Audio Amplifier Using TDA2050 32 Watt
7,885
35
8
Audio amplifier using TDA2050 IC max output of 32Watt
Supplies:
Step 1: Components List
2xLed
2x1K Resistors
2x22k Resistors
2x1000uF Capacitor
1x2 Ohm Resistor
1x0.47uf Cap
1x20K Potentiometer
1xTDA2050
1xBridge Rectifier
Step 2: Power Supply
The circuit uses a dual power supply to build the power supply use a 12V 5Amp transformer which gives a output of +12 And -12 Volt
Step 3: TDA2050
The IC gives a maximum power of 32Watt at 4ohm use a heatsink for the IC it gets very hot while in opration
Step 4: Circuit Diagram
Use circuit diagram to build the circuit you can also build this circuit on breadboard
Step 5: Stereo Use
For stereo application you can build a same copy of this circuit for the other channel
Step 6: OUTPUT
use a box enclosed speaker at output it gives a better bass output
Step 7: Sound Test Video
Step 8: Building the Circuit on Zero PCB
For a good connection than breadboard we can build this circuit on Zero PCB
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    8 Discussions
    baotrangl
    2 years ago
    AD?
    my amplyfier used TDA2050A are buzzing. please tell me the cause?
    CircuitTodaybaotrangl
    Reply 2 years ago
    Check for any shorts.if its ok try adding capacitors to the power supply
    DakuluD
    3 years ago
    The ori version of TDA2050 has been discont...on 2012..Right now only the clone of TDA2050 on the market...This clone version 25W only..The ic protection not guaranteed 100% work.3A max...nomore 32W TDA2050 now...
    For the price...on my country...TDA2040 $12.50 .... TDA2050 clone only $7.45..
    TDA2040 more stable on low voltage .
    CircuitToday
    3 years ago
    Here In India It Cost 50 Rs
    1001abhar
    3 years ago on Introduction
    hello sir, can you please tell to me what is the cost of TDA2050 ic ? thank for the reading.......
