Arduino Project in 5 Minutes
9,295
139
About: Circuito.io is an automatic web tool that will help you build almost any innovation you have ever dreamed of, by breaking technical barriers and giving you the best package to kickstart your project. Our In...
In the following Instructable, we'll show you how you can make your next Arduino project in just 5 minutes.
It's simple, easy and fun.
Enjoy! :)
Supplies:
Step 1: Plan It!
1. Go to Circuito.io
2. Select the components in the screenshot, add a description and your email and click "Send"
3. Instantly receive schematic and code from Circuito.io.
* Sometimes our emails go to "promotions" so make sure to check the different inboxes.
Step 2: Connect It!
1. Download the attachments from the email you received.
2. Unzip the folder.
3. Open the .FZZ file (If you don't have Fritzing, you can download it here for free)
4. Move components around so you have a clear view of the connections.
5. Connect the different components to the breadboard.
Step 3: Code It!
1. Open the Firmware folder
2. Open the Firmware.ino file (if you don't have Arduino installed, you can download it here for free)
3. Make changes to the code.
The original code will show the word: ON if an object is closer than 30 cm. from the sensor:
void loop ( )
if (ultrasonic.getCms () < 30 {
sevenSegment.write("on");
delay(1000);
sevenSegment.clear();
We decided that for this project, we want the seven segment display to show the distance from the sensor:
sevenSegment.write (ultraSonic.getCms() );
delay (250);
Step 4: Test It!
Now that everything is in place, you can test your project and see if it really works like it does on the video :)
If you have any trouble, you can always write to us >> hello@circuito.io or through our FB page
Step 5: Share It!
We would love to see how your project turned out.
Share it with us through our FB page and with the Makers' community.
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    3 Discussions
    bpwmd
    Reply 2 years ago
    No i get that but lets say i make project a and get everthing figured out then i want to make project be but still have project a running.
    bpwmd
    2 years ago
    Question what do I do after ive made this project. how can I free up the arduino to re use for another project. and still have the original one working?
    miraheng
    3 years ago
    thanks
