Assemble Your FlipBooKit!
9,942
51
About: FlipBooKit is from kinetic artists, Mark Rosen and Wendy Marvel. They create moving art that tells stories and tickles our sense of nostalgia. In late 2011, their series of motorized flipbooks based on the m...
You've most likely seen flip books before. You may have even made a little hand-drawn thumb flip book of your own. A couple years ago, Mark Rosen and Wendy Marvel created FlipBooKit, these cool kits that assemble into a looping mechanical flipbook box. They come with a default set of animated cards with Eadweard Muybridge's galloping horse (I do not envy that man learning to spell his name as a kid), but you can also make your own animation, which I'll show in an upcoming tutorial.
There are instructions in the box, but this instructable and video are here so you can get a few additional tips and tricks. And in the video you can find some advice for adults who are helping kids assemble a FlipBooKit, as that is a whole different animal than an adult assembling it on their own.
Supplies:
Step 1: Materials and Tools
A FlipBooKit set, which includes:
  • Box
  • Set of Cards
  • Bag of Spindle parts
  • Bag of rivets and piece of double sided tape
Optional (but Super Helpful) Tools:
  • Light-colored marker - such as a silver Sharpie, or white out, or a paint pen, or any other implement that can make a visible mark on black plastic
  • Pencil or chopstick
  • Quarter, Key, or Spoon
  • Key or Popsicle stick
  • Pliers
Step 2: Assembling the Box
In the pictures above, you can see the two parts of the rivets: one side has a smooth-sided, open shank, the other side has a smaller, bumpy-sided shank.
With the logo on the bottom side, fold the narrow flaps flat over. Insert the smooth-sided part of the rivet into one of the holes, which will go through two layers of cardboard, then place the smaller, bumpy-sided part into the other side and squeeze the two sides together.
It is possible to pop the rivets together with just your hands, but there are a few simple tools to make the process easier, such as a quarter, a spoon, or the head of a key.
Follow the pictures above to check out the rest of the folding process. The tapered, triangular ends get folded in over the rectangular flaps to hold them in place. Note that when you put in rivets, they will always go through at least two pieces of cardboard, and often three. This is the point of the rivets, after all, to keep the box's shape.
Step 3: Adding the Flipper
The flipper and page catch make the animation on the cards clearer, and go into that little dip on one of the narrow flaps we folded earlier.
One has two bumps on the back, the other has two holes. It is theoretically possible to attach these two pieces with your hands, if you have really strong hands. If you have trouble, you can use pliers.
If you have small kids around who like to put things in their mouths, the page catch is a potential choking hazard should it pop off. As it turns out, it makes things work a little better, but isn't strictly necessary (flipper yes; page catch, no), so you can leave it out if you want, or you can add a couple drops of super glue to help solidify it.
Expose one side of the double-sided tape square and attach it to the smooth back of the flipper (see pictures). Then you can remove the other side and slide it beneath that narrow flap with the dip. Try to avoiding making contact with the sticky side until it's all the way into place. Tape has this tendency to stick to things, and it'll stick sooner than you want it to if you aren't careful.
Press on the narrow flap to adhere it well.
Step 4: Assembling the Spindle
First, take the two H sections, hold them with the long legs pointing together, rotate one of them 90 degrees and then you can slide the slots together until they're the length of a single piece.
The spindle discs are attached to either end of this, with feet going into the rectangular holes. All of the feet from the H sections need to go in, but only two of them will snap all the way through. Make sure that the axle disc has the flat end on the inside, and make sure that the other disc has the narrow hub going inside (each side has a different size). It's easiest to secure these parts by standing the H sections on the table and gently rocking the disc over the rectangles until they're in place.
You'll notice that the spindle discs have a lot of holes in them. When you insert the cards, it's important for each one to be placed with either ends in the hole exactly across from it. A little trick to make this easier is to make marks at equal points around the disc, using a silver sharpie or similar marking tool. If you follow the edges of the H sections, you can make a mark over the hole that's directly at the end of either side. This will give you a nice, easily visible reference guide.
Finally, insert the axle pin into the little hex hole on the back side of the crank wheel. Placing the axle pin on the table and pressing down on the crank wheel makes it easier to get it all the way in.
Step 5: Putting in the Spindle
Now it's time to insert the spindle. Grab the bushings, spindle and crank wheel. Insert the bushings from the inside of the box into the big holes on both sides. We use these to make it easier for to axle and spindle to spin around, as there is less friction against the smooth plastic than the rougher cardboard.
Place the box with the flipper up, and insert the big axle end of the spindle into that hole. The other end of the spindle lines up with the other bushing hole. This part is challenging, so make things easier on yourself and use plenty of light. To get the spindle aligned in the right place, look through the hole from the outside and shift the spindle until you can see the little hexagon-shaped hole. Then, to keep it in place, insert the axle pin from the outside and press it into the hexagon hole in the end of the spindle. Check the pictures in this step to get a better idea of the process.
Step 6: Punching Out the Cards
Now it's time to punch out the flip cards. These are made with a nice, heavy paper, so they're pretty solid. You'll notice that there are tiny little tabs or sprockets on either side. These parts are still a little bit delicate and you definitely don't want to tear them. It's absolutely possible to punch out these cards by hand, but there are a couple tools that can help keep them intact.
One option is to use a key. Rest the business end of the key on a tab and push down until it pops out, do the same to the other tab, and then punch out the rest of the card with your fingers. Another good tool is a popsicle stick. Use the thin side to support the tab as you pop it out.
Each card is numbered on the top right, so pop out all 24 cards and put them in order.
Step 7: Inserting the Cards
Now it's time to put the cards into the spindle. Remember those little marks we made on the spindle discs? This is where they come into play. Make sure the flipper is on the top side and the crank wheel on the right. Take the first card, and insert the tab on one side into one of the marked holes. You'll need to bend the card a little bit to get the tab opposite into the marked hole right across from it. Once it's in place, flip it down and grab card number two. Place the tabs for this one into the holes immediately above the ones you just used, and flip it down too. Continue with each successive card. Be careful not to skip any holes, or you'll have to go back.
Step 8: Finished!
And that is our FlipBooKit, assembled! Turn the crank wheel counter clockwise, as shown by the arrows on the wheel, and marvel at the animation.
You should know that the box is fairly sturdy, so when a child spins it wildly fast (which they will), the worst damage you're likely to encounter is for some cards to slip out, which is easily fixable.
One of the best things about the FlipBooKit Craft is customizing the blank box. You can color it, add stickers, glue on items, whatever your mind comes up with.
We love to hear about your experiences making these, so stop by the website, Instagram, and Facebook pages to share pictures and stories, and to see what others are doing with their FlipBooKits!
Keep an eye out for additional tutorials about how to make your own animations for the FlipBooKit, and how to throw a FlipBooKit party.
Thanks for reading, and have fun!
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    3 Discussions
    JuanR303
    Question 8 months ago on Introduction
    Hello...what are the dimensions of the box ?
    Thanks
