Arduino Automatic Milk Feeder
1,926
37
6
About: Electronics and Automation Engineer, Game designer, Artist! EMAIL: amaraxr@gmail.com
When puppies are born they are wrapped in a clear sac called the amniotic membrane. This membrane must be removed from the puppy’s face in order for it to breathe.
Once it is cleared it will start crawling towards its mother,
About First milk :- Colostrum is the milk that the mother produces the first days after birth. It is very thick, yellowish-cream in color, and rich in antibodies that protect the puppy against disease. Puppies that do not drink colostrum during their first 12 -14 hours of life can not fight the diseases and bacteria they encounter as well as pups that do.
How Much Milk Should I Feed?
That is a very difficult question to answer because puppies arrive in so many sizes. Experienced breeders generally decide when to stop feeding based on the shape of the puppies stomach and its greediness to continue feeding rather than by giving a set amount of formula.
But I can give you some idea: When the powdered formula I suggested is mixed according to directions (one part formula powder to two parts water) ; each day the average puppy needs 25-35 milliliters of formula for every 100 grams (about 3.5 ounces) of body weight. Divide this number by the number of feedings per day to obtain the amount for each feeding. During week two, give 15-20 ml for every 100 grams body weight. During weeks three and four give 20 ml for every 100 grams body weight. These amounts are always only a rough estimate. Feed the puppy until its belly is gently rounded or pear-shaped - never more. As long as it is slowly but steadily gaining weight, everything is fine.
How Often Should I Feed ?
Feed very young puppies every 2-3 hours or six to eight feeding a day. Some people get up to give their puppy a midnight feeding but this is not necessary if you have a vigorous ,healthy pup.
Supplies:
Step 1: VIDEO OF SWITCHING PUMP
I HAVE USED CUSTOMIZED ARDUINO IN THIS VIDEO , DONT WORRY THE CODE WORKS FOR ARDUINO UNO WELL ,
Thank you !! write some words so that I can correct my mistakes from next project !
Step 2: About Milk Feeder
If you are a Puppy/kitty owner, going on vacation can be stressful. Usually, you need a friend or neighbor to come over everyday and feed your pets. However, by enslaving robots you can keep your pet happy and enjoy a stress-free holiday.
Today, we make an automatic milk feeder from Thermocol Box,12V water pump,Relay board, IR sensor box, an LED and an Arduino.
Step 3: Things Needed
1) Arduino uno - 1nos
Arduino is an open-source computer hardware and
software company, project and user community that
designs and manufactures microcontroller -based kits for
building digital devices and interactive objects that can
sense and control objects in the physical world.
The project is based on microcontroller board designs,
manufactured by several vendors, using various
microcontrollers. These systems provide sets of digital and
analog I/O pins that can be interfaced to various expansion
boards ("shields") and other circuits.
The boards feature
serial communications interfaces, including USB on some
models, for loading programs from personal computers. For
programming the microcontrollers, the Arduino project
provides an integrated development environment (IDE)
based on the Processing project, which includes support for
the C and C++ programming languages.
it controls the whole process gives signal to the water pump and milk pump to switch on and switch off.
2) 12v Submergible pump - 2nos
This is used to pump water and milk to lift it from water and milk compartment .
A submersible pump (or sub pump, electric submersible pump (ESP)) is a device which has a hermetically sealed motor close-coupled to the pump body. The whole assembly is submerged in the fluid to be pumped. The main advantage of this type of pump is that it prevents pump cavitations’, a problem associated with a high elevation difference between pump and the fluid surface.Small DC Submersible water pumps push fluid to the surface as opposed to jet pumps having to pull fluids. Submersibles are more efficient than jet pumps.
Working principle:-
The submersible pumps used in ESP installations are multistage centrifugal pumps operating in a vertical position.Although their constructional and operational features underwent a continuous evolution over the years, their basic operational principle remained the same.Produced liquids, after being subjected to great centrifugal forces caused by the high rotational speed of the impeller, lose their kinetic energy in the diffuser where a conversion of kinetic to pressure energy takes place. This is the main operational mechanism of radial and mixed flow pumps.The pump shaft is connected to the gas separator or the protector by a mechanical coupling at the bottom of the pump. Well fluids enter the pump through an intake screen and are lifted by the pump stages.Other parts include the radial bearings (bushings) distributed along the length of the shaft providing radial support to the pump shaft turning at high rotational speeds.
3) IR sensor - 1nos
An infrared sensor is an electronic instrument which is used to sense certain characteristics of its surroundings by either emitting and/or detecting infrared radiation. Infrared sensorsare also capable of measuring the heat being emitted by an object and detecting motion.
This is used to switch the water pump when thirsty puppy comes in front of the Automatic Milk feeder.
4) 5V Relay board - 1no
This is a 5V, 10A 4-Channel Relay interface board. It can be
used to control various appliances, and other equipments with
large current. It can be controlled directly with 3.3V or 5V
logic signals from a microcontroller (Arduino, 8051, AVR, PIC,
DSP, ARM, ARM, MSP430, TTL logic).
It has a 1x4 (2.54mm pitch) pin header for connecting power
(5V and 0V), and for controlling the 4 relays. The pins are
marked on the PCB:
GND - Connect 0V to this pin.
IN1 - Controls relay 1, active Low ! Relay will turn on when this
input goes below about 2.0V
IN2 - Controls relay 2, active Low ! Relay will turn on when this
IN3- Controls relay 3, active Low ! Relay will turn on when this
IN4 - Controls relay 4, active Low ! Relay will turn on when this
VCC - Connect 5V to this pin. Is used to power the opto
couplers
This relay driver is used to Switch on and switch off the pumps
5) LED #1 and 1k Resistor - 1each
it is just an indication of power supply .
6) Small Pipe
it is connected from pump to Plate of the puppy.
Step 4: How It Works ?
Milk and Water is filled in two different plastic container each container has different 12v pump to lift the liquid ,
This pumps are activated by 5v relay module and it is controller by the master brain of the unit ,ie Arduino uno ,
Arduino has a 16mhz crystal hence it can calculate time by using its timer
,in Arduino programming delay(1000) means 1sec, so we have to give milk to our pet for every 3hrs for that
we need to calculate the delay
1 sec = 1000ms
60sec = 60000ms
1min = 60sec = 60000ms
60min = 60*60000 = 3600000
therefore 1hr = 3600000
so we need to calculate it for 3hr
3*3600000= 10800000 !!
hence
delay(10800000) ;
we have to give this delay after every feed process .
whenever this delay finishes Arduino gives signal to the Relay driver ,then relay driver switches on the pump for few sec (based on the pet & age ,ie amount of the milk consumption will be different for different pets) .
and then it turns of the relay driver,Arduino starts its delay counting again.
now we will see the connection !!
Step 5: Connection of Arduino and Relay Board !
Connections :-
Arduino pin no - 7 to Relay IN1
Arduino pin no - 8 to Relay IN2
Arduino 5v to Relay VCC
Arduino GND to Relay GND
Step 6: Connection of Relay Board and 12v Submersible Pump
Here unconnected terminal goes to 12V DC/AC input from battery.
Step 7: Connection of Arduino and IR Sensor !!
Connections :-
Arduino pin no - 13 to IR sensor O/P
Arduino 5v to IR sensor VCC
Arduino GND to IR sensor GND
Step 8: Arduino Coding !
Step 9: Overall Connection !!
Here look at the first pic it is the main part of the project and second pic has got 12v power supply based on 7812IC I got this for around 35 INR in Bangalore .
Here I have used only two relay(iN1,iN2) since I have used two pumps ,
12v supply board has got two terminal connector ,one is for input and other is for output,
Connect all the components as per the circuit and upload the sketch to the Arduino ,
I hope you will Do it soon for your pet.
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    6 Discussions
    Lorddrake
    2 years ago
    that seemed like alot of water pumped into the bowl in the video. is there an overflow prevention that i missed or is that something that needs to be added?
    AXR AMARLorddrake
    Reply 2 years ago
    You can control the amount of water flow by using a delay() in program ...here it will pump for 4sec , you can use 2sec or 3sec depending upon your pet !ie amount of water /milk it can drink.
    We can add overflow sensor for it ,its not a big issue but here i made a simple one...!
    AXR AMARTanmay Deuskar
    Reply 2 years ago
    Thank u bro, Still need !upgrade a lot in this project....will do it soon
    Tanmay Deuskar
    2 years ago
    Nice project. Is really useful for a pet
