Automatic Tea Timer
3,856
46
13
This is a simple gadget that will help you prepare your teas and infusions. Just put the tea bag (or infuser) and the cup with hot water in place and select the desired steeping time. The Tea Timer will automatically infuse the tea during the selected time and will notify you with a beep when your drink is ready.
All project files available at: https://github.com/lluisgl7/tea-timer
Thingiverse link: http://www.thingiverse.com/thing:1049056
Supplies:
Step 1: Parts
Printed parts
The printed parts have been designed with FreeCAD. The original parametric files are supplied along with the generated STL files. For the main part of the Tea Timer, in addition to the unsupported version, I created a version with the minimal supports needed (although it will depend on the printer).
Required hardware
- Arduino Pro Mini or another small and compatible Arduino board.
- LCD Display compatible with the Hitachi HD44780 driver (typical 2x16 Arduino LCD)
- Micro Servo - 2x Rotary Potentiometers: http://www.banggood.com/1-2-5-10-20-50-100-250-50...
- Push Button: http://www.banggood.com/1-2-5-10-20-50-100-250-50...
- Slide Switch: http://www.banggood.com/1-2-5-10-20-50-100-250-50...
- 11.8 mm Buzzer: http://www.banggood.com/1-2-5-10-20-50-100-250-50...
- 5V Power Supply (USB supply, phone charger…)
- Power Jack Plug: http://www.banggood.com/1-2-5-10-20-50-100-250-50...
- Power Jack Socket: http://www.banggood.com/1-2-5-10-20-50-100-250-50...
- 7x M3 bolts and nuts (LCD display and lid)
- 4x M2 bolts and nuts (servo and power switch)
You may also need some type of adhesive (I used double sided foam to fasten the arduino board and the contrast potentiometer on the inside), an USB-to-TTL serial converter board to upload the sketch and wiring material (wires, solder, heatshrink tubing…).
Step 2: Wiring
Do the wiring following the schematic.
Step 3: Arduino Sketch
Upload the Arduino sketch using an USB-to-TTL serial converter board and test the circuit before the final assembly.
Step 4: Final Assembly
Attach all the components to the 3D printed parts with screws or adhesive, and you're done! Happy tea time :)
Caffeine Challenge
Runner Up in the
Caffeine Challenge
Time Contest
Runner Up in the
Time Contest
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    13 Discussions
    VilmárioJ
    1 year ago
    I see in the project that was used two push buttons, but in the code has an encoder button ... I can not make the change ... will you help me? I loved your project, I want to build one for me! thank you!
    lluisgl7VilmárioJ
    Reply 11 months ago
    Hi! Glad you liked the project. I'm not sure I understand your question. There is only one push button ("buttonPin" in the sketch) and a potentiometer ("potPin" in the sketch) to select the time. Those are the ones you can see under the display. Additionaly, there is an extra potentiometer inside to adjust the display contrast and a switch to power on/off the circut. I hope this helps!
    lluisgl7jappa
    Reply 2 years ago
    Thanks for your comment!
    The i2c module would reduce the wiring mess a lot, so yes it may be easier. But the sketch would need some modifications!
    lluisgl7DonC60
    Reply 2 years ago
    Sorry there is no other link. You can download all files in a ZIP from github by clicking the "Clone or download" button :)
    lluisgl7skepticaljay
    Reply 3 years ago
    Thank you. I've just seen your Tea Steeper. It looks great!
    thijsv
    3 years ago
    Nice project. There is a big fuzz around coffee brewing and finding the ideal time and temperature, but I think your project fills in that gap on the tea side perfectly.
    I also like the small R2D2 joining the project!
    lluisgl7thijsv
    Reply 3 years ago
    Thanks for your comment! R2 helped a lot :P
    seamster
    3 years ago
    Very cool project! Thanks for sharing, and welcome to instructables! :)
