Arduino Based Bi-color LED Matrix Tetris Game
53,562
158
49
One of the electronics DIY kit jolliFactory came up with is the Bi-color LED Matrix Driver Module Kit. This module is designed to be chain-able so that you may daisy-chain the modules together to the number of modules you need to suit your project.
The following are some of the projects built using this Bi-color LED Matrix Driver module:
It is amazing to browse through instructables and find projects which may interest and inspire you to embark on the project or ignite new ideas for your project.
Tetris is a tile-matching puzzle video game released in 1984 and it was the hugely successful handheld version for the Game Boy launched in 1989 that established the game as one of the most popular ever.
Just for FUN, we thought we could build a simple Tetris game by daisy-chaining two of the Bi-color LED Matrix Driver modules together driven by an Arduino micro-controller simply by adapting similar projects found at instructables. We searched through the instructables here but did not manage to find any similar Tetris project to work on.
We expand our search to other online sites and managed to find some information which we adapted to build a simple Arduino based Bi-color LED Matrix Tetris game here.
To build this project, basic electronics knowledge with electronics component soldering skill and some knowledge on using the Arduino are required.
You may view the following YouTube video to see what we are building.
Step 1: Building the Bi-color LED Matrix Driver Module
We will be building a two LED Matrix tall Tetris game here driven by an Arduino Nano for this project. We will need two of the Bi-color (Red/Green) LED Matrix Driver Module Kits from jolliFactory. Each of these modules uses two MAX7219 Display Driver ICs to drive a Bi-color LED Matrix. These ICs are excellent because they take a lot of work off the micro-controller and simplify the wiring and logic design.
You can find this Bi-color LED Matrix Driver Module kit from here.
This kit comes with all through-hole components and someone with basic soldering skill should be able to assemble it without much difficulty.
See the following YouTube video on how to assemble the LED Matrix Driver Module Kit:
Step 2: Wiring
After all the LED Matrix Driver Module kits are completed, they are connected together with the Arduino Nano micro-controller as shown in the wiring diagram (LED Matrices not installed for better view).
For the game audio output, we used one 8 ohms 0.5 watt speaker driven directly by one of the Arduino’s digital pins through a 100 ohms resistor. Basic sound tone is used for this project and the low sound volume should be sufficient for a hand-held game with this simple setup.
Four SPST Panel Mount Momentary Push Button Switches are required for the project for navigation and rotation of the Tetris blocks.
Note the use of 10Kohms pull-down resistors on the DATA IN, CLK and LOAD input pins. When power is first applied to the micro-controller or when they are reset, their I/O lines float. The MAX7219 can see this as valid data and display garbage until the micro-controller gains control. The pull-down resistors prevent these problems. To reduce the part count for this project, you may try without the 10Kohms pull-down resistors for the DATA IN and CLK input lines.
Except for the two Bi-color LED Matrix Driver modules and the four push button switches, we hook up the entire circuit on a small piece of perf-board around 60mm x 60mm in size.
Note that there are four PCB mount push buttons on the perf-board in the photo. We initially used them for the game control but after building a simple enclosure for the game, we decided to use four panel mount push buttons instead for better game control. We parallel wired our panel mount push button with the PCB mount push buttons so game control can now be performed using either the PCB or panel mount push buttons.
Edit:For those who do not want to mess around with too much wiring using perf-board, jolliFactory have designed a bare interface PCB board suitable to build this project. If you are using this interface PCB board, do remember to change the speaker output digital pin from D9 to D8 in the sketch downloaded from this instructable to drive the speaker.
You may find our bare interface PCB board at https://www.tindie.com/products/Nick64/jf-interface-board-1-bare-pcb-board-with-headers/
Step 3: Programming the Arduino Board
The Arduino board needs to be loaded with the Arduino sketch to run the display.
We used Arduino IDE V1.03 for our project. Download the Arduino sketch below for this project.
Download jollifactory_Tetris_V1_1.ino
The Tetris game sketch we have here is very basic without any game levels and scores. You may amend and enhance the sketch.
Note: Having some problems with your Bi-color LED Matrix Display modules? Download the following test program to test each of your modules separately. The display should light up RED, GREEN and ORANGE in sequence row by row to fill up the entire display repeatedly.
Download jolliFactory_Bi_Color_LED_Matrix_Test_Check.ino
Step 4: Enclosure and Assembly
As this project is simply built for the FUN factor with no intention of using it for long, we did not pay too much attention to build a proper enclosure. However, the enclosure built should enable the player to hand-held the gadget to play quite comfortably.
What we have for the enclosure is a cardboard box backing with a blue tinted acrylic protective front with the game control push button switches mounted. We did not even secure the modules to the enclosure as they fit quite snugly in the enclosure.
We will not delve into the detail on how we build our game enclosure here. The pictures show the various stages of assembling the completed sub-modules together.
2 People Made This Project!
  • Arduino Contest 2019
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
49 Discussions
masteruan
1 year ago
Nice project. Where in the code you trig the line complete.I want add score. Every line complete I want add 1 point.
GutierrezC
2 years ago
can we add another lcd for score and highscore?? and game difficulty??
jollifactoryGutierrezC
Reply 2 years ago
Yes. It should be possible to connect a separate LCD for display. Use a I2C LCD Display for ease of interfacing though it is a bit more expensive. You will need to modify the code yourself to implement score display and game difficulty.
GutierrezCjollifactory
Reply 2 years ago
can i use this led matrix?
https://www.amazon.com/gp/product/B00AYAPB9Q
Reply 2 years ago
No. That LED matrix display is a single color display. We are using a bi-color LED matrix display for this project which we are able to make it light up in three colors . You may find online for Tetris games implemented using a single color display or modify our Arduino sketch to work with it. We prefer the bi-color LED matrix display for implementing this game as it makes the game look more interesting.
e_Darwishjollifactory
Reply 1 year ago
hi ... i'm so interested in your project. can i modify the code to replace each GREEN in the code with RED. this way I shall get all the patterns in RED instead of GREEN... right? if so, any other modification i can work on ??? thanks in advance
Reply 2 years ago
and what arduino can i use if i don't have arduino nano??
thanks for the answer.
Reply 2 years ago
The entry level Arduino UNO should be a good choice. It is very similar to the Nano except for the size.
mibarnett
2 years ago
I'm trying to connect 3 or more LED matrices to add on
It seems to skip one Matrix and moves on to another, even when you define the number
is there something that I need to do to amend the code to work with 4 matrices in series?
Juan CarlosD22
2 years ago
Hola, gracias por este post muy bueno, logré hacerlo pero no me funciona bien, a ver si pueden ayudarme
Use 2 matriz 8x8 single color, y me aparecen días y las piezas salen de un lateral, gracias por la ayuda
Nachitoosss2
2 years ago
One question, I do not have the bi Matrix color, which would only be having one color, that part of the exchange code, leaving only one color?
GutierrezC
2 years ago
can we add a score and highscore?? and game difficulty??
Trying0ut
2 years ago
How do you actually wire all of them on small piece of board???
jollifactoryTrying0ut
Reply 2 years ago
We used perf-boards with copper dough-nuts and solder thin wires for point to point connections.
Trying0utjollifactory
Reply 2 years ago
Im currently interested in building this project,however I'm currently getting the error " Programmer is not responding" so im just curious in what "programmer" did you use in the "tool" selection in the arduino program?
Reply 2 years ago
Since we are using the Arduino Nano, we do not need any programmer to program our Arduino. If you are using Arduino IDE 1.0.6 for program upload, then under Tools -> Board, simply select Arduino Nano w/ ATmega328 and then upload the program to our Arduino board by selecting File -> Upload.
Reply 2 years ago
I've tried to do the steps abovr but i still cant upload it. I've searched around and the usual answers are to check the port in which i cant select it as it was greyed out. I can't even find it in the device managers. Any help? Ive tried all kinds of way to install the drivers and even reinstalling the program
Reply 2 years ago
Your problem probably lies with the Arduino board you are using. You may need to check with your Arduino vendor on how to install the driver for your board especially if your Arduino board is a clone.
jollifactory
2 years ago
Are you using the exact Bi-color LED Matrix modules as in thus project?
