Atari Punk Stick
9,043
56
12
About: I am currently an electrical engineering student with a passion for all forms of fabrication. And I am working as a finish carpenter.
     The Atari Punk Console is a classic 8-bit noise maker. It is easy to build and requires very few components- ones that are readily available at your local electronic supplier, such as Radio Shack. The problem with the Atari Punk Console is the interface; knobs can be fun but only keep me entertained for so long. A joystick on the other hand is a much more fun and active way to use interface. This Instructable will teach you how to combine the simple design of an Atari Punk Console with the fun interface of a joystick.
     If you would like to know a little more about the Atari Punk Console before you start check out this video from Collin Cunningham, http://www.youtube.com/watch?v=Oi3dmSMpjsU
This article from Jameco also has some useful info. http://www.jameco.com/Jameco/PressRoom/punk.html
Step 1: Get a Joystick
     The Joystick you choose will not only determine how cool your end product ends up being but, based on what is inside it, will also determine the value of some of the parts. So getting and testing the joystick must be the first step.
Finding and Selecting a Joystick:
     Finding a joystick has been fairly easy in my experience. Literally every time I have gone to Goodwill or Salvation Army there have been at least five. They are usually around three dollars. Keep in mind the simpler the joystick the easier it is to convert. Some more complicated joysticks, such as the one on the right in the first picture, actually use an optical system and not potentiometers to track their position. This might be great for a project with Arduino integration but for the purposes of this project its far too complicated. The square shape of the one in the middle made it very easy to mount everything, but it did have a few unnecessary buttons. For this Instructable I will be using the one on the left. It only had one button that did not get used and although the curved shape made it a little hard to mount everything it looks much more sleek.
Testing the Joystick:
     Once you have a joystick selected you will want to open it up and marvel at its simplicity.Once you have finished doing that, you will want to hook up a multimeter up to each of the two potentiometer that the control column (the stick part) is attached to. There will be a third potentiometer not attached to the stick that will be taken out after, as it is not needed. You will want to hook up one lead of the multimeter to the center leg of the potentiometer and one to either of the side ones (polarity doesn't mater here nor does which of the side legs). So far every joystick I have dissectedhas used a 130K ohm potentiometer for both axises but it is worth testing just to make sure. Once you have determined the value you are going to want to remember it because you will use it to determine the value of a second set of potentiometers you will add.
Determining Which Wires are Which:
     Part of this build involves using the original trigger or "fire" switch as a sort of kill switch for the punk console. Since there are two switches on the joystick and we only need one we will want to determine which two of the three wires going into the stick itself we will need to utilize the trigger (my stick only had 3 wires although if your stick has more buttons it will probably have more wires.)
     As long as you have your multimeter out you may as well set it up to do a continuity test and do this now. Hook one lead of the continuity tester up to the black wire and the other lead up to any of the remaining wires and pressing the button you wish to use, if the multimeter beeps, or lights up, or does whatever yours does, you have found the combination of wires you will use for the switch. If it doesn't, keep hooking it up to different wires till it does.
Step 2: Parts and Tools
You will need:
1)
       An old, simple joystick
2)
       A switch (the cooler looking the better just as long as its SPST.)
3)
       A 9v batter clip
4)
       A mono audio jack (I went with 1/8" but you could go with 1/4" if you want to hook it up to a guitar amp.)
5)
       Some hook-up wire (different colors help keep track of things but are not totally necessary, although you should use stranded and not solid as it is much easier to make fit in small places.)
6)
       Resistors
          1K ohm
          10K ohm
          4.7K ohm
7)
       2 Potentiometers (to determine what type you need, you take the value of the potentiometers in your joystick and subtract that number from 470k. You don't have to be very exact with this; I have up to 1m ohm potentiometers and they work just fine if you cannot get it exact, though you will want to go with more resistance as opposed to less)
8)
       Capacitors
          10uf electrolytic
          100 nf (.1uf) ceramic (I didn't have one so I used two .047uf caps; it was close enough)
          10 nf (.01uf) ceramic
9)
       A 556 timer
Not Pictured:
10)
       A proto board (any kind will do as long as it fits in your joystick)
11)
       A 9 volt battery
Tools:
A multimeter
A soldering iron
Solder
A drill
Drill bits
Wire strippers/cutters
Measuring tools (a ruler will work fine)
A rotary tool such as a Dremel
Step 3: Building the Circuit
Follow the diagram and put your circuit together in an orderly fashion. Depending on how much space you have inside of your joystick you may really need to squeeze things together, but I have found that in most cases there is plenty of room. Keep in mind that S1, S2, R1, R2, R3, and R4 are mounted on the case of the joystick and not on the circuit board.
Step 4: Preparing the Joystick
Make Space:
     First I cut off the serial cable that would have hooked up to a computer. I then removed the potentiometer that does not get used. Then I used a rotary tool to take out some of the plastic supports inside of the joystick to make room for the potentiometers, switch, board, and battery.
Drill Some Holes:
You will want to measure your switch, jack, and potentiometers to determine what size holes they will need. If you got them from Radio Shack it will probably say on the back side of the package what size holes you will need.Then you want to determine where you have space on the inside and translate that to the outside and mark where they will go. There is no wrong way to do this just so long as everything fits.
Mount it:
     Once you have the holes drilled you can go ahead and start mounting things.
Step 5: Hook It Up
Now that you have everything prepared, you can start hooking and soldering everything together. I like to start by soldering everything in place that I can before putting the main board in. So you can start by hooking the battery clip to the input and ground of the illuminated switch. Then you can hook the output of the switch up to R1 and R3, and hook R1 and R3 to R2 and R4 respectively. You can also go ahead and solder one of the wires from the "fire" switch to the audio-out jack as well as the ground from the battery. Once you have that done you just need to put in the board you made and hook the X and Y axis series of potentiometers of the audio out to the remaining wire for the "fire" switch, and the 9 volt input to the power switch.
Step 6: Try It Out!
The only thing left now is to put the bottom back on and fire it up. Oh yeah, and have fun!
DIY Audio
Grand Prize in the
DIY Audio
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    12 Discussions
    poofrabbit
    6 years ago on Introduction
    Congratulations on being a finalist in the DIY Audio Contest!! Good luck to you!
    patdoherty
    If anyone in the Chicago land area is interested in using this for live shows or for any sort of music thing I would be happy to give one of these to you (although they are pretty easy to make on your own), all i would ask in return is that you vote on it and that if you do anything with it such as a video or a live performance you let me know.
    nak
    That would be fun for live performance :)
