Awesome Led Cube
490,528
2,267
1,512
You never know when you might need a glowing cube to convince people you are from the future.
Step 1: Materials and Tools
To make this you will need:
A LED (preferably high power)
a 3 volt coin cell battery
a 100 ohm resistor (anything close to 100 will work)
a momentary or push button switch.
thin sheet metal
plexiglass
tools:
hot glue gun
metal shears
sharpie
saw
soldering iron
Step 2: The Box
Cut out 6 squares of equal size from the plexiglass with a saw.
Use the hot glue gun to make them into a box. Leave off the last side for now.
Drill a hole in one side of the box, make the hole large enough for the button on the switch to be pushed through it.
Step 3: Lighting
Solder together the switch, resistor, and the led.
Duct tape the two wires that remain to the battery.
Hot glue the assembly to the inside of the cube with the button in the hole.
Step 4: Finish the Box
Fill the box with hot glue to diffuse the light.
Glue the final side on.
Step 5: Armor
Cut out of the sheet metal futuristic designs and glue them onto the cube.
Make sure that when you glue onto the button you don't stop it from being pressed down, and that it sticks out enough to be pushed down.
To give you an idea, Duck-Lemon made two templates. (last pictures)
Step 6: Time Travel!
Use the cube to slow, stop, or reverse time, or even turn ordinary technology into transformers. Your choice.
It looks the best in the dark.
First Prize in the
The Instructables Book Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    1,512 Discussions
    zack247Jandro
    nope, all sides will light up because the hot glue is diffusing the light throughout the entire box.
    Lenny24
    8 years ago on Introduction
    One Idea. If the Battery in these things are empty, youll have to throw it away, I guess. How about adding a Supercapacitor and an inductive charger to it? So youll have to shake it if you want it to Light up. I thought that would be kinda cool and youll wont have to worry about empty Batteries!
    anv3DLenny24
    Reply 2 months ago
    Put one of those colour changing LED tealights inside!
    asoo1Lenny24
    make socket (hole or wath ever to call it ) for ac adapter :D u can easely racharge it :D
    zack247asoo1
    or, since the metal would be conductive, use two of the metal plates as charging contact plates?
    ThePuzzler
    5 years ago on Step 5
    umm... the design templates only have 5 sides... is there supposed to be 6?
    anv3DThePuzzler
    Reply 2 months ago
    You don't need anything on the bottom.
    Mremeralds95
    2 years ago
    I loved this idea, but instead of a single led I used a portion of an LED strip light, and left a small hole on the back to plug into power. It's not as portable, but you don't have to worry about a battery going bad.
    wow_zakarumajjhh
    The resistor is used to keep the LED from drawing too much current and burning its self out. You dont HAVE to have one, but it will last longer if you do.
    LokkeshRwow_zakarum
    Reply 2 years ago
    Guys could we use aluminium foil for reflection instead of hot glue
    imagigadgetsajjhh
    I've killed a few LEDs because I wasn't smart enough to use one. You really need it if you don't want to waste supplies making these.
    mavisclouds
    2 years ago
    sir,i need more pict for the pattern of the lamp and resistor and battery
    BlairP4
    2 years ago
    You don't happen to remember exactly which LED's you used do you?
    jjuneja1
    3 years ago
    how long does it last??
    fibcoa7
    3 years ago on Introduction
    The original picture for the cube looks quite a bit like a Borg cube from Star Trek TNG. I'm not a trekkie myself, but I have a friend who is, so it will be so much fun to freak him out.
