Babybel Candle
34,253
36
10
Eat lots of mini Babybel but never know what to do with the wax? Tired of shelling out the big bucks for tealights? Then boy, have we got the project for you. Using common household items, you too can make your own Babybel candle.
You’ll need:
  • Tissue
  • Mini Babybel cheese
  • Metal cap. We used the screw cap off of a bottle of sake.
  • 2" x 2" piece of aluminum foil (optional)
  • Lighter
  • Flat nose pliers (optional)
  • Glass jar (optional)
Step 1: Step 1: Making the Wick
  • Tear off a small strip of tissue, about the width of a finger and the length of the wax paper pull-tab. You’ll only need a single ply, so separate your tissue if it’s 2-ply.
  • Twist the tissue into a wick.
Step 2: Step 2: Adding a Base
  • Fold your wick in half.
  • If you haven’t eaten your mini Babybel, do so now. Save the wax coating and wax paper.
  • Take the wax paper pull tab and wrap it tightly around the middle of the wick. This will be the base of your wick.
Tip: if you want a brighter flame, wrap the pull tab close to the two ends of the tissue. If you want a longer-lasting flame, wrap it closer to the folded-over middle.
Step 3: Step 3: Adding Wax
  • Take the two wax halves and smush them one on top of the other.
  • Take your mini-wick and place it inside of the wax nest.
Tip: Separate the two bottom prongs. We found that this keeps your wick from listing to the side when the wax melts.
Step 4: Step 4: Shaping the Candle
  • My favorite step. Take the wax and mash it inward into a ball.
  • Just remember to fold it over and around the wick bottoms.
Step 5: Step 5 (OPTIONAL): Lining the Cap
  • If you want to use the cap again, line it with aluminum foil.
  • Tear off the edges for a neater look.
Step 6: Step 6: Lighting the Candle
  • Place your candle in the cap.
  • Light it.
Tip: Try not to use plastic caps. Paraffin melts at about 130°F...which is also the melting point of polypropylene, which is what most plastic bottle caps are made of. Cleaning congealed plastic goo out of a narrow glass jar is just not fun. Trust us.
Step 7: Step 7 (OPTIONAL): Placing the Candle
  • Using the pliers, carefully lower the lit candle into the glass jar.
  • You don't have to, but the jar keeps stray breezes from blowing out the candle. Plus it's prettier.
Step 8: Step 8: Enjoy!
  • Each Babybel candle will burn for about an hour, giving you more than enough time to drink your sake, eat another mini Babybel, and make your next candle.
  • Trash to Treasure
    Trash to Treasure
  • Organization Contest
  • Tape Contest
    Tape Contest
10 Discussions
CherylI
1 year ago
I actually melted mine with silicone based makeup foundation and made a dream mousse along with the cyclomethicone and dimethicone from a product halled hair polish and a tad of titanium dioxide. Ultimate coverage.
MrKozf
2 years ago
Hey, nice DIY project!
I actually tried this, but after some research, turns out that paraffin wax (babybel wax) is actually toxic and could really harm your lungs.
So for you and everyone else's safety I would highly recommend finding other creative ways to reuse babybel wax instead of a candle, unless you want your house air and lungs polluted.
Have fun and stay safe guys.
JessicaC108
3 years ago
I have to ask, does it smell "CHEESY" at all? lol Or does it pretty much
smell unscented? Nothing like melting a nice wax melt with a top note of cheese....just curious before I make my own-thanks
baileejade
3 years ago
I used mine as a wax warmer!
AC-ACcharlieanderin
Reply 4 years ago on Introduction
Does it have a twist cap? The crown cap ones might not be deep enough. Or you could try olive oil caps if you can get the plastic lining out.
