Backyard Chicken Coop
854,552
718
125
About: Dad and hubby, good food enthusiast, solar energy, boating, making stuff, melting stuff, and raising chickens.
I made this little chicken barn a few years ago to house 3-5 laying hens in my back yard. I'm in town and had to design a "pretty" one to keep people from having a chicken coup (ha ha). This one was inspired by some Kansas barns I've seen. I spent about $40 when fully completed. Chicken wire, some 2x4s and damaged siding were the costs. Damaged siding is half price at my local lumber store. Other things used were scrap wood from old bathroom cabinets, leftover hardware, paint, and wood from house projects, and lot of scraps and hardware from a condemned house down the street (I got permission to take things before they bulldozed it.) Shingles were given by my neighbor leftover from roofing his garage.
There are some basic rules for designing and running a good healthy chicken shack:
1. Adequate floor space per bird.
2. Dry with good ventilation.
3. Temperature control.
4. Predator protection.
5. Keep it clean + fresh water/food = happy & healthy birds.
Many towns actually allow up to 5 chickens but no roosters. Check local rules on this if you plan to build. If you do get chickens in town, be courteous to the non-chicken majority so the rest of the city chicken people don't get punished through politics and zoning.
I submitted pictures of this coop to someone who was working on a coops book a while ago and they included a picture of it in "Chicken Coops, 45 Building Plans for Housing Your Flock." By Judy Pangman
Sources for my chicken knowledge:
"Building Chicken Coops" Gail Damerow
The City Chicken, http://www.thecitychicken.com/
Backyard Chickens Forum, http://www.backyardchickens.com/f/
FeatherSite - The Poultry Page, http://www.feathersite.com/Poultry/BRKPoultryPage.html
I recently posted another coop, a chicken outhouse with a beer can roof at diylife.com
Supplies:
Step 1: Floor Space, Framing, and Nest Boxes
My floor space includes the exterior run. I knew I wanted 3 heavy egg layers, so from the charts I used 10 square feet per bird rule. There are different suggestions in different books/guides; this link has a pretty good chart: Virginia Tech Small Scale Poultry Housing PDF.
I built this 18" off the ground to create a shady part of the pen underneath the coop.
The floor is 2x4s framed like a little porch 3 feet by 4 feet sitting on 4x4s attached with many 3" screws.
The walls are just under 4' tall and I used 3" screws to put together the 2x4s. 4' walls are a good dimension because siding and plywood come in 4'x8' sheets.
I framed in nest boxes here. I think a rule is one box per 3-5 laying birds. They like dark, comfy places to lay. Making the boxes the size of a 12" dust pan works great when cleaning the coop. Lots/all books suggest elevated boxes, but these floor boxes have worked great for three years now.
Avoid treated lumber inside the coop or where they perch; the toxic stuff can affect the birds (ie. sickness/death)
Step 2: Roof
I don't have many step by step pics for this so you'll have to use your skills to fill in the gaps.
I cut 2x4s with angles to make three sets of rafters and attached them with three inch screws. I screwed down some old cabinet wood across the rafters to make the roof, leaving a little 4" hole near the center peak for a cupola. Then I shingled the roof leaving the center peak hole open.
The cupola is made like a little bird house that sits over the vent hole. Use a hole saw to make holes in it's sides and staple window screen on the inside to keep out the critters. Attach it with 3" screws.
This helps meet rule #2.
Step 3: Walls
Cut the siding to fit the framing and attach with nails. Use a jigsaw to cut out doors and other openings; save the cutouts for building the doors.
Keep the following in mind while designing walls:
  • Make openings for windows; this is important for summer heat control.
  • Build walls tight to keep out wind and drafts; this is important for winter cold control.
This is a standard chicken coop rule: Have good ventilation but no drafts.
Step 4: Doors
A main door to access the coop and a small chicken door are the only doors really needed.
But I added cabinet doors, a nest box door, chicken door and a main door on this thing.
Hinges were from old bath and kitchen cabinets.
The main door is made with old porch flooring. Boards were attached diagonally to the siding cutout with nails; then I used the jigsaw to clean it up around the outside. This made a more old fashioned looking door. The nails will stick out the back side, bend them over or cut them and grind the stubs smooth.
The other doors were made directly from the siding material and some trim wood. I just attached hinges and handles with some trim around the edges. The trim is important to close the gap from where the saw cut the siding. I added some plastic near the top to shed rain over the cabinet doors.
Step 5: Finishing Touches
Add the roost perch for night-night time.
Make a perch out of a 2x4 with the edges rounded a bit. Under the perch make a place for the poop to gather. This roost area is usually the only place that gets poop inside my coop and makes cleaning easy. (Don't use treated wood!)
When I finished the coop, it ended up being very heavy; so I attached some boards to the bottom and used a hand truck to wheel it (with help) to its home location.
The run/pen can be made easily with 2x2s and 2x4s as seen in the pic below. I enclosed the top of the run to keep the hawks out. I later added a matching run on the opposite side when I added some more hens.
Step 6: Extra Notes
UPDATES: I've changed the coop a little over the years to allow for more birds. I've removed the storage area and added a roost in its place.
Also, I've removed the small pen and made a large run for the birdies.
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    125 Discussions
    shalnachywyt
    7 days ago
    Lovely coop, but use hardware cloth instead of chicken wire unless you want raccoons, possums and other critters to get in and kill your chicks. I've had my chicks for 4 years or so and keeping the predators out is imperative.
    You can learn more about it on stodoys website I think.
    JazziWorld
    2 years ago
    I am thinking about adopting 3 chickens and live in a warm climate. The temp ranges from 30-110 degrees farienheit. Is that an ok range for chickens? and is there anything else I need to know before adopting them?
    Farmer girl228JazziWorld
    Reply 1 year ago
    chickens need at least 75 degrees so when temperatures drop by a chicken lamp and they will stay warm
    robbtoberfestJazziWorld
    Reply 2 years ago
    Anytime you're worried about heat problems with animals, fresh water and shade are very important. Make sure the coop is ventilated well. Check the water so it doesn't stagnate and provide a shaded area for sure. Good luck and enjoy the birdies!
    jkbruce
    9 years ago on Introduction
    I got my 4 hens a year ago and now I have a rooster. I only have one hen sitting at this time my question is this when do I need to take the rooster out of the pin and for how long? And also how long does it take a egg to hatch?
    stormy0314jkbruce
    Reply 6 years ago on Introduction
    Don't need a rooster for hens to lay. You just end up with non-fertile eggs. Also, if you put a light on a timer, they will lay all year if they get 16 hours of light a day. (Same goes for plants inside. If you give plants light for 16 hrs. a day, and warmth of course, they will produce all year.
    stormy0314jkbruce
    stormy0314jkbruce
    JordanWalker
    5 years ago on Introduction
    It looks like the predators in town are not having any chickens tonight.
    This is an awesome design!
    Thank you for sharing to us these helpful tips on how to raise chickens in the backyard with less expense. You were very creative and at the same time saved resources by using scrap materials.
    Your design is great since you have fence that will protect your chickens from predators in town and at the same time a guard puppy.
    I will be building one for my chickens soon.
    Rudy1
    Nice coop....I don't suppose I would be lucky enough for you to be in Wichita? I have built a small coop and then bought one of those rabbit/chicken coops from someone off CL. Well I have also added to my flock and need a larger coop. I love the inside of yours and the idea of building it without much cost. Are the plans all in the book you mentioned? Thanks and enjoy!!!
    robbtoberfestRudy1
    Thanks, I'm not in Wichita area anymore (I miss it but Colorado is nice). The book features only a picture; this Instructable is probably the best "plans" layout. I'm working on a 3D drawing of a wall mounted chicken coop for four hens; if you're interested I can send you that.
    stumitch
    we have 3 chicens. but they keep askaping. We tried clipping there feathers but they still got oat.
    czelly
    Thank you very much for this article! Your chicken coop looks awesome! Also the fence for the predators is an excellent idea! I also built a few chicken coops within the last years! I uploaded a photo of my current one:
    I also opened a blog about building a chicken coop! If you are interested please visit my site and leave a comment. I do not have that much articles there right now but I will write more within the next days.
    iguana15czelly
    Nicely done, more like a chicken "Coop de Ville".
    Good blog, will post a comment there too.
    mcaliber.50
    i''m looking to get chickens in the next year or so, i have a nice spot that would be perfect for 2 or 3 (thats the most i want) next to my garage, but it's a little small for the one here, but it's still pretty cool
