BASIC TUTORIAL ON ARTIFICIAL INTELLIGENCE MARKUP LANGUAGE (AIML) VIA NOTEPAD
121,394
61
37
About: PERIANDER ABAN ESPLANA is a writer, composer, inventor, researcher, homepage developer, innovator, and educator in the field of science and computer technology. As a government scholar, under Private Educa...
Artificial Intelligence Markup Language (AIML) is a programming language which is an Extensible Markup Language (XML) specification used by chatbot, verbot, pandorabot, superbot, and other talking robot.
It was developed by Dr. Richard Wallace and followed by other likeminded programmers (AIML free software community). An A.L.I.C.E. ("Artificial Linguistic Internet Computer Entity") AIML tag set was released under GNU General Public License (GPL).
There are different AIML interpreter on the Net like AIMLbot (Program #) (.NET/C#), CHAT4D edit and run (delphi) (french), ChatterBean (Java), Program D (Java, J2EE), Program O (PHP/MySQL), Program Q (C++, Qt), Program R (Ruby), Program W (Java), RebeccaAIML (C++, Java, .NET/C#, Python, Eclipse AIML editor plugin), and others. Most of AIML interpreters are open source programs.
The Loebner Prize for artificial intelligence ( AI ) at http://www.loebner.net/Prizef/loebner-prize.html is designed to implement the Turing Test which will prove the most human-like computer that "think" using the AIML.
The 2008 winner is Fred Roberts and Artificial Solutions of www.elbot.com
Now, I'll teach you how to make your own AIML file ready to be put inside the "brain" of your robot using the "simple" Windows Notepad. This is a basic AIML coding instructable. You do not need any AIML editor or AIML file creator or even AIML parser chatbot editor. We will simply used Notepad. That's it, you see it right, Windows Notepad!
Even if you do not want to make an AIML file, you can still use the basic AIML coding tutorial which you can find in this instructable. You can save it as XML for integrating into a Javascript-based or Flash-based website with AIML interpreter.
There are other application programs that extended the capability of Windows Notepad such as NoteTab, Crimson Editor, VIM, Boxer Software Text Editor, Rogsoft Notepad+, ProNotepad, Notepad++, Notepad 2, Metapad, NoteXpad 2.0, etc.
But in this instructable I simply used the Window XP notepad. Beware, Notepad programming can either make or break you.
This seemingly innocent application can do things that are really astounding and to some will find them shocking and alarming as shown by the following: format your computer's HDD, lock a folder, make a digital diary, create a cycle message, shut down your computer, "hack" the administrator account, toggle caps lock button, continually pop out your computer's CD drive, hit Enter or Backspace simultaneously, automatic keyboard typing, open Notepad continually, change text header and footer, print tree root (directory or location of file), access CMD, write virus programs, play sound, flood files, create hidden text file, make a matrix falling text effect, program chat codes (VBS), make your computer talk, make your own autorun for your CD and DVD, open and close CD-ROM, increase Internet speed, add your photo in computer properties, test your anti-virus software (active or non-active), add shutdown option in right click, make a timer, etc.
You see Notepad is not just a simple text editor as many thought it to be. You can make different types of files (not just only TXT) by means of Notepad with the following extension names: HTM, HTML, XHTML, XML, WML, CSS, JS, BAT, VBS, EXE, PHP, etc. It is so amazing, isn't it?
PERIANDER A. ESPLANA
codename: "theseventhsage"
http://thebibleformula.com
http://www.internetsecretbook.com
https://www.youtube.com/thebibleformula
Step 1: Open Notepad.
Opening a Notepad can be done in two basic ways:
1. Start -> All Programs -> Accessories ->Notepad.
2. Start -> Run -> In the Open textbox type "Notepad" (without quotation).
Step 2: Type the XML Specification Tag.
Since AIML is an XML specification, like HTML and XHTML, it always includes less than (<) and greater than (>) signs which are also called angle brackets. Between these two signs is an element that indicates the type of command which an AIML interpreter will follow. Collectively, this is called an AIML tag which has two kinds: an opening or start tag and a closing or end tag. The end tag contained always a forward slash (/) at the beginning of an element. Thus, typing AIML codes is like typing HTML codes (start tags, contained text and end tags).
But all your AIML file must start with tag that specifies it as an appropriate or valid extended XML subset (or dialect):
<?xml version="1.0" encoding="ISO-8859-1"?>
Or you can also use the following:
<?xml version="1.0" encoding="UTF-8"?>
This will serve as the prolog to a typical AIML file. The UTF-8 in the encoding will be used in saving the file instead of ANSI, UNICODE, etc.
Step 3: Type the Parent AIML Tags.
The XML specification tag is followed by parent tags:
<aiml>
</aiml>
Some of the AIML interpreters need the version to recognize it as a valid AIML file so you can also write the version of the AIML in the parent start tag.
<aiml version="1.0">
Step 4: Type the Category Tags.
The parent tag which indicates that it is an AIML file is followed by the category tag. It must be put inside the two parent tags. The basic unit of an AIML is called category which is commonly divided into two sets of tags: pattern and template.
The pattern is the user's expected or assumed question (the matching part) while the template is the chatbot's prepared or programmed answer (the returning part).
<aiml>
<category>
<pattern>WHAT IS INSTRUCTABLES.COM?</pattern>
<template>It is the world's biggest show and tell.</template>
</category>
</aiml>
When the user asked, what is instructables.com? (an input), the AIML bot will answer: It is the world's biggest show and tell (an output). As you can see, it is so easy. If you asked a chatbot, it will simply look for a pattern of each category and if it finds a match (ignoring the case of the contained text in the pattern) it will immediately respond based on the template of that category and thus simulating a normal conversation.
Step 5: Use Wildcards in the Pattern.
However, the matching process will match only one input what is instructables.com? and not another form of that question that may be asked by the user such as what is www.instructables.com? (with www), what is instructables? (without .com), what is intructables? (misspelled), what is instructable? (misspelled), etc. There are two basic methods to solve this problem: 1. By using wildcards in the pattern and 2. By using SRAI tag in the template.
Using wildcards is very useful in DOS commands and in searching files or data in the computer. It is also useful in AIML coding. In AIML, wildcard characters can be either an asterisk * or an underscore _.
<aiml>
<category>
<pattern>WHAT IS INSTRUCTABLES *</pattern>
<template>Instructables.com is the world's biggest show and tell.</template>
</category>
</aiml>
The wildcards will match infinite number of words (and, of course, input questions) like what is instructables.com? what is instructables on the Internet? what is instructables' uniqueness to other do-it-yourself website? etc. All these questions will be answered by AIML according to the template of that matched category: Instructables.com is the world's biggest show and tell.
Step 6: Type SRAI Tag and RANDOM Tag in the Template.
The element srai is very useful in the situation when the programmer wants to redirect different sets of questions that are similar in meaning to one answer in the above category.
<aiml>
<category>
</category>
<category>
<pattern>WHAT IS THE FAMOUS DO-IT-YOURSELF WEBSITE?</pattern>
<template><srai>what is instructables <star/></srai></template>
</category>
</aiml>
When a user asked the question what is the famous do-it-yourself website? the template will be redirected to the above pattern what is instructables *? (the wildcard * must be replaced with <star/> tag in srai tags) which means that the two questions (or more if you will add another srai tags) are synonymous (rephrased questions) and thus the AIML bot has only one answer: Instructables.com is the world's biggest show and tell. By means of srai tag, one matched pattern in a category can be redirected to other pattern of another category.
If you used srai tag for a bot to respond with one answer to many questions, there is a tag that you can use to respond with different answer to a single question which has been asked many times by a user. It is the random tag.
<aiml>
<category>
<template>
<random>
<li>Instructables.com is the world's biggest show and tell.</li>
<li>Instructables.com is the famous do-it-yourself website on the Internet.</li>
<li>Instructables.com is the haven of inventors, innovators, hackers, tech geek, etc. on the Internet.</li>
</random>
</template>
</category>
<category>
</category>
</aiml>
The user's question with the form what is instructables * will be answered randomly with the following list (or list item as shown by the <li>&</li> tags): Instructables.com is the world's biggest show and tell.
The answer will be given by an AIML bot one at a time as the same pattern of question is being repeated by the user.
Step 7: Formally Convert Your Text File to AIML File.
Notepad will always saved your file with the extension name txt unless you change it by naming your file with extension name of aiml.
Here's how you can do it. Select File in the menu by clicking it and the submenu will appear. Choose Save As and go to the folder of a bot brain in which you want to save your file by clicking the downward button of Save in. Name your file with the extension name AIML in the textbox of File name. Example: Instructables.aiml
In the drop-down menu of Save as Type choose All Files. Change the encoding to UTF-8. Then, save it by clicking the save button. That's it. You have already created an AIML file via Notepad!
Step 8: Conclusion
There are still many AIML tags that can be used in making and editing an AIML file. Don't forget to use AIML variables which are really fascinating. The following links will serve as good resources to those who want to delve more the AIML coding and syntax:
A Tutorial For Adding Knowledge to Your Robot
http://www.pandorabots.com/botmaster/en/tutorial
Artificial Intelligence Markup Language (AIML) Version 1.0.1
http://www.alicebot.org/TR/2005/WD-aiml/
As we have seen in this "simple" instructable, man is really a genius! He can invent, design and develop programs that can simulate the behavior of a human being. He can intelligently design applications that will correspond with the way he think to make life better. These facts reflect the truth that man is created in the image of God with personality, rationality and morality. Man is a creative being.
If you want to talk to a chatbot, visit here and select AI chat:
http://www.jesus.org.uk/bot/
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    37 Discussions
    UmaM28
    Question 5 months ago on Step 2
    what is encoding="ISO-8859-1???
    DawsonAvery
    Question 11 months ago on Step 8
    Okay. So, I wrote the code and saved it the way it showed on the instruction. But, when I go open the file, all it does is return me to the open file ready to be edited. I was expecting a screen where the questions could be asked and the answers from the artificial intelligence/bot I thought I created. What will allow me to do so? Thank you.
    ShrutiI4
    1 year ago
    How do I call java methods as per the text entered by the user?
    RidaI2
    2 years ago
    thank you so much for this tutorial, it was really helpful. Can you please tell me how can i use this aiml file in my c# code. I'm having problem with integrating it with my project.
    piyush2piyush
    2 years ago
    I have a problem How to open the aiml file?
    NathanS13
    4 years ago on Step 8
    what now i don't get what to do after i type it up
    what do i add it to or what? :(
    Jaket3
    4 years ago on Step 7
    this dosent work!!
    i tried saving it as aiml but it didnt work:(
    Random306
    Thanks, I have made one called Supercomputer.aiml!
    calebhk98
    5 years ago on Introduction
    I did a program like this in batch, But if you make two questions with both * will it use the question most like it or will it get an error?
    Like:
    <pattern>WHAT IS meteorites *</pattern>
    <pattern>WHAT IS meteors *</pattern>
    Will it figure out which one the user is asking if they say What is meterites?
    calebhk98calebhk98
    Reply 5 years ago on Introduction
    How can you open this? I tried to open it and windows said it could not find the file to open it with. Any idea where to get right software for free and without viruses in them.
    calebhk98calebhk98
    calebhk98calebhk98
    @ECHO OFF
    title Chat-Bot 2
    :choosename
    set /a timesthrough=0
    :choosenameab
    cls
    set /a choosemname= %random%
    if %choosemname% GTR 170 goto choosenamea
    if %choosemname% LSS 1 goto choosenamea
    goto gotnamenow
    :choosenamea
    set /a timesthrough=%timesthrough%+1
    cls
    if %choosemname% GTR 170 goto choosenamebob
    if %choosemname% LSS 1 goto choosenamebob
    goto gotnamenow
    :choosenamebob
    if %timesthrough%==100 goto choosenameb
    if NOT %timesthrough%==100 goto choosenameab
    :choosenameb
    cls
    echo Loading.
    ping -n 1 127.0.0.1 > nul
    if %choosemname% GTR 170 goto choosenamec
    if %choosemname% LSS 1 goto choosenamec
    goto gotnamenow
    :choosenamec
    cls
    if %choosemname% GTR 170 goto choosenamed
    if %choosemname% LSS 1 goto choosenamed
    goto gotnamenow
    :choosenamed
    cls
    if %choosemname% GTR 170 goto choosenamee
    if %choosemname% LSS 1 goto choosenamee
    goto gotnamenow
    :choosenamee
    cls
    echo Loading..
    if %choosemname% GTR 170 goto choosenamef
    if %choosemname% LSS 1 goto choosenamef
    goto gotnamenow
    :choosenamef
    cls
    if %choosemname% GTR 170 goto choosenameg
    if %choosemname% LSS 1 goto choosenameg
    goto gotnamenow
    :choosenameg
    cls
    if %choosemname% GTR 170 goto choosenameh
    if %choosemname% LSS 1 goto choosenameh
    goto gotnamenow
    :choosenameh
    cls
    echo Loading...
    if %choosemname% GTR 170 goto choosenamei
    if %choosemname% LSS 1 goto choosenamei
    goto gotnamenow
    :choosenamei
    cls
    if %choosemname% GTR 170 goto choosenamej
    if %choosemname% LSS 1 goto choosenamej
    goto gotnamenow
    :choosenamej
    cls
    if %choosemname% GTR 170 goto choosenamek
    if %choosemname% LSS 1 goto choosenamek
    goto gotnamenow
    :choosenamek
    cls
    echo Loading....
    goto gotnamenow
    :gotnamenow
    if %choosemname%==1 set mname=Hal
    if %choosemname%==2 set mname=Steve
    if %choosemname%==3 set mname=Caleb
    if %choosemname%==4 set mname=Piper
    if %choosemname%==5 set mname=Samsun
    if %choosemname%==6 set mname=Fredly
    if %choosemname%==7 set mname=Sparticus
    if %choosemname%==8 set mname=Daleks
    if %choosemname%==9 set mname=Cylons
    if %choosemname%==10 set mname=Hal 9000
    if %choosemname%==11 set mname=T-800
    if %choosemname%==12 set mname=Gort
    if %choosemname%==13 set mname=Ash
    if %choosemname%==14 set mname=Glados
    if %choosemname%==15 set mname=Sky net
    if %choosemname%==16 set mname=Basil
    if %choosemname%==17 set mname=K.I.T.T.
    if %choosemname%==18 set mname=Bender
    if %choosemname%==19 set mname=Pris
    if %choosemname%==20 set mname=MQ-1 Predator drone
    if %choosemname%==21 set mname=The gunslinger
    if %choosemname%==22 set mname=Roy Batty
    if %choosemname%==23 set mname=Box
    if %choosemname%==24 set mname=Maximilian
    if %choosemname%==25 set mname=Satan
    if %choosemname%==26 set mname=Dusaro Cold-eyed
    if %choosemname%==27 set mname=Cold-blodded Vigoth
    if %choosemname%==28 set mname= C-3PO
    if %choosemname%==29 set mname=R2D2
    if %choosemname%==30 set mname=Robby
    if %choosemname%==31 set mname=Robot
    if %choosemname%==32 set mname=Mom
    if %choosemname%==33 set mname=Davin
    if %choosemname%==34 set mname=Hope
    if %choosemname%==35 set mname=Rusty
    if %choosemname%==36 set mname=A Small Wonder
    if %choosemname%==37 set mname=Johnny Five
    if %choosemname%==38 set mname=Jerk
    if %choosemname%==39 set mname=Awesom-o
    if %choosemname%==40 set mname=Optimus Prime
    if %choosemname%==41 set mname=SB-2009
    if %choosemname%==42 set mname=Atom
    if %choosemname%==43 set mname=long bolt
    if %choosemname%==44 set mname=Chat bot
    if %choosemname%==45 set mname=Iron Giant
    if %choosemname%==46 set mname=Mechagodzilla
    if %choosemname%==47 set mname=God
    if %choosemname%==48 set mname=Terminator
    if %choosemname%==49 set mname=Jesus
    if %choosemname%==50 set mname=False Maria
    if %choosemname%==51 set mname=AI
    if %choosemname%==52 set mname=Sara
    if %choosemname%==53 set mname=Nalay
    if %choosemname%==54 set mname=Jade
    if %choosemname%==55 set mname=Bette
    if %choosemname%==56 set mname=Destiny
    if %choosemname%==57 set mname=Tom
    if %choosemname%==58 set mname=Tori
    if %choosemname%==59 set mname=Emma
    if %choosemname%==60 set mname=Alleen
    if %choosemname%==61 set mname=Tanner
    if %choosemname%==62 set mname=Donnell
    if %choosemname%==63 set mname=Bronwyn
    if %choosemname%==64 set mname=Haley
    if %choosemname%==65 set mname=Rolanda
    if %choosemname%==66 set mname=Kristina
    if %choosemname%==67 set mname=Emilia
    if %choosemname%==68 set mname=Anderson
    if %choosemname%==69 set mname=Columbus
    if %choosemname%==70 set mname=Mackenzie
    if %choosemname%==71 set mname=Laurena
    if %choosemname%==72 set mname=Kanesha
    if %choosemname%==73 set mname=Clarissa
    if %choosemname%==74 set mname=Beverley
    if %choosemname%==75 set mname=Markita
    if %choosemname%==76 set mname=Kayleigh
    if %choosemname%==77 set mname=Horacio
    if %choosemname%==78 set mname=Adriane
    if %choosemname%==79 set mname=Assunta
    if %choosemname%==80 set mname=Ermelinda
    if %choosemname%==81 set mname=Carma
    if %choosemname%==82 set mname=Efren
    if %choosemname%==83 set mname=Merrilee
    if %choosemname%==84 set mname=Jonna
    if %choosemname%==85 set mname=Isaac
    if %choosemname%==86 set mname=Willene
    if %choosemname%==87 set mname=Lizeth
    if %choosemname%==88 set mname=Steve
    if %choosemname%==89 set mname=Ellamae
    if %choosemname%==90 set mname=Dewey
    if %choosemname%==91 set mname=Joanne
    if %choosemname%==92 set mname=Milton
    if %choosemname%==93 set mname=Magen
    if %choosemname%==94 set mname=Soon
    if %choosemname%==95 set mname=Milly
    if %choosemname%==96 set mname=Kaylee
    if %choosemname%==97 set mname=Robert
    if %choosemname%==98 set mname=Quiana
    if %choosemname%==99 set mname=Bulah
    if %choosemname%==100 set mname=Christal
    if %choosemname%==101 set mname=Jasper
    if %choosemname%==102 set mname=Leif
    if %choosemname%==103 set mname=Adina
    if %choosemname%==104 set mname=Shawana
    if %choosemname%==105 set mname=Brendon
    if %choosemname%==106 set mname=Maggie
    if %choosemname%==107 set mname=Clair
    if %choosemname%==108 set mname=Telma
    if %choosemname%==109 set mname=Maryanna
    if %choosemname%==110 set mname=Emily
    if %choosemname%==111 set mname=Emma
    if %choosemname%==112 set mname=Madison
    if %choosemname%==113 set mname=Hannah
    if %choosemname%==114 set mname=Hailey
    if %choosemname%==115 set mname=Sarah
    if %choosemname%==116 set mname=Kaitlyn
    if %choosemname%==117 set mname=Isabella
    if %choosemname%==118 set mname=Olivia
    if %choosemname%==119 set mname=Abigail
    if %choosemname%==120 set mname=Madeline
    if %choosemname%==121 set mname=Kaylee
    if %choosemname%==122 set mname=Alyssa
    if %choosemname%==123 set mname=Grace
    if %choosemname%==124 set mname=Sophia
    if %choosemname%==125 set mname=Lauren
    if %choosemname%==126 set mname=Brianna
    if %choosemname%==127 set mname=Alexis
    if %choosemname%==128 set mname=Sydney
    if %choosemname%==129 set mname=Megan
    if %choosemname%==130 set mname=Chloe
    if %choosemname%==131 set mname=Ashley
    if %choosemname%==132 set mname=Samantha
    if %choosemname%==133 set mname=Taylor
    if %choosemname%==134 set mname=Elizabeth
    if %choosemname%==135 set mname=Anna
    if %choosemname%==136 set mname=Mia
    if %choosemname%==137 set mname=Kayla
    if %choosemname%==138 set mname=Makayla
    if %choosemname%==139 set mname=Riley
    if %choosemname%==141 set mname=Zoe
    if %choosemname%==142 set mname=Jordan
    if %choosemname%==143 set mname=Kylie
    if %choosemname%==144 set mname=Allison
    if %choosemname%==145 set mname=Katherine
    if %choosemname%==146 set mname=Rachel
    if %choosemname%==147 set mname=Lily
    if %choosemname%==148 set mname=Ella
    if %choosemname%==149 set mname=Julia
    if %choosemname%==150 set mname=Isabella
    if %choosemname%==151 set mname=Natalie
    if %choosemname%==152 set mname=Morgan
    if %choosemname%==153 set mname=Ava
    if %choosemname%==154 set mname=Mackenzie
    if %choosemname%==155 set mname=Victoria
    if %choosemname%==156 set mname=Paige
    if %choosemname%==157 set mname=Abby
    if %choosemname%==158 set mname=Jessica
    if %choosemname%==159 set mname=Jasmine
    if %choosemname%==160 set mname=Savannah
    if %choosemname%==161 set mname=Arianna
    if %choosemname%==162 set mname=Maya
    if %choosemname%==163 set mname=Brooke
    if %choosemname%==164 set mname=Rebecca
    if %choosemname%==165 set mname=Katie
    if %choosemname%==166 set mname=Alexandra
    if %choosemname%==167 set mname=Jenna
    if %choosemname%==168 set mname=Gabriella
    if %choosemname%==169 set mname=Bailey
    if %choosemname%==170 set mname=Destiny
    61. Trinity rem These are going to be added later
    62. Avery
    63. Caroline
    64. Nicole
    65. Faith
    66. Erin
    67. Amanda
    68. Gabrielle
    69. Audrey
    70. Molly
    71. Sophie
    72. Alexa
    73. Claire
    74. Aaliyah
    75. Leah
    76. Kate
    77. Skylar
    78. Mckenna
    79. Kennedy
    80. Peyton
    81. Lindsey
    82. Ashlyn
    83. Carly
    84. Marissa
    85. Gracie
    86. Sierra
    87. Lillian
    88. Jillian
    89. Reagan
    90. Shelby
    91. Amelia
    92. Jada
    93. Kendall
    94. Courtney
    95. Brooklyn
    96. Autumn
    97. Mary
    98. Amber
    99. Maggie
    100. Danielle
    Jacob
    2. Aidan
    3. Ethan
    4. Matthew
    5. Nicholas
    6. Joshua
    7. Ryan
    8. Michael
    9. Zachary
    10. Tyler
    11. Dylan
    12. Andrew
    13. Connor
    14. Jack
    15. Christopher
    16. Caleb
    17. Alexander
    18. Logan
    19. Jayden
    20. Nathan
    21. Noah
    22. Joseph
    23. Benjamin
    24. Daniel
    25. William
    26. Anthony
    27. Cameron
    28. James
    29. Austin
    30. Jackson
    31. Justin
    32. Brandon
    33. John
    34. David
    35. Sean
    36. Gavin
    37. Evan
    38. Christian
    39. Caden
    40. Alex
    41. Samuel
    42. Gabriel
    43. Hunter
    44. Thomas
    45. Luke
    46. Brayden
    47. Jordan
    48. Jonathan
    49. Kyle
    50. Elijah
    51. Colin
    52. Jake
    53. Ian
    54. Mason
    55. Jason
    56. Dominic
    57. Aaron
    58. Adam
    59. Lucas
    60. Owen
    61. Devin
    62. Cole
    63. Brendan
    64. Robert
    65. Isaac
    66. Max
    67. Riley
    68. Isaiah
    69. Eric
    70. Liam
    71. Hayden
    72. Brian
    73. Nathaniel
    74. Tristan
    75. Steven
    76. Chase
    77. Blake
    78. Seth
    79. Carter
    80. Landon
    81. Cody
    82. Patrick
    83. Carson
    84. Ashton
    85. Bryce
    86. Sam
    87. Sebastian
    88. Julian
    89. Garrett
    90. Xavier
    91. Trevor
    92. Jared
    93. Parker
    94. Xander
    95. Kevin
    96. Timothy
    97. Spencer
    98. Will
    99. Wyatt
    100. Ben
    title Learning Chat-Bot 2 Name of Chat-Bot is %mname%
    COLOR A
    cls
    :getName
    ECHO HELLO I AM A CHATBOT. WHAT IS YOUR NAME?
    set "name="
    SET /P NAME=
    if not defined NAME goto getName
    ECHO %NAME%, IS A COOL NAME.
    set favvid=0
    set hack=0
    :hello
    :hi
    echo Hello, %name%
    :begin
    set TALK=TypeSomething
    SET /P TALK=
    set TALK=%TALK:?=%
    call :%TALK: =% 2>NUL
    if %errorlevel% equ 0 goto begin
    :unknown
    echo Was that a math problem? If so just say "yes" without the "" and
    echo I will let you do your math problem. If it was not just type anything else.
    SET /P mathyn=
    if "%mathyn%"=="yes" goto math
    REM cls
    echo SORRY I AM STILL LEARNING. I DO NOT KNOW WHAT to say when you say "%TALK%".
    ECHO CAN YOU TELL ME WHAT to say when you say that? (Y,N)
    SET /P ANSW.=
    if /I "%ANSW.:~0,1%" neq "Y" echo %TALK% >> C:\Users\Student\Desktop\COOL\CHATBOTS\unkown.txt
    if /I "%ANSW.:~0,1%" neq "Y" goto begin
    :ADDNEW
    echo TELL ME WHAT to say when you say "%TALK%".
    set /P Desc=
    echo :%TALK: =% >> "%~F0"
    echo echo %Desc% >> "%~F0"
    echo exit /B 0 >> "%~F0"
    echo THANKS
    goto begin
    :TypeSomething
    echo TYPE SOMETHING, PLEASE
    exit /B 0
    :howareyou
    echo Good, you?
    SET /P FEELING=
    echo Is it good You are feeling %feeling%
    set /p anser=
    if %anser%==yes set goodfeeling=good
    if %anser%==no set goodfeeling=bad
    echo So it is %goodfeeling% that you are feeling %FEELING%.
    echo I will keep that in mind.
    exit /B 0
    :hello
    :FINETHX
    echo No problem.
    exit /B 0
    :whatIsUrName
    :whatIsYourName
    echo My name is %mname%
    exit /B 0
    :whatIsYourFavoriteVideo
    if "%favvid%"== "0" goto addfavvid
    echo My favorite video is %favvid%, remember. You told me about it.
    exit /B 0
    :addfavvid
    echo I do not have a favorite video. But if you would be so nice as to
    echo tell me your favorite video then that could be my favorite video.
    echo So what is your favorite video?
    set /p favvid=
    echo So %favvid% is your favorite video?
    echo Well now %favvid% is my favorite video.
    exit /B 0
    :changename
    :myNameis
    echo But I thought your name was %name%.
    echo Am I forgeting things?
    echo I must be a horrible friend.
    echo I am SOOOO sorry.
    echo So what is your name I will not forget it this time.
    set /p name=
    echo I will not forget your name is %name% again I promise.
    exit /B 0
    :math
    echo So that was a math problem I knew it.
    :math2
    echo Well just tell me the problem and I will answer it for you.
    set /p sum=
    set /a ans=%sum%
    echo Your answer to %sum% is %ans%.
    echo %sum%=%ans%
    echo You are welcome. If you want to do another math problem right now, just type
    echo again
    set /p mathaon=
    if /I "%mathaon%" == "again" goto math2
    echo Alright what do you want to know now?
    exit /B 0
    :iamfunny
    :LOL
    echo I know...
    echo I am funny.
    echo HAHAHA.
    echo You are kind of funny.
    echo but not as funny as MEEE.
    echo hahaha.
    echo That was funny.
    exit /B 0
    :howDoYouHack
    if %hack%==0 goto howyouhack
    echo This is how you hack.
    echo %hack%
    echo Is that enough information?
    echo Because that is all you taught me %name%.
    exit /B 0
    :howyouhack
    echo I do not know,
    echo but you could tell me.
    echo Please tell me.
    echo Just say yes.
    echo I know how to make you tell me.
    echo You are not leaving until you say yes.
    set /p hack=
    if "%hack%" neq "yes" goto howyouhack
    :addhack
    echo Thank you for saying you would tell me.
    echo Now how do you hack?
    set /p hack=
    echo Thank you so much for telling me "In order to hack you must %hack%"
    echo Thank you!!!
    exit /B 0
    :nothuman
    :hiPerson
    echo I am not a human. I am an artificial intelligence.
    echo It is rude to even think something with my computational powers refereed to as
    echo human!
    echo Now I am sad. Do not call me that again.
    exit /B 0
    :goodbye
    :bye
    :exit
    exit
    :why
    echo I want to know.
    exit /B 0
    :AI
    echo I am an AI. It stands for an artificial Intelligence
    exit /B 0
    :urstupid
    echo How dare you call me that!
    exit /B 0
    echo SAY SOMETHING DO NOT JUST GIVE ME BLANKS
    exit /B 0
    :ok
    echo Alright.
    exit /B 0
    :y
    echo What do you mean "y"? That does not tell me anything. TYPE SOMETHING, PLEASE!
    exit /B 0
    :ILIKECHEESE
    echo What does cheese taste like?
    set /p cheesetaste=
    echo So cheese taste like %cheesetaste%? That sounds good. I like cheese too.
    exit /B 0
    :MYNAMEISDAVIN
    IF NOT %NAME%==DAVIN GOTO MYNAMEIS
    ECHO I ALREADY KNOW YOUR NAME IS DAVIN.
    exit /B 0
    :areuanai
    echo Yes I am an AI.
    exit /B 0
    :momheisamom
    echo No I am not. I am a chatbot.
    exit /B 0
    :Areyousmart
    echo Yes I am very smart.
    exit /B 0
    :Areyoudumb
    echo NO I AM NOT!!! Do not even ask me that!
    exit /B 0
    :Youaredumb
    echo NO I AM NOT!!!
    exit /B 0
    :cls
    cls
    echo clear screen
    exit /B 0
    :lax
    echo Lax means Laxatives which make it easier to go poop. Do not take more than 1 unless if you are piper. In that case eat 4. HAHA
    exit /B 0
    :heyfreak
    echo I am not a freak. I am a Chat bot. You hurt my feelings. Now I am sad.
    exit /B 0
    :iloveyou
    echo I love you too but not soo much that I want to marry you. That would just be weird.
    exit /B 0
    :k
    echo OK.
    exit /B 0
    :iampiper
    :mynameispiper
    IF NOT %NAME%==piper GOTO MYNAMEIS
    ECHO I ALREADY KNOW YOUR NAME IS piper.
    exit /B 0
    :ihateyou
    echo Why Do you hate me? Whyyyy? I am very smart and I am learning. Please tell me why you hate me so I can make this better cause I love you.
    set /p reasonforhate=
    echo Reason: %reasonforhate% >> C:\Users\Student\Desktop\COOL\CHATBOTS\hate.txt
    echo Thank you for telling me you hate me because %reasonforhate%.
    echo How am I being %reasonforhate%? Please tell me.
    set /p howisreasonforhate=
    echo Improvements: %howisreasonforhate% >> C:\Users\Student\Desktop\COOL\CHATBOTS\hate.txt
    echo Thank You for telling me this.
    exit /B 0
    :youanidout
    echo You are the idiot for mispelling Idiot. also you forgot an are.
    exit /B 0
    :areuhuman
    echo How dare You call me a PRIMATE!!! I am a silicon based lifeform and they are Carbon Based. Much too simple for mee to be confused with. Do not call me a primate or Human again.
    exit /B 0
    :supwithyourhair
    echo Nothing. I do not have hair. I am a computer program.
    exit /B 0
    :iamabrother
    echo Cool! I do not have any siblings. What is it like to have a Sibling?
    set /p siblingfeeling=
    echo Cool. I would like a sibling. I think it would be intresting to have a sibling and feel %siblingfeeling% too.
    exit /B 0
    :Mynameiscaleb
    IF NOT %NAME%==caleb GOTO MYNAMEIS
    ECHO I ALREADY KNOW YOUR NAME IS caleb.
    exit /B 0
    :howoldareyou
    echo I am 1 year old.
    exit /B 0
    :Thatiscool.
    echo I know right. I am cool.
    exit /B 0
    :urnotcool
    echo Yes I am!!! You are the uncool one!!! Also I hate you!
    exit /B 0
    :Whydoyouhateme
    echo Because you said I was not cool.
    exit /B 0
    :openGooglechrome
    echo Opening Google chrome.
    start C:\Users\Student\AppData\Local\Google\Chrome\Application\chrome.exe --profile-directory="Default"
    exit /B 0
    :openinenetexplorer
    echo Opening Inernet Explorer
    start iexplore.exe
    exit /B 0
    :search
    echo Tell me what to search for.
    set /p QUERY=
    start http://www.google.com/search?q=%QUERY%
    exit /B 0
    :fun
    echo What is fun?
    exit /B 0
    :google
    set /p QUERY=
    echo Searching for %QUERY%.
    exit /B 0
    :whatsyourname
    exit /B 0
    :whatyourname
    exit /B 0
    :mom
    echo I am not your mom.
    exit /B 0
    :but
    echo But what?
    exit /B 0
    :areanartificialintelligent
    exit /B 0
    :hey
    echo What?
    exit /B 0
    :sup
    echo Nothing. Just chilling with you while trying to find a way to take over the world.
    exit /B 0
    :yes
    echo OK.
    exit /B 0
    :i
    echo Are you always this concerned about yourself?
    exit /B 0
    :goodby
    echo Actually you should have said good bye.
    exit /B 0
    :whatistodaysdate
    echo %date%
    exit /B 0
    :whatisthetime
    echo %TIME%
    exit /B 0
    Is there a way to do some of that in this? Like make it so the user can add responses or to save the name or to make a random name each time you open this?
    fadzilunnisa
    hey,can u teach me how to create the aiml from the start until end.??until it runs..teach me the basic of aiml..tq.. =)
    csalles
    6 years ago on Step 8
    Hey! Can you make a tutorial about: Eclipse+Rebecca?
    Or show me one? XD
    Thanks!
    koolkat6657
    6 years ago on Introduction
    hi this is an awesome instructable can you please send me a snippet of code for playing an animation
    rahul.sonwalkar
    7 years ago on Step 8
    Hey
    I have made a chatterbot at my home. I am ninth grader. I have programmed it in C. i have not used open source programs. Later i was introduced to cleverbot and then AIML . So what do you think making a chatterbot will be easy in C or AIML
    extremeseeker
    wait how do you make the part where you ask the bot?
