Automatic Lights for Tool Chest
24,484
340
24
About: Engineer by day, mad scientist by night.
You know how you open the fridge and the lights are just on? That's cool and I want that in a lot of other useful places - Like my tool chest. So now I have it and I'm going to show you how to do it too!
This project covers adding LED lights to each drawer of a tool chest—so that it will automatically turn on when the door is opened, and turn off when it's closed. The tool chest I have are Craftsman tool chest. All the dimensions I'll mention are related to a standard Craftsman tool chest.
I have some basic projects tools so the only cost for this project was the material cost. I needed LED Lights, Battery Packs and a switch to turn things off and on. This project cost me about $30 in new materials your mileage may vary depending on your tools and deals you can find on the parts. We'll cover all the parts and pieces in the next step.
The mystery of the fridge lights being on or off when the door is closed is solved in this project. Quick Note, this Instructable isn't as long as it looks. Some steps are just extra information and you can skip the mini physics lesson and skip right to building!
Enough about the why, lets get into the how!
Step 1: Things You Have, Things You Dont
There are some things you may already have and some things you would need. I also used a 3D printer to print some custom brackets; I'll supply the file and dimensions I used if you have one.
Things you may have (basic project tool pack):
Scissors, Tape, Soldering Iron, Solder, helping hands soldering station, electrical tape, wire cutters, some wire (anything will work here, I used leftover wire from another project), needle-nose pliers, caliper.
If you don't a caliper, you can get a good digital one from amazon or Ebay for like $10. I highly recommend one for projects like this to have an easy to read caliper.
Things you probably don't have:
These are the LED Light strip I used. ($8 Amazon Prime)
Amazon: LED Light Strips
You could always get some waterproof ones also (for not much more)
(Optional) Amazon: LED Light Strips - Waterproof
Microswitch aka limit switch. ($10 for qnty 20). I installed my lights on 10 drawers but you can never have too many of these for other projects.
Amazon: Limit Switches
LED Light strip Easy Connectors (Optional - $6 for 10, cut in half will make the 20 needed for 10 drawers)
(Optional) Amazon: LED Strip Connectors
Battery holder. The battery holder you pick will really be a function of how long do you want to go between changing batteries. Since we will be cutting this to roughly 18 inch segments for each drawer, the amp draw is low. I picked these 6xAA holders but there are other options here (including using rechargeable packs). More on this later.
Ebay: 6xAA Battery Holders
Regarding 3D printing part the brackets If you don't have a 3D printer don't buy one just for this project, buy one because they are awesome. But, if you're not going to get one (you should) just use Moldable plastic instead of buying a 3D printer (which you should).
Amazon: Modlable Plastic
Step 2: LED Light Strips - Tool Chest So Bright I Gotta Wear Shades
The key here is the low cost, low power consuming and easy to use LED Light strips.
If you haven't used these things before you have been missing out. These things are pretty cheap and can be installed in a wide range of uses. I've installed these lights in my kitchen for under cabinet lighting, in my car for lighting up hard to see spots, and outside (weather proof version) for mood lighting for parties. Once you make a project with these kits you'll be hooked on them.
First thing to know is that the majority of the ones you can buy online are able to be cut into small segments at the indicated marks (typically 3 or 4 inches apart).
For this project I bought a 16 ft strip (standard size) and cut them into 9 inch segments. Doing this gave me 20+ 9 inch segments. I used one 9 inch segment on each side of each drawer resulting in 2 segments for each drawer. This works out to 18 LED lights in each drawer.
Once cut at the noted location, you can use the wire clips you buy, or solder wire directly onto the strips. The first time I used these I used the clips I bought online. They tend to suffer from movement over time and will eventually become a bad connection. I know it seems intimidating but soldering them isn't that hard, just take your time and make sure you have a good connection. I'm not a soldering expert but luckily there are some good instructables by other authors on that subject. If you need some assistance, I'll wait why you go read one of those. Go ahead; I'll be here when you get back.....
Alright, when you have all your sections cut up we can move onto a mini physics lesson, wiring and testing.
Step 3: 1.21 GigaWatts!
No not really. You won't be traveling in time, so you don't need that much.
There are two concepts you don't need to know, but here is some info in case you’re curious. The two concepts are Voltage (V) and milliAmpere hour (mAh). I'm going to make a lot of assumptions, so don't get to nit picky here. This isn't a physics lesson as much as a high level overview. I'll keep the math very simple, or you can just skip to the next step if you don't care lol.
Voltage is the electrical force required to run a circuit. You can think of this in terms of mechanical force like this, to lift a 100lb weight you have to supply a 100 lb force. To run a 12V circuit, you need to supply 12 Volts. It can get deeper than that, but let's keep it simple shall we?
An Ampere (commonly called Amp) is how much current is required for operating, and an Amp Hour is how long you can supply that amperage. Think of it like this, if you have a 10 cups of water and it has a hole it in that leaks 1 cup an hour it would take 10 hours to empty. The 10 Cups here would be your potential miliAmp hours from your batteries and the leak (cups per hour) would be your milliamp hour draw from your circuit. Same thing with amps, if you have a 700 milliamp battery (typical AA battery is something like 2500 milliamps) and your circuit draws 100 milliamps per hour, you could run your circuit for 7 hours 700 / 100 = 7. And yes 0.7 Amps = 700 milliamps.
Let's chat batteries for a second. The light strips are rated for 12V. A single AA battery is 1.5V. My Battery packs are wired in Series (that means the V- of one battery goes to the V+ of the next), so to determine the voltage for the pack multiple your number of batteries by 1.5V. For 12 volts, you need 8 AA and that's starting to get a little big. For this project I used 6xAA which results in 9V. The LED strips can operate at 9V (I think that's the minimum) they are just slightly dimmer than if it was 12V supply.
Updated (thanks to Galah for the correction):
When connected in series Amperage does not add like it does for Voltage. Each battery is roughly 2500 milliamps hour and when connected in series the amperage hour remains constant as the increase in number of batteries is going towards boosting the Voltage.
The light strips I bought were 12V and 20 Watts. I'm only using 9V so i'll use 9 instead of 12 in my calculation. To calculate amps use Amp = Watt / Voltage. 20/9 = 2.22 Amps for the entire light string. I cut mine into 20 pieces (and used two per door, so i have 10 final sections). That results in 2.2 / 10 = 0.222 amps or 222 milliamps for each drawer.
My AA batteries are estimate to have about 2500 mAh and the theoretical draw is 222 milliamps. Some simple math and I estimate that I can run the lights for roughly 10 continuous hours without replacing a battery (2500 mAh / 222mA = 10 Hours roughly). I used my multimeter to measure a few drawers and I found my consumption closer to 150 milliamps. Various light strips will be different so will different batteries but when I use tools my drawers are open only a few mins at a time so I expect the batteries to last a pretty long time.
Bottom line, battery packs are cheap and provide plenty of time running these lights. Moving on...
Step 4: Wiring and Testing
The wiring for this project is pretty straight forward. We are dealing with low voltage so any low voltage wire is fine. Big Box Stores sell low voltage 2 wire landscape wire which works great, or any other project wire you have will be fine too. I prefer solid core wire instead of braided wire for a few different reasons but the most important here is how easy it is to solder. The wire selection isn't that important do to the small length and low voltage. Your best friend at this step is testing, testing and retesting. Every time you solder something test for conductivity. Before you wrap anything up for good, make sure it works. Test, test and retest.
The wiring schematic might look scary but it's actually very simple. The battery pack has a V+ and V- (common, ground, neutral.... whatever you want to call it for this purpose). Those names for V- aren't truly interchangeable but for the purpose of this Instructable we can use them that way since the idea is that they are just for completing the circuit to the battery. I'm not a "sparky" (Electrical Engineer) so i'll let them point out the minutiae difference to me in the comments.
First, you need to measure the distance fro the desired location of the LED to the Switch. Measure along the inside of the perimeter wall of your drawer. You should be measuring where you want to run your wire and where it will be easier to hide it. You'll need to cut this much wire for each LED plus 1 - 2 inches for wire stripping and to make installation easy. Once you have those sections cut, strip the wire on each side.
One side of the wire should be soldered to the V+ and V- of the LED strip directly (note the picture of what this should look like). Make sure you note which wire is on the V+ and which is on the V-. It's helpful if the wire you use is two different colors or is someway marked. Do this for both LED segments for your drawer.
Cut some wire for running your battery pack from the switch all the way to the front of the drawer (straight down the middle of the drawer). The reason for this is to give you plenty of slack for replacing the batteries at some point in the future without disrupting anything. Solder the wire to your battery pack and note the V+ and V- connections.
Take the V+ wire from both LED's and the V+ wire from the battery pack and solder together.
Take the V- wire from the battery and solder on a female wire connector.
Take Both the V- from the LEDs and solder them together into a separate female wire connection.
At this point put batteries into the battery holder, and touch the two female connections together to test all soldered connections. Test, test and retest. You should get light, if you don't recheck all connections. Once you are satisfied with your pretty spectacular solder job, electrical tape (or heat shrink if your fancy) all solder exposed joints to prevent a short circuit or shock later. After this check for conductivity again, touch the V- sides together to complete the circuit and verify you didn't mess anything up.
Time to add some smarts to the light. Moving on to the magic in the tool chest.
Step 5: Don't Limit Yourself, Limit the Light
You may or may not know about micro / limit switches. You run into this switch all day long without realizing it. A typical application is to know if some movement has occurred. This could be your car door opening (to make the lights turn on), a position valve in power plant control, or any number of applications. This is the secret switch helping to automate all sorts of things. These switches are often used for their high reliability, quick switching and high tolerance precision for applications like ours here. This switch is the perfect application here for our tool chest. BTW, for more information check out this instructable about all types of limit switches and applications. If you don't care about more detailed information on the switch skip down to the bold part that talks about the using it.
Limit Switch Instructable
There are 4 main parts to the switch we care about here: Rocker Arm, Common Leg, NC Leg and NO leg.
I'll start with the part where people are like what??!?!? NO and NC. This stands for Normally Open and Normally Closed, and while the name sounds weird is very descriptive of what it does.
Normally simply means the at rest position. If you put the switch on your table just sitting there doing nothing, that's the normal position. Closed is a Closed circuit and open is an open circuit. A closed circuit allows current to flow, an open one does not.
So when connected to the NC (Normally Closed) we have current flow without needing to do anything to the switch. When connected to the NO (Normally Open) we do not have current flow without doing something to the switch.
Rocker arm is the metal arm outside the red and black box that comes into contact with something moving. The movement of the arm is attached to the internal switch and changes the contact point internally from NC to NO. When the rocker arm is engaged the Limit Switch is no longer in the normal position. Understanding this operation isn't critical, just realize the arm moving change the contact point from NC to NO for the circuit.
Common leg is the portion of the switch that is always in the circuit. This leg should always be connected to a circuit.
OK done with the terminology explanation so lets not talk about how it works and instead how we'll use it. We will be connecting the V- from the battery to the Common leg of the Limit Switch with the female wire connector solder on during the last step. On the NC leg we will be connecting the V- from the LEDs wire connected soldered on during the last step. I took apart one of my switches for the purpose of this Instructable so you could see what is going on inside. You can see without the case on that there is a lever across the Limit Switch that connects to the NC without the rocker arm engaged, and pops over to the NO when the rocker arm is pressed. An internal spring resets the switch when the force to close is removed.
When we connect to the NC and COMM we have a complete circuit without the switch pressed. We use it this way because when the drawer is open, the pressure from the back wall is no longer on the switch, it goes back to its normal position (drawer open) and the light comes on. When we push the drawer closed, the limit switch makes contact with the back wall and opens the circuit disconnecting the lights from the power source.
Once you make this connection, you should again power up the battery compartment, and test the switch is working as expected: lights ON when nothing is pressed, and lights OFF when you squeeze the rocker arm closed. If you pass this quality step, move on to making the bracket for this guy!
Step 6: 3D Print a Bracket (3D Print Optional)
I know I know, most people are like I don't have a 3D printer, how am I going to do this?
Like I mentioned in the materials list if you don't have a 3D printer get some moldable plastic and make a bracket. I haven't used it before, I know many people who swear by this being a great alternative to an expensive 3D printer.
For those with a 3D printer the attached STL file will print 1 bracket, so print as many as you need. This project calls for 1 bracket per limit switch and the attached file works perfectly for the limit switches I call out in the materials as well as fit perfectly on a craftsman rear panel.
These brackets are pretty small and don't require a lot of material. I printed mine using the Windows 10 printing software with Medium Density and Medium resolution. Since they are pretty small, even a medium density gives plenty of strength.
The support that pushes into the limit switches are 3mm and can snap if even pressure isn't applied. (Sorry for switching back and forth between English and Metric but for the small stuff metric is better than fractions of an inch.) Push the limit switches firmly with equal pressure on both sides to avoid snapping a support. Make sure aligned properly so that the side with the switch extends over the edge towards the backside of the drawer. Refer to the attached picture for properly alignment so that you have good contact for the rocker arm to the rear panel of the cabinet frame. You should test fit with your particular cabinet so that when the drawer is fully seated, you have good contact with your limit switch to engage the rocker arm and close the switch. I'll load the design file as well as the print file so you can tweak it if you want.
This is a time to test and test and retest. Put your light package in your drawer (just place it in there) and affix the limit switch to where it's final position will be. With the drawer open the lights should be on, with it closed they should turn off. If all that works, continue on to final installation.
Step 7: Install Aka Use Tape to Hide Wires
My cabinet is black, so I used black duct tape so all wiring disappears. You can use any tape you want, I liked the clean look of Gorilla Black Duct tape.
Side not here, do you say Duct or Duck tape? I think both are correct, but when typing it up you realize that perhaps you use them interchangeable? The real funny thing is Duct tape was originally made for using on heating and cooling ducting (hence the name) but really shouldn't be used in hot attacks since the glue wears off and isn't really effective. Duck tape came from WW2 for use on Duck cloth, again hence the name. I think they are the same? End side note.
There isn't a wrong way to do this. Well, as long as you achieve the goal of securing and hiding the wires. If you tape your drawers closed, I would say that is a wrong way. You can look at my images for how I did it, but get creative here and put your mark on it. You do you here.
Tape from the light to the switch and make sure you leave the battery pack accessible. It's tape, probably over kill giving it its own step. Moving on.
Step 8: Final Product
First and Foremost I want to thank Edison and Oleg Losev. Without you guys this Instructable couldn't have been written.
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light - Plato
Tada, light! Hopefully this project was easy enough to follow. This was my first of hopefully many Instructables, let me know how I did in the comments and share your pictures of you making this!
Enjoy!
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    24 Discussions
    Matthew_Fiero
    11 months ago
    Has anyone thought of an idea to eliminate the battery pack? These LED strips can plug into a wall socket with a transformer. Any ideas how to run the wiring from each drawer to a transformer stored in one location? I would see the moving drawers being a problem as they would have to have room to flex/recoil/retract somehow...
    The Sam DMatthew_Fiero
    Reply 11 months ago
    Hey Thanks for reading and the comment.
    I toyed with the idea of using a transformer and running it into a socket like you mention. The man reason I didn't do this was my tool chest like many others would require holes to be dripped in it to run the wire. I wanted to modify this as lightly as possible, so I elected for battery packs.
    Now, I wrote this Instructable about two years ago and I use my tool chest pretty frequently and I can now attest that the batteries in this configuration last just about two years.
    In fact, I replaced some while they still produced power because of how long they were installed and I didn't want them to start leaking.
    Thanks for reading!
    The Sam Dyrralguthrie
    Reply 2 years ago
    Possibly, I picked the limit switch due to it's compact layout and reliability. Between the drawers in most cases there is very little room. In my case I had about 11 mm (~0.4 inch). I didn't want to modify the drawer itself (drill a hole to mount this type of push button), so I created the bracket to mount on top.
    One could easily change out to a momentary push button. The key is for the button to be momentary, be small enough to fit inside the clearances and be able to firmly open the circuit with the drawer closed. I don't see the dimensions on this particular button, but I have a similar one on my desk and it's right in or above the 1/2 inch envelop.
    One thing I've also come across are momentary buttons are typically a little more expensive (repetitively speaking of course). They will run you in many cases about $1 each (your link is $1.10 each) and the limit switch was about 50 cents each. Push button would have increased the cost by $5 without adding any additional value.
    The other thing I liked about the limit switch was the wire connectors. Buttons like you linked have leads you can solder too which is completely fine. BUT, I preferred the wire connectors so I could replace in-kind easily if a switch were to become damaged without having to solder things back together. Using a female wire connector makes for easy service if required. Since the switch (or button) is the moving part and most likely fail point, it's good practice to make future service considerations a priority. The limit switch and service considerations are certainly overkill, but when it's a cheaper option it just makes sense.
    Thanks for reading!
    yrralguthrieThe Sam D
    Reply 2 years ago
    Might actually lower the cost since no separate led and wiring might be needed. If the light from the indicator is enough.
    Reply 2 years ago
    I don't think so. Those Light up switches while "bright" are essentially a single LED inside a diffuser. Also, the only practical application I can see is an interference setup like I used. By that I mean, when the drawer is closed the contact of the back wall changes the circuit from closed to open. Since the only part of the setup with relative motion to the drawer is the back wall it is the ideal switching mechanism. From the perspective of the lights, the drawer isn't moving and the back wall does.
    If you mounted that button in the back of the drawer you would have 2 issues: 1) light to far from point of use and 2) the button itself is the light and to operate in my design the light source itself would be pointed away from the user i.e. pointed at the back wall.
    The LEDs I used have 3 LEDs per segment, and 6 segments were used in each drawer. This results in 18 LEDs in the drawer which is actually a good amount of light. It's beight enough to be useful without being blinding.
    The button you linked is a great button, not a good application here.
    CheesesOfNazereth
    2 years ago
    I like the Timbuk 3 reference !
    Also this is actually an I will do!
    Don't worry about the people who say to light your work area better- they have never worked on a flightline or in the field. You can just tell these things. I have a little crafstman portable box with 3 drawers this will be handy for, and I think I have almost the same roll around set as you, and when I have it at the door of the garage at night I have to put a light on it because you can not have a light on ceiling that will illuminate through the garage door that is rolled up, right?
    The Sam DCheesesOfNazereth
    Reply 2 years ago
    Absolutely. I understand that there a lot of solutions to various problems.
    I wrote this to share a neat idea I came up with one late night searching my tool box for a socket. I know more light is better, and if everyone could they would install a lot of light in their garages. However, I understand that isn't a pragmatic approach. Often times people can't afford to tie up a ton of money in shop lights especially those out there that tend to me on a casual user side. If you work in a commercial shop this might seem silly, but for the other 99% of readers with a typical garage setup, this is a perfect cheap effective approach to adding light at point of use.
    All that said, when you install this in your tool box and show it to your buddies, your going to show it off. Some times projects like this are just cool and that's plenty of reason to make it if you ask me.
    Thanks for reading!
    pfred2
    2 years ago
    I have to ask, why don't you just adequately light up your work space?
    marco!pfred2
    Reply 2 years ago
    in most shops i've been in, the lighting is focused on the workspace, while tool storage is off to a side for space reasons. but in any case, this is just cool as hell to have!
    Kraeikmarco!
    Reply 2 years ago
    this was exactly my thought as well marco, my bench is lit up like the sun but I don't really allocate any of my overhead lights to light up my tool box. I just use the bleed from the main lights. I think this would be a great idea to help some of us older eyes from missing things in our kits.
    JmsDwhmarco!
    Reply 2 years ago
    And it's a way to add the nicer features of newer, higher end tool boxes to one that didn't originally come with it.
    The Sam Dpfred2
    Reply 2 years ago
    Of course I do. My work does have good lighting, however I do believe more light is always better. Also I know this is an issue for a lot of people who can't light their work area as effectively as they would like. A quick google search will yield a lot of people asking for a solution. And one that's automatic? Come on.....
    But as Marco so effectively stated below, because it's pretty cool for 30 bucks.
    MattakadeimosThe Sam D
    Reply 2 years ago
    Ah don't listen to the doubters, this is an awesome idea and one I'm gonna impliment. Gonna use LiPo batteries and a charge port so I can go mobile with mine. :)
    pfred2The Sam D
    Reply 2 years ago
    like a fan with spinning lights? Or ground effects lights for cars? Some folks go in for that sort of thing. You won't see any of that here though.
    The Sam Dpfred2
    Reply 2 years ago
    No, but how about under cabinet lighting in the kitchen? Or extra lights for a truck bed? Or easy flexible lights for a tent? So many uses for these Led lights hooked to a low voltage supply or battery packs.
    Thanks for reading!
    ElectroFrank
    2 years ago
    In step 1, you put "need noise pliers", but (with a little lubrication) could this be "needle nose pliers" ?
    The Sam DElectroFrank
    Reply 2 years ago
    I'm an engineer, therefor I'm required to be a terrible speller lol.
    Fixed. Thanks for reading and catching that!
    ElectroFrankThe Sam D
    Reply 2 years ago
    I'm a technician, therefore I'm required to sort out the engineer's glitches !
    galah
    2 years ago
    Hi
    Just correcting your battery pack calculation. As the batteries are in series, you get more volt, but the same number of AH as a single battery.
