BEST DIY Simple Reflex Sight
70,271
729
86
All you need is a CD case, and you get a perfect circular aiming dot :)
Have fun making!
Step 1: Tools and Material
All you need is:
- small saw
- glue
- dremel tool (a hot nail can poke a hole in that too)
- old CD case (maybe 2)
- 3V button cell
- LED (blue LEDs run on 3V, so no other parts needed!)
- pair of pliers or something 90°angled to bend the main part, plus lighter
Step 2: Step by Step Video
THE STEPS:
1. Print and cut out the template (cardboard will work best, paper is too thin)
2. Place it on the clear CD cover, and grab a marker
3. Works best with a small saw: Cutting it out
4. Mark a stripe of 4cm in the center
5. Use a pair of pliers and a lighter to bend it by 90° on each side
6. Cut out 2 L-shaped edges (from another clear CD case lid)
7. Glue them onto the first part.
8. Make the 4 cm wide, 9 cm long centerplate (same clear plastic) and glue it on the L-pieces
9. Grab the black disc-holding part cut out a piece as shown in the video and glue it to the rear
10. Make 2 side plates, and glue them on
11. Glue in a tiny L-plate to make sure, the battery is held in place, same for the LED
12. Glue on a stripe of the clear stuff to cover the LED and battery
13. Time for paint, tape off the exit hole and rear section...then cover it in black, 2-3 layers.
14. Glue in the display and done :)
Make It Glow! Contest
Runner Up in the
3 People Made This Project!
  • Remix Contest
    Remix Contest
  • Pie Contest
    Pie Contest
  • Pocket Sized Contest
86 Discussions
-Selfmade-
3 years ago
Well its the last one you get from me dude....because you seem you dont even understand what I am trying to tell you. Nevermind. Its physics, physics is not for everyone.
Beside that...it says SIMPLE, how can you expect a high end sight? Spend more time MAKING stuff instead of talking about other peoples stuff...another argument you cant beat. Have fun making.
GarethR5-Selfmade-
Reply 3 years ago
Nice job, but what you have made there is a toy, or a prop, it lacks the actual function of a reflex sight, which is parallax correction.
Time spent discussing vs MAKING is well spent if it stops you wasting time making something which doesn't work. It's like "measure twice, cut once".
-Selfmade-GarethR5
Reply 3 years ago
Dude.....it says SIMPLE. You are not a maker, so make a better one, same simple material...then you can give it to me :p Or is it jealousy? Because you cant be serious.
GarethR5-Selfmade-
Reply 3 years ago
I'm not knocking your making, I just don't think a reflex sight CAN be made simply. There's a difference between SIMPLE and NON FUNCTIONAL.
I don't have any ibles up, but trust me I am a maker, I'm mostly done on a cheap, simple to make, 'Hog Saddle' gun clamp. I may make that into an ible if it turns out well. I also recently made a robotic target setup controlled with an arduino, this one: www.youtube.com/watch?v=xU9IJjv8u4U excuse the video, but you'll get the idea.
koden88GarethR5
Reply 1 year ago
Reflex sight can be rather simple, google "telrad reflex sight". It does not use curved glass but regular lens, mirror and flat glass. I bet anybody can make this at home.
alfadog67GarethR5
Reply 3 years ago
Yup. this is cool. And physics IS for me. I hope to be as creative one day.
CamB12
2 years ago
What's the measurement on the template
-Selfmade-CamB12
Reply 2 years ago
Mine was around 35-40mm wide...print it and enlarge. Or enlarge and then print :p
makucho567
2 years ago
please can you send me the plans by email please i cant dowload it
email : makucho02@hotmail.com
KasioE
2 years ago
tanks
MarcosA40SPEEDYGONZALEZ04
Reply 3 years ago
If you have lenses and the knowledge on how to space them to magnify stuff, then sure. i would recommend just using it mounted in front of a preexisting scope. if anything, use google cardboard lenses, or you can break open an old telescope or monocular and use those lenses and just mount one lens directly in front of or on the plastic where the dot is located. now move the second lens around ahead of or behind it until it focusses. if there are more lenses, repeat. this should magnify it. not the best way to do it. Like i said, use it as is and use an existing scope
Reply 3 years ago
-Selfmade-
Reply 3 years ago
Thanks.
Keep an eye on my channel, simple but unconventional bow next.
jellmeistercreativebuilder1
Reply 3 years ago
If you are using the app this sometimes doesn't work with videos. Desktop version they work fine...
SeanJ12
3 years ago
I have a green led I might try this with
