Wow. Thank you! This guide is very helpful.
    НовицкийН
    1 year ago
    Okay, but what if I don't see any "unknown devices" and driver already installed. But board still wont connect?
    MauriceB33НовицкийН
    Reply 4 months ago
    If any one is still having trouble, make sure you use the Old Bootloader You can choose this under the processor tab.
    JanT81НовицкийН
    Reply 8 months ago
    I have exactly same issue on my Win 10 machine. Did you manage to find a solution ?
    MauriceB33
    4 months ago
    One thing to add (I just read it in a comment on YouTube): If any one is still having trouble, make sure you use the Old Bootloader You can choose this under the processor tab.
    mbpadro
    8 months ago
    Thanks for this, much appreciated!
    AbrahamS37
    11 months ago
    Plain and Simple. Awesome !!
    Thank you very much !
    maviler
    1 year ago
    Top Man
    Baasil Biniyamin
    1 year ago
    Thanks dude i was searching for this driver, this helped me :)
    timonstacy
    1 year ago
    that website looks super sketchy but hey it works so thanks
    Chai LifeC
    1 year ago
    Yes I have made and work, https://cointwashingmachine.blogspot.com/2017/10/how-to-fix-arduino-uno-not-recognized.html
    FDM3
    1 year ago
    I was able to use this on my Nanos
    stu.tg
    1 year ago
    Under the device status on device manager I get
    This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
    Object Name already exists.
    Any ideas??
    Maggie Shahstu.tg
    Reply 1 year ago
    Open the device manager then, Locate the driver, and right-click on it. You will see options to:
    Update Driver Softwar , Uninstall Driver Software, and Install Drivers. First uninstall the existing driver. Then plug in the device and then restart the computer. The device will be detected and reinstalled after the restart. And update the driver for CH340G. Hope it work otherwise let me know.
    stu.tgMaggie Shah
    Reply 1 year ago
    Done all that - after running the .exe file the driver is installed successfully but still get
    Under device manager. I think Windows 10 maybe trying to load its own driver.
    Thank you for your response.
    RahulY45
    1 year ago
    It hepled. Thank you
    carlos66ba
    2 years ago
    There is nothing bad about the CH340 chips, in fact these are a lot better than the FTDI. Reasons: 1) you cannot know for sure if you have a fake FTDI chip, so anytime you use one you take a huge risk. 2) I will not do business with any company that intentionally damages someone else's property. FTDI intentionally bricked several of my devices, so I WILL NEVER EVER BUY ANYTHING WITH FTDI in it.
    frarugi87carlos66ba
    Reply 2 years ago
    I was a bit puzzled at your sentence "FTDI intentionally bricked several of my devices". What happened?
    Maggie Shahfrarugi87
    Reply 2 years ago
    FTDI, the manufacturer of the popular USB to Serial converter used by many Arduinos released a driver (2.11.0 and 2.12.0) that bricks chips that it believes to be counterfeit. What it did was to set the PID (Product ID) to 0000 instead of 6001 which renders the chip unusable as Windows cannot find a driver for it. However, there seems to be a fix created by the maker community out there
