Arduino Powered Haunted Mansion Singing Busts
84,320
229
40
Last year I wanted to put together a Halloween display emulating my favorite Disneyland/world ride of all time. Originally this was just going to be four heads on a table with the Haunted Mansion's "Grim Grinning Ghosts" playing on a loop. But that all changed after I picked up my first Arduino UNO.
After I started learning to program my Ardunio this evolved into a photocell actuated video "on demand" Halloween display. I used an example I found on Arkadian.eu to control a Dell Mini 9 netbook running AutoHotKey. When the photocell switch is tripped the Arduino sends a serial message to the Dell laptop which is converted to a keystroke by AAC Keys which in turn triggers the below AutoHotKey Script and finally plays back using VLC. The "AAC Keys" could probably be replaced by setting up your Arduino as a USB HID but at the time this was all a foreign language to me.
So, lets get to the build!
Step 1: Hardware: Don't Lose Your Head Over This.
Sometimes (OK, lots of times) it's handy to have a retired Electrical Engineer as a father. In particular for this project he was able to provide me with a nice "industrial" photocell switch (just like at Disneyworld!) This ran off a seperate 12v power supply and was really easy to setup on a digital pin of my Arduino (more on that later).
In addition to the switch my hardware list included:
  1. 4 styrofoam heads (found on eBay)
  2. Dell Mini 9 netbook for video playback
  3. A 800x600 VGA projector
  4. Old Karaoke machine for audio playback
  5. Arduino UNO
  6. Radioshack project box to keep the Arduino dry and happy
  7. And the previously mentioned photocell and 12v wall wart
As you can see in the photos I setup the photocell to span the width of my parent's front steps (this would not have worked so well in my apartment...). The photocell wired into a pin on my arduino to register when it was tripped. The Arduino is hooked up to my Netbook over USB and lastly the netbook hooks to the projector and karaoke machine using their respected ports. Then I setup the styrofoam heads and aligned them with the video (more on that in step 3). Whew, ok who's ready for some software?
Step 2: Software: Lets Go to the Head of the Class
Obviously one of the most important parts of this project was the source video. I was lucky enough to find some original recordings of the singing busts from Disneyland on Youtube. You can find the one I used here: "Phantom 4 of 5 Grim Grinning Ghosts". I pulled the video from Youtube and used that for both the video and audio in this project.
As I said in the introduction I primarily used four pieces of software to run this project (all of which are free) they are:
  1. My programmed Arduino UNO
  2. AutoHotKey (Windows macro program)
  3. AAC Keys (Turns serial input into keystrokes)
  4. VLC (video playback)
I also set my Windows background to black and hid the task bar so nothing displayed when the video was not playing.
Here's the code for the AutoHotKey script:
a::
Run, c:\Program Files\VideoLAN\VLC\vlc.exe -I rc "VIDEO_FILE_NAME"
Sleep, 61000 ; Pause for video to play, prevents triggering multiple times.
Process, close, vlc.exe ; Kill vlc and make sure it stays dead.
Return
As you can see it's pretty simple. When the "a" key is pressed VLC is launched with arguments to hide everything but the video itself. The script waits for the length of the video (61 seconds) then it closes VLC to reset and run again.
The Arduino sketch isn't much more complicated it waits until the photocell is triggered, then sends the "a" key to the computer over USB (which AAC Keys turns into a keystroke) and waits for 61 seconds before it can be triggered again.
  Serial Keyboard
 Used to send keystrokes to a Windows PC running AACKeys.exe which
 turns serial data into keystrokes. Best used in conjunction with
 AutoHotKey.
 Examples and idea based on the work of http://www.arkadian.eu and
 information from http://wwww.ladyada.net
TheNewHobbyist 2010 <http://www.thenewhobbyist.com>
// Initialize variables
const int buttonPin = 2;
const int ledPin = 13;
int buttonState = 0;
// Set inpout/output and start serial
void setup() {
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  Serial.begin(9600);
// Main code loop
void loop(){
    buttonState = digitalRead(buttonPin);
    if (buttonState == HIGH) {
        digitalWrite(ledPin, HIGH);
        Serial.print("a"); // send key to PC to start video playback
        delay(61000); // ignore input until video ends
    else {
        // turn LED off:
        digitalWrite(ledPin, LOW);
Step 3: Putting It All Together: Heads Up!
So once you've got your hardware and software all playing nice the only thing left to do it arrange the heads in a trick-or-treater friendly area and wait to BLOW KIDS MINDS. The neighborhood kids seemed to really get a kick out of the display (some coming back with friends to show them). It was a lot of fun and taught me a thing or two about the Arduino.
Halloween Decorations Challenge
Second Prize in the
    • Trash to Treasure
      Trash to Treasure
    • Remix Contest
      Remix Contest
    • Tape Contest
      Tape Contest
    40 Discussions
    Marleen Milligan
    8 months ago
    Question... is the photo cell necessary if I am planning on running it on a continuous feed in a haunted house, not on a motion, light, or sensor based trigger?
    RickyC46
    2 years ago
    DO you have detailed, I mean step by step, instructions on how to do this? I mean down to exactly what to type, where to type it, what and where to download the stuff you need. This is all way to technical, I am in healthcare not tech :( I would love to do this but simply put, it is beyond me unless I have step by step instructions. If you have them would you please consider emailing them to me at shotokahn@yahoo.com
    Ricky
    ChristianE68RickyC46
    Reply 10 months ago
    I use an Epson 2045 pricey but worth it a micca media player playing an HD singing bust video on to coro-plast bust cut out panels,so like hooking up DVD player to TV via HDMI and pressing loop!Best part is most media players are cheap and loop almost as good as computers and they are tiny! Not 3-D but appears 3-D and are big like at Disneyland! https://youtu.be/JH0o49MkOG8 The one i use https://www.amazon.com/s/?ie=UTF8&keywords=micca+speck&tag=googhydr-20&index=aps&hvadid=177165500862&hvpos=1t1&hvnetw=g&hvrand=1268339510811 Projector i use https://www.amazon.com/Epson-Cinema-Miracast-Theater-Projector/dp/B018YKVSMG/ref=sr_1_3?ie=UTF8&qid=1526859160&sr=8-3&keywords=epson+2045 Speaker i use https://www.amazon.com/ION-Audio-Tailgater-Portable-Bluetooth/dp/B00SNBCBGE/ref=sr_1_2?s=electronics&ie=UTF8&qid=1526859200&sr=1-2&keywords=ion+tailgater And HD remastered video the best and most important thing https://youtu.be/a7BmXRf2Dgw
    Homerz2001
    2 years ago
    Projected the video onto panel and then traced it and cut it out looks great!
    propgirrl
    4 years ago on Introduction
    For those that wanted to know, I got mine from www.nightfrights.com, though I see they're also available on haunted props.com. It's the whole neighborhood's favorite effect. Wish I could have pulled it off doing it myself using these instructs, but it was just too hard for my meager skills. Pats on the back for trying, right? I need a prop-building Halloween fan for a boyfriend! LOL!
    propgirrl
    Love it! Nice job!!!
    I gave it my best shot, but couldn't come close to what you accomplished. I ended up getting the pre made Ghost Bust from Night Frights since I'm not as technically skilled as you. It was a little pricey, but SO COOL, it was worth it! It's the hit of the neighborhood at Halloween! Thanks for the inspiration! What's next?
    Naters
    6 years ago on Introduction
    Someone is going to be scared this Halloween! Gonna try this!
    yvettegrmdegiova
    Reply 7 years ago on Step 2
    Use the Firefox browser and search the add ons. Lots of downloaders.
    TheNewHobbyistmdegiova
    Keepvid.com does a pretty good job. You can find other similar services pretty easily on Google.
    U456
    7 years ago on Step 3
    i had the comment and too many wows
    maewert
    7 years ago on Introduction
    This is cool and I copied it with a few modifications. I bought styrofoam heads but used only one, which I had to sand off much of the facial features. I then projected my own face on it.
    lperkins
    You could also use a webcam on the laptop and one of the dozens of pieces of motion-detecting software. Or wire the output of the motion detector into the DTR pin of a serial port on the computer. Both options would be cheaper than using an Arduino as a glorified button-pusher. ;)
    AE8994lperkins
    I investigated this solution and you can use a webcam and freeware motion sensing software called YAWCAM ( Yet Another Web Cam) to trigger an executable. Check it out at http://www.yawcam.com/index.php and look at the help page http://www.yawcam.com/help/help_motion_actions_exe.php for instructions on how to trigger the video for your singing ghosts.
    emerson.johnlperkins
    You are exactly right. Arduinos are really overused, when there are much simpler ways to accomplish the same task.
    If the Arduino is overkill, it is over-engineering, which is not good engineering. I do think I'd like to see a buffer between an external device and DTR on my PC.
    lperkinsemerson.john
    I generally use a small relay to separate the electrical systems from each other. Especially where the voltages involved quite often differ between devices.
