Attendance Record System (Arduino + RFID)
78,060
104
65
About: Don't be same, be better!
In this project, you'll learn to create attendance system using Arduino and RFID. This project is facilitate to minimize the time to take attendance data and identifying who attend and do not attended.
Basic Skills Requirements:
  • C Programming
  • PHP
  • MySQL
Step 1: Let's Get Started!
Hardware Requirements:
1 x Intel Galileo (You also can use Arduino UNO and other compatible board )
1 x RFID RC522
1 x LCD 16x2
1 x Potentiometer (10k)
Wires and cables for connection
Ethernet connection cable to Router
Step 2: Let's Start Wiring
Connection of RFID to pin Intel Galileo:
Reset = Pin 5
SDA = Pin 10
MOSI = Pin 11
MISO = Pin 12
SCK = Pin 13
GND = GROUND
3.3 = 3.3v
Connection of LCD to pin Intel Galileo:
VSS & RW = GND
Vcc = 5v
Vo = Potentiometer (this is the middle pin of the 10k potentiometer)
RS = Pin 9
E = Pin 8
D4 = Pin 7
D5 = Pin 4
D6 = Pin 3
D7 = Pin 2
If not understand not clarify with the connection, please refer the image above.
Step 3: Time for Arduino Code
Download the code below and run. Verify, Compile, and Upload.
If the Arduino is wired and working correctly the LCD will display IP Address that connected to your Internet.
Download Here: bit.ly/1E9kTj5
*Libraries are attached together
Step 4: Time for PHP & Database
PHP Code:
Creating a web PHP for data(time) inserting or updating to database. Here, this code will compare the serial on card and on database.
You need a card or tag to access the attendance system record. When approaching the card / RFID tag for sensor, the serial number of this card / tag is detected and compared with the serial numbers listed on the database. If it is registered serial number, the system will send card series to the database. LCD will display, and success send messages will appear on the LCD display. If not , the system will ignore the user access and data transmission on the LCD will show a warning message card is not recognized.
*Upload the arduino.php file of your web server.
Download PHP: bit.ly/1EQRMjt
Creating Database:
Create a Database on your web hosting server and Table as I shown on the image above.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    65 Discussions
    tahiraishaamberrayh
    Reply 2 years ago
    hi bro i am a student i need this project for semester project please gives me complete documentation of project with codes
    LinkFaker
    3 months ago
    Dear author, could you email me the codes you used in makin the system, just gonna use it and add new things for our research.
    Email: ja.yrastorza@gmail.com
    Benjamin Utengye
    Question 4 months ago on Step 4
    How can i modify this project to be examination attendanc for my project
    nyowinh
    Question 7 months ago on Step 3
    please, would you send source code ,i want source code.
    tintin1
    Question 8 months ago
    how to insert scanned details from rfid into mysql
    dee910620
    1 year ago
    Error compiling for board Arduino.
    How can i solve this?
    dee910620
    1 year ago
    Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_841079 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_980846 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -verbose C:\Users\User\Downloads\Coding\Coding.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_841079 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_980846 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -prefs=runtime.tools.avrdude.path=C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -verbose C:\Users\User\Downloads\Coding\Coding.ino
    Using board 'uno' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
    Using core 'arduino' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
    Detecting libraries used...
    "C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "C:\Users\User\AppData\Local\Temp\arduino_build_841079\sketch\Coding.ino.cpp" -o "nul"
    "C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\SPI\src" "C:\Users\User\AppData\Local\Temp\arduino_build_841079\sketch\Coding.ino.cpp" -o "nul"
    "C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\SPI\src" "-IC:\Users\User\Documents\Arduino\libraries\rfid-master\src" "C:\Users\User\AppData\Local\Temp\arduino_build_841079\sketch\Coding.ino.cpp" -o "nul"
    "C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino" "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\standard" "-IC:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\SPI\src" "-IC:\Users\User\Documents\Arduino\libraries\rfid-master\src" "C:\Users\User\AppData\Local\Temp\arduino_build_841079\sketch\Coding.ino.cpp" -o "C:\Users\User\AppData\Local\Temp\arduino_build_841079\preproc\ctags_target_for_gcc_minus_e.cpp"
    C:\Users\User\Downloads\Coding\Coding.ino:21:21: fatal error: pitches.h: No such file or directory
    #include "pitches.h"
    compilation terminated.
    Using library SPI at version 1.0 in folder: C:\Users\User\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\SPI
    Using library rfid-master at version 1.3.6 in folder: C:\Users\User\Documents\Arduino\libraries\rfid-master
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    bilal shahid 228
    1 year ago
    hello sir/mam please send me the whole project documentation
    ranabilalshahid228@gmail.com
    plzzzzzzzz
    Nosheen Fatima
    1 year ago
    please send me its complete code and circuit diagram..
    my mail id is fatimanosheen7863@gmail.com
    Saifiiz artWorkJosogeorge
    Reply 2 years ago
    i figured it out how to work with UNO.. it needs lots of changes. i got the PHP and Mysql working and Cards are working smoothly. I will do my instructable on it.
    SitiB3Saifiiz artWork
    Reply 2 years ago
    hi, can you please send the schematic and code to me too? it would be really helpful thank you in advance may god bless you :)
    email: syirah_2010@hotmail.com
    BeansinghSaifiiz artWork
    Reply 2 years ago
    hey can u send me the schematic and the code...i want to make a similar project. i want to make a databse of 60 students and store there daily attendance.
    my email id- say2deepaksingh@gmail.com
    thank you
    tahiraishaSaifiiz artWork
    Reply 2 years ago
    hi bro please help me in that i want to complete my final year samester project plz gives me documentation and code
    tahirmuhdiuldin64@gmail.com
    AbhinayR
    1 year ago
    hey bro!
    would you like to please send the full code bro.
    gmail-abhinayraj1226@gmail.com
    Iyanuoluwa
    1 year ago
    Please, can u send the schematics and the code. I need it for my final year project. Thanks
    Email: fadugba.iyanu@gmail.com
