Arduino Solar Tracker
490,617
720
290
About: Hello, I'm Bruce. I'm a student in Belgium. I have a wide variety of interests: electronics, computers, technology, ... In my spare time I spend a lot of time on: projects, exploring the internet, cycling. ...
What is does:
It searches for the brightest light source like the sun.
There is a newer and better version of this project: https://www.instructables.com/id/Dual-Axis-300W-IOT-Solar-Tracker/
Supplies:
Step 1: How It Works
How it works:
I'd made a sensor of 4 LDRs with sheets between them
The white dots are the LDRs
When the stick on top is righted to the sun or the brightest point
the four LDRs get the same amount of light on them.
Example1 when the light is left on top:
right-top, right-down, left-down are in the shadow
and left-top get the most light
Example2 when the light is on top
left and right down are in the shadow and top is in the light
Step 2: Parts List
Step 3: The Set-up
Just hot glue it together!!!
Step 4: The Circuitry
Step 5: The Code
you can download the code down this page
/* this code is written by geobruce
for more info check my site http://xprobe.net
#include <Servo.h> // include Servo library
Servo horizontal; // horizontal servo
int servoh = 90; // stand horizontal servo
Servo vertical; // vertical servo
int servov = 90; // stand vertical servo
// LDR pin connections
// name = analogpin;
int ldrlt = 0; //LDR top left
int ldrrt = 1; //LDR top rigt
int ldrld = 2; //LDR down left
int ldrrd = 3; //ldr down rigt
void setup()
  Serial.begin(9600);
// servo connections
// name.attacht(pin);
  horizontal.attach(9);
  vertical.attach(10);
void loop()
  int lt = analogRead(ldrlt); // top left
  int rt = analogRead(ldrrt); // top right
  int ld = analogRead(ldrld); // down left
  int rd = analogRead(ldrrd); // down rigt
  int dtime = analogRead(4)/20; // read potentiometers
int tol = analogRead(5)/4;
int avt = (lt + rt) / 2; // average value top
int avd = (ld + rd) / 2; // average value down
int avl = (lt + ld) / 2; // average value left
int avr = (rt + rd) / 2; // average value right
int dvert = avt - avd; // check the diffirence of up and down
int dhoriz = avl - avr;// check the diffirence og left and rigt
if (-1*tol > dvert || dvert > tol) // check if the diffirence is in the tolerance else change vertical angle
if (avt > avd)
servov = ++servov;
if (servov > 180)
servov = 180;
else if (avt < avd)
servov= --servov;
if (servov < 0)
servov = 0;
vertical.write(servov);
if (-1*tol > dhoriz || dhoriz > tol) // check if the diffirence is in the tolerance else change horizontal angle
if (avl > avr)
servoh = --servoh;
if (servoh < 0)
servoh = 0;
else if (avl < avr)
servoh = ++servoh;
if (servoh > 180)
servoh = 180;
else if (avl == avr)
// nothing
horizontal.write(servoh);
delay(dtime);
Celestron Space Challenge
Runner Up in the
18 People Made This Project!
  • Party Challenge
    Party Challenge
  • Arduino Contest 2019
  • IoT Challenge
    IoT Challenge
290 Discussions
TomDunlap
5 years ago on Introduction
Just finished it and got it debugged. Really cool. Now I'm going to try to use it to build a Solar Forge and or a Solar Sand Sinter 3D Printer. Should be a snap. ;-)
ShreyasP4TomDunlap
Reply 3 years ago
Hey Tom, We are right now making a Solar sand sinter 3D printer. We have finished making the coordinate plate and are working on the tracking system now. Would like to get your inputs. Best,
BalaJ11ShreyasP4
Reply 3 years ago
hi dude ,
what is the rate and power of servo motor which u have used.. can u give me some details.. i have to do this as mini project
TomDunlapShreyasP4
Reply 3 years ago
Good luck with your project. I have not been able to pursue this one so not much more to add. Everything you need should be available online now. Except time and money. You'll have to come up with those. ;-)
TomDunlapgeo bruce
Reply 5 years ago on Introduction
Another development, I used a Makerbot Replicator to print a replacement for the foam core sensor holder. Here is the Sketchup pic of it. The two pieces glue together. The center top hole is for a fifth sensor to shut the system down if clouds block the sun so it doesn't try to point at the brightest cloud.
geo bruceTomDunlap
Nice!!!
It's cool to see your instructable finished by someone else :D
it means i've helped someone ^^ or someone liked my project! :D
TomDunlapgeo bruce
It's really helpful to get me started toward my other goals.
Next I want to modify the code to operate some 12V drill motors with a MotorShield or the like if I can find one that will handle the 3-4A current.
tgray1
5 days ago
The parts list says 10K resisters but the photo shows 1K (brown-black-red) and the handwritten notes say 1K.
mikhailmagri959
Question 6 days ago on Introduction
Hi,
just need to know what is the function of the potentiometers ?
Thanks
JosephM408
2 months ago on Step 5
Hello sir. What is the purpose of using a variable resistor that is connected in ANALOG PIN 4 AND 5?
DraconicOJosephM408
Reply 7 weeks ago
hello, after reading the code it appears that pin 5 controls the tolerance of the resistors (or how sensitive they are), you don't want a passing wispy cloud to make your projects go crazy if your tracking the sun. and pin 4 controls how often the code repeats, both can probably be replaced with constant integers in their place, however, having a pot. there makes for easily adjusting on the fly without needing to reconnect a laptop or pc, although i am new to arduino so theres a chance im reading it totally wrong.
Sallu Khan
5 months ago
There is a problem was occurred & still occurring to make this project. I am working to make this project as bigger type. I used generic high torque continuous (360 degree) servo motor (SM-S4303R) for rotating the panel. But a problem is occurring. That's is when servo motor started again it's rotates according to LDR's lighting action but the motors aren't stop. It's continuously rotates if once the LDR is lighted. I used this code for my project. What's the problem? Please help me .
