Arduino Trumpet
52,156
259
84
About: I love the TV shows Psych and Monk Bands Relient K and Anberlin destroying things making things swimming and having fun.
This project emulates a trumpet by playing notes using the three buttons (valves). This is easy to make and fun to play with, though it can only play one octave and no sharps/flats.
Step 1: Code
Load this into your Arduino:
int speaker = 9; // Hook up speaker to digital pin 9
int sw1 = 15; // Switch hooked to analog pin 1
int sw2 = 16; // Switch hooked to analog pin 2
int sw3 = 17; // Switch hooked to analog pin 3
int valve1;
int valve2;
int valve3;
void c () { // Presets the note "c" to be used later
digitalWrite(speaker, HIGH);
delayMicroseconds(1915);
digitalWrite(speaker, LOW);
delayMicroseconds(1905);
void d () {
delayMicroseconds(1700);
delayMicroseconds(1690);
void e () {
delayMicroseconds(1519);
delayMicroseconds(1509);
void f () {
delayMicroseconds(1432);
delayMicroseconds(1422);
void g () {
delayMicroseconds(1275);
delayMicroseconds(1265);
void a () {
delayMicroseconds(1136);
delayMicroseconds(1126);
void b () {
delayMicroseconds(1014);
delayMicroseconds(1004);
void C () {
delayMicroseconds(956);
delayMicroseconds(946);
void setup() {
pinMode(speaker, OUTPUT);
pinMode(sw1, INPUT);
digitalWrite(sw1, HIGH);
pinMode(sw2, INPUT);
digitalWrite(sw2, HIGH);
pinMode(sw3, INPUT);
digitalWrite(sw3, HIGH);
// Serial.begin(9600);
void loop() {
valve1 = digitalRead(sw1); // Reads switch 1
valve2 = digitalRead(sw2); // Reads switch 2
valve3 = digitalRead(sw3); // Reads switch 3
if ((valve1 == LOW) && (valve2 == LOW) && (valve3 == LOW)) { // If all valves are pressed, then
c(); // It plays a "c"
else if ((valve1 == LOW) && (valve2 == HIGH) && (valve3 == LOW)) { // If the first and third valves are pressed, then
d(); // It plays a "d"
else if ((valve1 == LOW) && (valve2 == LOW) && (valve3 == HIGH)) { // If the first and second valves are pressed, then
e(); // It plays a "e"
else if ((valve1 == LOW) && (valve2 == HIGH) && (valve3 == HIGH)) { // If the first valve is pressed, then
f(); // It plays a "f"
else if ((valve1 == HIGH) && (valve2 == HIGH) && (valve3 == HIGH)) { // If no valves are pressed, then
g(); // It plays a "g"
else if ((valve1 == HIGH) && (valve2 == HIGH) && (valve3 == LOW)) { // If the third valve is pressed, then
a(); // It plays a "a"
else if ((valve1 == HIGH) && (valve2 == LOW) && (valve3 == HIGH)) { // If the second valve is pressed, then
b(); // It plays a "b"
else if ((valve1 == HIGH) && (valve2 == LOW) && (valve3 == LOW)) { // If the second and third valves are pressed, then
C(); // It plays a "C"
else{
delay(1);
Step 2: Hook It Up
Each of the three switches go from ground to analog in 1, 2, and 3. The Piezo goes from digital pin 9 to ground. Make sure to have the switches in the right order in order to have the correct fingerings. Afterwords, download the file and upload it to your Arduino.
Step 3: Materials
You will need:
-Arduino
-9v battery and clasp
-3 momentary switches (NO)
-Project box (4x2x1)
-Piezo speaker element
-Header pins
-Soldering stuff
-Hotglue
-Dremel
-Drill and 1/4 in bit along with 1/16 in
Step 4: Put It Together!!
First, open the box and on the outside, mark the center and an inch out from the center. These marks are where you will need to make a 1/4 in hole ( I would suggest using a pilot hole).
Now, dremel out the scraps of plastic and the holders used to hold a PC inside, we will not be needing these.
Step 5: Make It Fit
Insert the switches and make sure they fit and screw them in.
Insert the pins into the correct spot and then mark the case where they are and drill holes with a 1/16 in drill bit. Then, make sure it fits and then flip it over to the open side.
Step 6: Wireing
Now, solder a wire to each of the analog input posts and attach the other side to the corresponding switch. Make sure to not get mixed up and solder the wrong switch to the wrong pin. The other side goes to ground. Sound Fimiliar?
Like before, solder the piezo to pin 9 and ground and the battery clasp to ground and voltage in.
Then, Hotglue over the solder connections on the pins, and attach the battery, you should hear a tone, if not check your wireing.
Afterwords, cram in the battery and piezo, its a tight fit! I found it best to put the speaker by the pins and the battery on the other side. Whatever works.
Step 7: Playing
The fingerings on this trumpet are 'similar' to a normal trumpet. By 'similar' I mean I had to make a few changes.
on a normal trumpet its like this:
c..........0pen
d..........1-3
e..........1-2
f ..........1
g..........0pen / 1-3
a..........1-2 / 3
b..........2
C..........0pen / 2-3
On the Arduino Trumpet:
c..........1-2-3
d..........1-3
e..........1-2
f ..........1
g..........0pen
a..........3
b..........2
C..........2-3
I could have complicated things and put an octive changing switch and used half steps. Though it would be awsome, It would be more complicated and I would need a bigger box.
HAVE FUN
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
84 Discussions
josei_ng
2 years ago
Whats the schematic drawing of the circuit?
MikenHarnish
3 years ago
how do you write more notes in? like another octave
RaeganH
3 years ago
i am a middle school student that did this for a class project. could someone help me with adding another button to be the rest or something. i cant have the constant noise.
TomB88
3 years ago
it may have been possible to include another octave by adding a sensor that you could "blow" or just hold infront of your face, this could be achieved by a light sensitive or pressure sensitive module. LOVE the project though !
nmrobotics
3 years ago on Introduction
What would i have to change to use a buzzer instead of a speaker?
Arduino Tech
4 years ago
is it a speaker or a buzzer ??
Maker1721
6 years ago on Step 2
Does this project need a breadboard?
hankenstien
6 years ago on Introduction
Cool IDea,
I took your idea, and instead of buttons i used potentiometers, just to see what would happen, it was kinda cool, you could get and hold various tones, might be fun if some one knew how to hack the code to read the potentiometer values, so it was more then an on or off type thing, any cool idea, i also like the piezo blow hole idea, read hears somewhere.
PEACE~
Hankenstien
rduino.com
jonoxer
9 years ago on Introduction
Adding a pressure sensor wouldn't be hard at all. You just need something like a MPX2010DP differential pressure transducer then feed it into an op-amp comparitor / amplifier, then read that with analog in on the Arduino. I've just done exactly that for a totally different purpose (measuring the depth of a water tank) and the circuit I built would work perfectly in this trumpet. In fact while building it I tested the circuit by blowing into the transducer and watching the analog read value change! There's more about it here including a photo of the shield: http://www.practicalarduino.com/news/id/101
srikarbeechujonoxer
 hello sir its great to hear as that we can use a DPT but sir i have a major problem making the transducer work for your own application for  TANK DEPTH SENSOR. Sir i kindly oblige you to help me or teach how to work on DPT. please my sincere request please i would be glad if u could give me your facebook userbook i really need to chat with u sir.please.
jonoxersrikarbeechu
 @srikarbeechu Have you read the explanation in the book? I can't really help you unless I know what you've tried.
srikarbeechujonoxer
@ jonoxer sir kindly help me how to work with MPX@)!)DP DPT... i am unable to measure the output voltage of the transducer and the water tank depth sensor experiment.
no0x
That's great !
How can we do to have more sound from the piezo ?
Have we to put an amplifier or something else ?
Thanks !
Kulf
9 years ago on Step 1
 Would you be able to modify this code to use with a guitar hero guitar? So when you press the frets and strum the bar it plays the tones. That's what I'm planning on doing.
Ouroboros439
No vote until I hear it. How do I know if yours even works? Come on just a little blues or some Louie Armstrong.
ReCreateOuroboros439
It would theoretically work, And most likely would too, by looking at the code. Though it might sound a bit bad, as it generates square waves, the only easy way to create sound in the arduino, it would sound better if it was a sine wave...
