Arduino TFT Interfacing
3,998
39
About: Passionate Techie ! Robotics | Electronics | Programming - Worked with Arduino, PIC and ARM Controllers
TFT touchscreens are the amazing graphical interface which can be used with microcontrollers such as Atmel, PIC, STM, as it has a wide color range, and good graphical ability and a good mapping of pixels.
Today, we are going to Interface 2.4 inch TFT LCD Shield with Arduino.
This shield is for Arduino UNO, but I'll teach how to use it with Arduino Mega for a very logical reason, the "Program Memory".
By using this color TFT LCD shield we can show characters, strings, button interfacing, bitmap images, etc on the color TFT LCD.
Step 1: ​Hardware and Software Requirements
To make the shield interface with the Arduino mega, we need
HARDWARE :
• Arduino mega
• TFT 2.4/2.8/3.2 inch LCD
• USB Cable
SOFTWARE :
• Arduino IDE
UTFT Library / spfd5408 Library
The Shield is originally made for the Arduino UNO boards, which can be used with Arduino mega.
There are two main issues while using it with the Arduino UNO: "Storage memory" and pins usage.
It is difficult to use the unused pins which are available on UNO, whereas it is better with Arduino MEGA since we have more I/O pins left.
In the next step, I'll show how to edit the UTFT library to use the TFT shield
Step 2: Tweaking UTFT Lib
This library is the continuation of my ITDB02_Graph, ITDB02_Graph16 and RGB_GLCD libraries for Arduino and chipKit. As the number of supported display modules and controllers started to increase I felt it was time to make a single, universal library as it will be much easier to maintain in the future.
Arduino MEGA has 256kb of program memory. In addition, there are 54 pins.
Most of them are free to use, and the analog just 5 are taken from 16.
This library supports a number of 8bit,16bit, and serial graphics displays, and will work with both Arduino, chipKit boards and select TI LaunchPads.
NOTE:Due to the size of the library I do not recommend using it on ATmega328 (Arduino Uno) and ATmega32U4 (Arduino Leonardo) as they only have 32KB of flash memory. It will work, but you will be severely limited in available flash memory for your application.
Steps:
  • Download the UTFT Library
  • Unzip the Library
  • Open UTFT\hardware\avr in case of Arduino or depending on the microcontroller used
  • Open HW_AVR_defines using Notepad
  • Uncomment Line 7 to enable UNO shield for MEGA
  • Save the file and Add this Library to Arduino IDE
Now we are done with this step! In the next step, I'll show to use the library and define the pins for Arduino Mega.
Step 3: Initializing the TFT Shield
    After editing the library, Add it to the Arduino directory.
    Next, I'm gonna show you how to define the right TFT module that you have
    we should find its module name in the library.
    • open the library file
    • go to the documentation
    You can see these files in the Documentation
    • UTFT:
    This file shows all the functions and commands included in this library.
    • UTFT_Requirement
    This file has information about the modules and how it's related to the library, like pins configurations
    •UTFT_Supported_display_modules_&_controller
    This is our target, this file has the names of the modules and shields that are supported by this library, you can see in it a list of module names and module names for the UTFT which you should use to define your module.
    Steps to Define the TFT:
    Open UTFT_Supported_display_modules_&_controller file from the library
    • Open UTFT_Supported_display_modules_&_controller file from the library
    • Find the Models for UTFT for the Modules (shield) which you have.
    • Now to define a UTFT function on the Arduino IDE, we use the command :
    UTFT name(module,Rs,Wr,Cs,Rst);
    Open UTFT_Requirement file from the library
    From the document, we know that the pins are located on the A5, A4, A3, and A2 pins.
    we use the command:
    UTFT myGLCD(ITDB28,19,18,17,16); # note that pins 19,18,17,16 in the Arduino Mega
    UTFT myGLCD(ITDB28,A5,A4,A3,A2); # note that pins A5,A4,A3,A2 in the Arduino UNO
    And done! Now you can use the library examples on the Arduino IDE with the Following changes.
    Step 4: Basic Hello World
    #include <UTFT.h>
    // Declare which fonts we will be using
    extern uint8_t BigFont[];
    extern uint8_t SevenSegNumFont[];
    // Remember to change the model parameter to suit your display module!
    UTFT myGLCD(ITDB28, A5, A4, A3, A2);
    void setup()
    myGLCD.InitLCD();
    myGLCD.clrScr();
    myGLCD.setFont(BigFont);
    void loop()
    myGLCD.setColor(0, 255, 0); //green
    myGLCD.print("HELLO WORLD", 45, 100);
    while (true) {};
    Step 5: UTFT Fonts
    #include <UTFT.h>
    extern uint8_t SmallFont[];
    extern uint8_t SevenSegNumFont[];</p><p>// Set the pins to the correct ones for your development shield
    // Arduino Uno / 2009:
    // Standard Arduino Uno/2009 shield            : <display model="">,A5,A4,A3,A2
    // DisplayModule Arduino Uno TFT shield        : <display model="">,A5,A4,A3,A2
    // Arduino Mega:
    // Standard Arduino Mega/Due shield            : <display model="">,38,39,40,41
    // CTE TFT LCD/SD Shield for Arduino Mega      : <display model="">,38,39,40,41
    UTFT myGLCD(ITDB32S,38,39,40,41);</display></display></display></display></p><p>void setup()
      myGLCD.InitLCD();</p><p>  myGLCD.clrScr();
    }</p><p>void loop()
      myGLCD.setBackColor(0, 0, 0);</p><p>  myGLCD.setFont(BigFont);
      myGLCD.print(" !\"#$%&'()*+,-./", CENTER, 0);
      myGLCD.print("0123456789:;<=>?", CENTER, 16);
      myGLCD.print("@ABCDEFGHIJKLMNO", CENTER, 32);
      myGLCD.print("PQRSTUVWXYZ[\\]^_", CENTER, 48);
      myGLCD.print("`abcdefghijklmno", CENTER, 64);
      myGLCD.print("pqrstuvwxyz{|}~ ", CENTER, 80);</p><p>  myGLCD.setFont(SmallFont);
      myGLCD.print(" !\"#$%&'()*+,-./0123456789:;<=>?", CENTER, 120);
      myGLCD.print("@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\\]^_", CENTER, 132);
      myGLCD.print("`abcdefghijklmnopqrstuvwxyz{|}~ ", CENTER, 144);</p><p>  myGLCD.setFont(SevenSegNumFont);
      myGLCD.print("0123456789", CENTER, 190);</p><p>  while(1) {};
    Step 6: UTFT Shapes, Lines and Pattern
    #include <UTFT.h><br>
    // Standard Arduino Uno/2009 shield            : ,A5,A4,A3,A2
    // DisplayModule Arduino Uno TFT shield        : ,A5,A4,A3,A2
    // Arduino Mega:
    // Standard Arduino Mega/Due shield            : ,38,39,40,41
    // CTE TFT LCD/SD Shield for Arduino Mega      : ,38,39,40,41
    void setup()
      randomSeed(analogRead(0));
    // Setup the LCD
      myGLCD.InitLCD();
    void loop()
      int buf[318];
      int x, x2;
      int y, y2;
      int r;
    // Clear the screen and draw the frame
      myGLCD.clrScr();
      myGLCD.setColor(255, 0, 0);
      myGLCD.fillRect(0, 0, 319, 13);
      myGLCD.setColor(64, 64, 64);
      myGLCD.fillRect(0, 226, 319, 239);
      myGLCD.setColor(255, 255, 255);
      myGLCD.setBackColor(255, 0, 0);
      myGLCD.print("* Universal Color TFT Display Library *", CENTER, 1);
      myGLCD.setBackColor(64, 64, 64);
      myGLCD.setColor(255,255,0);
      myGLCD.print("", CENTER, 227);
      myGLCD.setColor(0, 0, 255);
      myGLCD.drawRect(0, 14, 319, 225);
    // Draw crosshairs
      myGLCD.drawLine(159, 15, 159, 224);
      myGLCD.drawLine(1, 119, 318, 119);
      for (int i=9; i<310; i+=10)
        myGLCD.drawLine(i, 117, i, 121);
      for (int i=19; i<220; i+=10)
        myGLCD.drawLine(157, i, 161, i);
    // Draw sin-, cos- and tan-lines
      myGLCD.setColor(0,255,255);
      myGLCD.print("Sin", 5, 15);
      for (int i=1; i<318; i++)
        myGLCD.drawPixel(i,119+(sin(((i*1.13)*3.14)/180)*95));
      myGLCD.setColor(255,0,0);
      myGLCD.print("Cos", 5, 27);
        myGLCD.drawPixel(i,119+(cos(((i*1.13)*3.14)/180)*95));
      myGLCD.print("Tan", 5, 39);
        myGLCD.drawPixel(i,119+(tan(((i*1.13)*3.14)/180)));
      delay(2000);
      myGLCD.setColor(0,0,0);
      myGLCD.fillRect(1,15,318,224);
    // Draw a moving sinewave
      x=1;
      for (int i=1; i<(318*20); i++)
        x++;
        if (x==319)
          x=1;
        if (i>319)
          if ((x==159)||(buf[x-1]==119))
            myGLCD.setColor(0,0,255);
          else
          myGLCD.drawPixel(x,buf[x-1]);
        y=119+(sin(((i*1.1)*3.14)/180)*(90-(i / 100)));
        myGLCD.drawPixel(x,y);
        buf[x-1]=y;
      delay(2000);
    // Draw some filled rectangles
      for (int i=1; i<6; i++)
        switch (i)
          case 1:
            myGLCD.setColor(255,0,255);
            break;
          case 2:
            break;
          case 3:
            myGLCD.setColor(0,255,0);
            break;
          case 4:
            break;
          case 5:
            break;
        myGLCD.fillRect(70+(i*20), 30+(i*20), 130+(i*20), 90+(i*20));
      delay(2000);
    // Draw some filled, rounded rectangles
        switch (i)
          case 1:
            break;
          case 2:
            break;
          case 3:
            break;
          case 4:
            break;
          case 5:
            break;
        myGLCD.fillRoundRect(190-(i*20), 30+(i*20), 250-(i*20), 90+(i*20));
      delay(2000);
    // Draw some filled circles
        switch (i)
          case 1:
            break;
          case 2:
            break;
          case 3:
            break;
          case 4:
            break;
          case 5:
            break;
        myGLCD.fillCircle(100+(i*20),60+(i*20), 30);
      delay(2000);
    // Draw some lines in a pattern
      myGLCD.setColor (255,0,0);
      for (int i=15; i<224; i+=5)
        myGLCD.drawLine(1, i, (i*1.44)-10, 224);
      for (int i=224; i>15; i-=5)
        myGLCD.drawLine(318, i, (i*1.44)-11, 15);
      myGLCD.setColor (0,255,255);
        myGLCD.drawLine(1, i, 331-(i*1.44), 15);
        myGLCD.drawLine(318, i, 330-(i*1.44), 224);
      delay(2000);
    // Draw some random circles
      for (int i=0; i<100; i++)
        myGLCD.setColor(random(255), random(255), random(255));
        x=32+random(256);
        y=45+random(146);
        r=random(30);
        myGLCD.drawCircle(x, y, r);
      delay(2000);
    // Draw some random rectangles
        x=2+random(316);
        y=16+random(207);
        x2=2+random(316);
        y2=16+random(207);
        myGLCD.drawRect(x, y, x2, y2);
      delay(2000);
    // Draw some random rounded rectangles
        x=2+random(316);
        y=16+random(207);
        x2=2+random(316);
        y2=16+random(207);
        myGLCD.drawRoundRect(x, y, x2, y2);
      delay(2000);
        x=2+random(316);
        y=16+random(209);
        x2=2+random(316);
        y2=16+random(209);
        myGLCD.drawLine(x, y, x2, y2);
      delay(2000);
      for (int i=0; i<10000; i++)
        myGLCD.drawPixel(2+random(316), 16+random(209));
      delay(2000);
      myGLCD.fillScr(0, 0, 255);
      myGLCD.fillRoundRect(80, 70, 239, 169);
      myGLCD.print("That's it!", CENTER, 93);
      myGLCD.print("Restarting in a", CENTER, 119);
      myGLCD.print("few seconds...", CENTER, 132);
      myGLCD.setBackColor(0, 0, 255);
      myGLCD.print("Runtime: (msecs)", CENTER, 210);
      myGLCD.printNumI(millis(), CENTER, 225);
      delay (10000);
    Step 7: UTFT Bitmap
    <pre>#include <UTFT.h><br>#include <avr/pgmspace.h>
    // Arduino Mega:
    UTFT myGLCD(ITDB32S,A5,A4,A3,A2);
    extern unsigned int info[0x400];
    extern unsigned int icon[0x400];
    extern unsigned int tux[0x400];
    void setup()
      myGLCD.InitLCD();
    void loop()
      myGLCD.fillScr(255, 255, 255);
      myGLCD.print(" *** A 10 by 7 grid of a 32x32 icon *** ", CENTER, 228);
      for (int x=0; x<10; x++)
        for (int y=0; y<7; y++)
          myGLCD.drawBitmap (x*32, y*32, 32, 32, info);
      delay(5000);
      myGLCD.print("   Two different icons in scale 1 to 4  ", CENTER, 228);
      int x=0;
      for (int s=0; s<4; s++)
        x+=(s*32);
        myGLCD.drawBitmap (x, 0, 32, 32, tux, s+1);
      x=0;
      for (int s=4; s>0; s--)
        myGLCD.drawBitmap (x, 224-(s*32), 32, 32, icon, s);
        x+=(s*32);
      delay(5000);
    Step 8: Button Interfacing
    #include <UTFT.h><br>#include  <URTouch.h>
    // Initialize display
    // Set the pins to the correct ones for your development board
    // Standard Arduino Uno/2009 Shield            : ,19,18,17,16
    // CTE TFT LCD/SD Shield for Arduino Due       : ,25,26,27,28
    // Teensy 3.x TFT Test Board                   : ,23,22, 3, 4
    // ElecHouse TFT LCD/SD Shield for Arduino Due : ,22,23,31,33
    // Initialize touchscreen
    // Standard Arduino Uno/2009 Shield            : 15,10,14, 9, 8
    // Standard Arduino Mega/Due shield            :  6, 5, 4, 3, 2
    // CTE TFT LCD/SD Shield for Arduino Due       :  6, 5, 4, 3, 2
    // Teensy 3.x TFT Test Board                   : 26,31,27,28,29
    // ElecHouse TFT LCD/SD Shield for Arduino Due : 25,26,27,29,30
    URTouch  myTouch( 6, 5, 4, 3, 2);
    int x, y;
    char stCurrent[20]="";
    int stCurrentLen=0;
    char stLast[20]="";
    **   Custom functions   **
    void drawButtons()
    // Draw the upper row of buttons
      for (x=0; x<5; x++)
        myGLCD.fillRoundRect (10+(x*60), 10, 60+(x*60), 60);
        myGLCD.drawRoundRect (10+(x*60), 10, 60+(x*60), 60);
        myGLCD.printNumI(x+1, 27+(x*60), 27);
    // Draw the center row of buttons
      for (x=0; x<5; x++)
        myGLCD.fillRoundRect (10+(x*60), 70, 60+(x*60), 120);
        myGLCD.drawRoundRect (10+(x*60), 70, 60+(x*60), 120);
        if (x<4)
          myGLCD.printNumI(x+6, 27+(x*60), 87);
      myGLCD.print("0", 267, 87);
    // Draw the lower row of buttons
      myGLCD.fillRoundRect (10, 130, 150, 180);
      myGLCD.drawRoundRect (10, 130, 150, 180);
      myGLCD.print("Clear", 40, 147);
      myGLCD.fillRoundRect (160, 130, 300, 180);
      myGLCD.drawRoundRect (160, 130, 300, 180);
      myGLCD.print("Enter", 190, 147);
      myGLCD.setBackColor (0, 0, 0);
    void updateStr(int val)
      if (stCurrentLen<20)
        stCurrent[stCurrentLen]=val;
        stCurrent[stCurrentLen+1]='\0';
        stCurrentLen++;
        myGLCD.print(stCurrent, LEFT, 224);
      else
        myGLCD.print("BUFFER FULL!", CENTER, 192);
        delay(500);
        myGLCD.print("            ", CENTER, 192);
        delay(500);
        delay(500);
    // Draw a red frame while a button is touched
    void waitForIt(int x1, int y1, int x2, int y2)
      myGLCD.drawRoundRect (x1, y1, x2, y2);
      while (myTouch.dataAvailable())
        myTouch.read();
    **  Required functions  **
    void setup()
    // Initial setup
      myGLCD.InitLCD();
      myGLCD.clrScr();
      myTouch.InitTouch();
      myTouch.setPrecision(PREC_MEDIUM);
      drawButtons();
    void loop()
      while (true)
        if (myTouch.dataAvailable())
          myTouch.read();
          x=myTouch.getX();
          y=myTouch.getY();
          if ((y>=10) && (y<=60))  // Upper row
            if ((x>=10) && (x<=60))  // Button: 1
              waitForIt(10, 10, 60, 60);
              updateStr('1');
            if ((x>=70) && (x<=120))  // Button: 2
              waitForIt(70, 10, 120, 60);
              updateStr('2');
            if ((x>=130) && (x<=180))  // Button: 3
              waitForIt(130, 10, 180, 60);
              updateStr('3');
            if ((x>=190) && (x<=240))  // Button: 4
              waitForIt(190, 10, 240, 60);
              updateStr('4');
            if ((x>=250) && (x<=300))  // Button: 5
              waitForIt(250, 10, 300, 60);
              updateStr('5');
          if ((y>=70) && (y<=120))  // Center row
            if ((x>=10) && (x<=60))  // Button: 6
              waitForIt(10, 70, 60, 120);
              updateStr('6');
            if ((x>=70) && (x<=120))  // Button: 7
              waitForIt(70, 70, 120, 120);
              updateStr('7');
            if ((x>=130) && (x<=180))  // Button: 8
              waitForIt(130, 70, 180, 120);
              updateStr('8');
            if ((x>=190) && (x<=240))  // Button: 9
              waitForIt(190, 70, 240, 120);
              updateStr('9');
            if ((x>=250) && (x<=300))  // Button: 0
              waitForIt(250, 70, 300, 120);
              updateStr('0');
          if ((y>=130) && (y<=180))  // Upper row
            if ((x>=10) && (x<=150))  // Button: Clear
              waitForIt(10, 130, 150, 180);
              stCurrent[0]='\0';
              stCurrentLen=0;
              myGLCD.setColor(0, 0, 0);
              myGLCD.fillRect(0, 224, 319, 239);
            if ((x>=160) && (x<=300))  // Button: Enter
              waitForIt(160, 130, 300, 180);
              if (stCurrentLen>0)
                for (x=0; x
    Step 9: Flappy Bird
    #include  <EEPROM.h>
    //==== Creating Objects
    UTFT    myGLCD(SSD1289,38,39,40,41); //Parameters should be adjusted to your Display/Schield model
    UTouch  myTouch( 6, 5, 4, 3, 2);
    //==== Defining Fonts
    extern unsigned int bird01[0x41A]; // Bird Bitmap
    int x, y; // Variables for the coordinates where the display has been pressed
    // Floppy Bird
    int xP = 319;
    int yP = 100;
    int yB = 50;
    int movingRate = 3;
    int fallRateInt = 0;
    float fallRate = 0;
    int score = 0;
    int lastSpeedUpScore = 0;
    int highestScore;
    boolean screenPressed = false;
    boolean gameStarted = false;
    void setup() {
      // Initiate display
      myGLCD.InitLCD();
      myGLCD.clrScr();
      highestScore = EEPROM.read(0); // Read the highest score from the EEPROM
      initiateGame(); // Initiate the game
    void loop() {
        xP=xP-movingRate; // xP - x coordinate of the pilars; range: 319 - (-51)
        drawPilars(xP, yP); // Draws the pillars
        // yB - y coordinate of the bird which depends on value of the fallingRate variable
        yB+=fallRateInt;
        fallRate=fallRate+0.4; // Each inetration the fall rate increase so that we can the effect of acceleration/ gravity
        fallRateInt= int(fallRate);
        // Checks for collision
        if(yB>=180 || yB<=0){ // top and bottom
          gameOver();
        if((xP<=85) && (xP>=5) && (yB<=yP-2)){ // upper pillar
          gameOver();
        if((xP<=85) && (xP>=5) && (yB>=yP+60)){ // lower pillar
          gameOver();
        // Draws the bird
        drawBird(yB);
        // After the pillar has passed through the screen
        if (xP<=-51){
          xP=319; // Resets xP to 319
          yP = rand() % 100+20; // Random number for the pillars height
          score++; // Increase score by one
        //==== Controlling the bird
        if (myTouch.dataAvailable()&& !screenPressed) {
           fallRate=-6; // Setting the fallRate negative will make the bird jump
           screenPressed = true;
        // Doesn't allow holding the screen / you must tap it
        else if ( !myTouch.dataAvailable() && screenPressed){
        // After each five points, increases the moving rate of the pillars
        if ((score - lastSpeedUpScore) == 5) {
          lastSpeedUpScore = score;
          movingRate++;
    // ===== initiateGame - Custom Function
    void initiateGame() {
      myGLCD.clrScr();
      // Blue background
      myGLCD.setColor(114, 198, 206);
      myGLCD.fillRect(0,0,319,239);
      // Ground
      myGLCD.setColor(221,216,148);
      myGLCD.fillRect(0, 215, 319, 239);
      myGLCD.setColor(47,175,68);
      myGLCD.fillRect(0, 205, 319, 214);
      // Text
      myGLCD.setBackColor(221, 216, 148);
      myGLCD.print("Score:",5,220);
      myGLCD.print("HowToMechatronics.com", 140, 220);
      myGLCD.setBackColor(114, 198, 206);
      myGLCD.print("Highest Score: ",5,5);
      myGLCD.printNumI(highestScore, 120, 6);
      myGLCD.print(">RESET<",255,5);
      myGLCD.drawLine(0,23,319,23);
      myGLCD.print("TAP TO START",CENTER,100);
      drawBird(yB); // Draws the bird
      // Wait until we tap the sreen
      while (!gameStarted) {
        if (myTouch.dataAvailable()) {
        myTouch.read();
        x=myTouch.getX();
        y=myTouch.getY();
        // Reset higest score
        if ((x>=250) && (x<=319) &&(y>=0) && (y<=28)) {
        highestScore = 0;
        myGLCD.fillRect(120, 0, 150, 22);
        myGLCD.printNumI(highestScore, 120, 5);
        if ((x>=0) && (x<=319) &&(y>=30) && (y<=239)) {
        gameStarted = true;
        myGLCD.fillRect(0, 0, 319, 32);
      // Clears the text "TAP TO START" before the game start
      myGLCD.fillRect(85, 100, 235, 116);
    // ===== drawPlillars - Custom Function
    void drawPilars(int x, int y) {
        if (x>=270){
          myGLCD.setColor(0, 200, 20);
          myGLCD.fillRect(318, 0, x, y-1);
          myGLCD.drawRect(319, 0, x-1, y);
          myGLCD.fillRect(318, y+81, x, 203);
          myGLCD.drawRect(319, y+80, x-1, 204);
        else if( x<=268) {
          // Draws blue rectangle right of the pillar
          myGLCD.fillRect(x+51, 0, x+60, y);
          // Draws the pillar
          myGLCD.fillRect(x+49, 1, x+1, y-1);
          // Draws the black frame of the pillar
          myGLCD.drawRect(x+50, 0, x, y);
          // Draws the blue rectangle left of the pillar
          myGLCD.fillRect(x-1, 0, x-3, y);
          // The bottom pillar
          myGLCD.fillRect(x+51, y+80, x+60, 204);
          myGLCD.fillRect(x+49, y+81, x+1, 203);
          myGLCD.drawRect(x+50, y+80, x, 204);
          myGLCD.fillRect(x-1, y+80, x-3, 204);
      // Draws the score
      myGLCD.printNumI(score, 100, 220);
    //====== drawBird() - Custom Function
    void drawBird(int y) {
      // Draws the bird - bitmap
      myGLCD.drawBitmap (50, y, 35, 30, bird01);
      // Draws blue rectangles above and below the bird in order to clear its previus state
      myGLCD.fillRoundRect(50,y,85,y-6);
      myGLCD.fillRoundRect(50,y+30,85,y+36);
    //======== gameOver() - Custom Function
    void gameOver() {
      delay(3000); // 1 second
      // Clears the screen and prints the text
      myGLCD.clrScr();
      myGLCD.print("GAME OVER", CENTER, 40);
      myGLCD.print("Score:", 100, 80);
      myGLCD.printNumI(score,200, 80);
      myGLCD.print("Restarting...", CENTER, 120);
      myGLCD.printNumI(2,CENTER, 150);
      delay(1000);
      myGLCD.printNumI(1,CENTER, 150);
      delay(1000);
      // Writes the highest score in the EEPROM
      if (score > highestScore) {
        highestScore = score;
        EEPROM.write(0,highestScore);
      // Resets the variables to start position values
      xP=319;
      yB=50;
      fallRate=0;
      score = 0;
      movingRate = 3;
      // Restart game
      initiateGame();
    Step 10: Working of the Project
    Give a thumbs up if it really helped you and do follow my channel for interesting projects :)
    Share this video if you like.
    Happy to have you subscribed: https://www.youtube.com/channel/UCks-9JSnVb22dlqtMgPjrlg/videos
    Thanks for reading!
    Electronics Tips & Tricks Challenge
    Runner Up in the
      • Arduino Contest 2019
      • Trash to Treasure
        Trash to Treasure
      • Tape Contest
        Tape Contest
      3 Discussions
      TaranA3
      3 months ago
      can i create colored items (like castles and ships) on a 16x2 lcd screen?
      thelonelyprogrammerTaranA3
      Answer 8 days ago
      LCD 16x2 can support only alphanumeric content. You can create a custom character with 5x8 pixel.
      You can't use a 16x2 to create those images. But, it is possible to make Bitmap on Graphic LCD's.
