Auotmatic Street Lights Control Using LDR and Arduino
92,378
41
18
Automatic street light control is used to control the street lights(Turn on and off based on the light).
Here we make use of LDR(Light Dependent Resistor) and LED(Light Emitting diode) and arduino.
Hard Ware Components Required:
1) LDR
2)LED
3)4.7k Resistor
4)Bread Board
5)Connecting wires
6)Arduino
LDR is used to detect the light, Arduino is used to on/off the Light.
For LDR Basics and Principles Please go through the below link.
http://www.electrical4u.com/light-dependent-resist...
For LED interfacing Please follow the below link.
https://www.instructables.com/id/LED-blinking-using...
Hardware Connections.-
Arduino 3rd pin connected to LED +ve
Arduino GND connected to LED -ve through 4.7k
Arduino +5v is connected to LDR One End
Arduino A0 pin is connected to LDR other end
Arduino GND is connected to LDR other end with 4.7k
Arduino
Supplies:
Step 1: Programming, Compiling and Uploading to Arduino
// Program related to LDR and LED interfacing to Arduino
#include <SoftwareSerial.h>
int sensorPin = A0; // select the input pin for the LDR
int sensorValue = 0; // variable to store the value coming from the sensor
int led = 3;
void setup() { // declare the ledPin as an OUTPUT:
pinMode(led, OUTPUT);
Serial.begin(9600); }
void loop()
Serial.println("Welcome to TechPonder LDR Tutorial");
sensorValue = analogRead(sensorPin);
Serial.println(sensorValue);
if (sensorValue < 100)
Serial.println("LED light on");
digitalWrite(led,HIGH);
delay(1000);
digitalWrite(led,LOW);
delay(sensorValue);
Copy and Paste the code in arduino new sketch folder later compile and upload the program as show in the images.
Please click on serial window, which is located top right corner of the Arduino IDE to view the results.
Step 2: Results
Results are displayed on the serial window.
When there is low amount of light the light automatically glows and when there is sufficient amount of light it automatically turns off the light.
Here based on our room condition the threshold value we took is 100 for the LDR sensor.
When we place a hand on LDR(Not allowing any light on LDR) arduino automatically turns on the LED.
When we remove our hand on LDR. Arduino automatically Turns Off LED.
Thanks,
TechPonder.
2 People Made This Project!
  • Party Challenge
    Party Challenge
  • IoT Challenge
    IoT Challenge
  • Classroom Science Contest
18 Discussions
manjuKR
Question 7 months ago on Introduction
led not glowing what to do please tell asap
ramesh798
9 months ago
tank you for sharing information :)
i found one web page it also give good info about diode
more about ldr
OulkarRD
Question 1 year ago
Sir please send me advantages and disadvantages and applications and circuit diagram of this project
OulkarRD
Question 1 year ago
CGA1
1 year ago
thanx for sharing information with us
Addssingrox
Question 1 year ago on Step 2
What if we increase or decrease the threshold value of the LDR
Addssingrox
Question 1 year ago on Introduction
What if increase or decrease the threshold value for the LDR
npawar
1 year ago
In Auotmatic Street Lights Control Using LDR and Arduino I want to make it for 3 LEDs so , what should I do ?
What will be circuit diagram ?
What changes should be done in Program ?
suseeln
1 year ago
pllzee give the circutr diagram
GirivardhanV
1 year ago
can the connections be shown properly..please....
Kevin SunnyT
2 years ago
GUYS CAN ANONE PLS TELL ME HOW TO MAKE A BUZZER RING WITH A ULTASONIC SENNSOR AND LDR TOGETHER. I MEAN BUZZER SHOULD RING WHEN TRIGGERED BY LDR OR ULTRASONIC SENSOR
ULTRASONIC SHOULD TRIGGER WITHIN 2 M
AND LDR WHEN LASER IS REMOVED
PLS PLSPLS CN U HELP ME WITH THIS THIS IS URGENT
Ashworth3271
2 years ago
What if I have more than 1 streetlamp and will like to have delays in all ?
YashK31
3 years ago
Can you please explain the wiring for this project. The circuit diagram was a little confusing about the input/output jumpers
ArbabA1
3 years ago
thanks Good JOB...Keep it up and shares such types of Project circuits..
TechPonderD6equj5
Reply 3 years ago on Step 2
To my knowledge its correct, If u have any changes please let me know.
elelor
3 years ago on Introduction
I think you need to know more about other electronic devices, i found site where i read about diodes etc.
http://911electronic.com
