Baby Care Bear Costume
141,489
206
100
About: Check out my etsy shop too! etsy.com/shop/scoochmaroo
What do you do with a baby-sized Care Bear?
You skin it and make a baby-sized Care Bear Skin Coat, obviously!
Whether you use this as a costume or as instant toy store camoflauge, you're going to get more than a couple looks for this upcycled toy!
Step 1: Get a Bear and Gut It
Find a bear that is approximately the size of your baby.
Gut it.
I decided that I wanted to put the zipper around the belly instead of straight down through it.  So I opened the bear under the chin and unstuffed it from there.
Step 2: Fix the Legs
The legs in this bear were sewn shut and flat into the seam.
This will never do.
Remove the legs.
Open the tops of the legs where they are sewn shut.
Remove stuffing from the legs.
At this point, it will help to open up the belly where you intend to put the zipper.  I popped the seam that ran from the chin of the bear down to its leg along one side.
Re-sew legs into leg openings, allowing them to remain open.
Open up the feet and the arms along the seams so that the baby's appendages can stick out.
Step 3: Fix the Head
I unstuffed the head because it was too heavy for the baby to hold up her head.  I mean, I assumed that.  I didn't try it on her and watch her neck collapse.  I was trying to avoid that.
But now the head was collapsey and sad.  So, how to make it look perky without adding weight?
Oh you already know the answer:  zip ties!
Yup.  I taped zip ties in place to act as boning in a corset would.  Then, once I was pleased with the general layout of them, I sewed over them with a whipstitch and secured them at both ends.
It totally worked!
Then I added a bit more stuffing loosely just to give it a more cuddly look.
Step 4: Add Lining
Now to add a lining so the stuffing will stay in the head and the baby won't get scratched by all of the open seams.
My head lining was a fail, so I need to offer better advice.
It seems obvious to me now that you need to but a hood shape into it.  At the moment of execution, though, I was baffled.  Consequently, there wasn't enough room for baby's head and we had to make an emergency field operation.
Cut a hood shape out of some fleece (or knit, something soft), and seam along the center back.
To line the body, I turned the bear inside out and pinned fabric all along it.  I cut off the excess and created one large dart along the heiney area.
To finish, use a smallish whipstitch.  You could get this under your machine, but I thought it might be more hassle than it was worth.
I also sewed a circle of felt behind the belly.
Step 5: Apply Zipper
You'll want a heavy duty plastic zipper that is at least the length of the opening.
Mine was a separating zipper, but that turned out to be unnecessary, and even inconvenient.
Pin the zipper along one side of the opening and hand sew it in with a backstitch.
Carefully align the other side of the zipper with the other side of the opening and sew.
Tack down the raw edges of the zipper.
Step 6: Insert Baby
Find a really chill baby, and convince them of how fun it would be to dress up like a bear. Rawr!
Surround with other toys, a la that scene from ET.  As if you needed to add cuteness.
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    100 Discussions
    BoredInClass
    9 years ago on Introduction
    I know the baby is wearing a red bow in the second feature picture, but it adds to the adorable factor that it looks like the Care Bear has bloody fangs-! ^^
    parisusa
    2 years ago
    Looking at this in November 2016 and know this baby is now about 6 years old but these photos are so precious!
    swings_jo
    5 years ago on Step 6
    This is awesome and cute!
    But are those fangs?
    ElPounse
    5 years ago on Introduction
    Having just constructed this, using Funshine bear procured on eBay, a few tips:
    - Buy really big cable ties. Only takes 4 to get the super structure in there. I used a combination of sewing and glue gun to secure them.
    - Instead of stuffing, use packing balloons from your latest diapers.com delivery to fill the head. Really lightweight!
    - If you are pressed for time, skip the lining, and just make sure your little one is wearing long sleeves.
    - Seal the bag of Care Bear guts, lest your dog wrestle the bag open and shower your floor with polyfill.
    onemoroni1
    This is the most adorable instructable I have ever seen. Happy trick-r-treating!
    onemoroni1onemoroni1
    Reply 5 years ago on Step 6
    I just remembered years ago when Starwars came out we dressed as characters, took a week. I was 3PO with R2D2, wife was Princess Leah, teenage son Luke, other three boys including the 1 year old were Jawas. Sorry no pictures, but it was fun going door to door. Thanks for bringing the memories back and sharing.
    orchidblack
    Oh my gosh this instructable is awesome and the baby even more so ... I was giggling with every photo! ^_^
    poppop159
    5 years ago
    That is very very cute
    sneakyparasol
    8 years ago on Step 6
    i wish i had a baby just so that i could make this costume. i think it is probably the most adorable thing I've seen in my entire life.
    Celine1107
    7 years ago on Introduction
    That baby is SO cute! Absolutely a cutie!! The costume just makes it EVEN cuter!
    U456
    aww soo cute if you don't add the fangs it would look cute as a button! :)
    hhornburg
    7 years ago on Step 6
    THIS IS ADORABLE!
    you've made my day :D
