Ball Balancing PID System
92,925
767
158
This system holds a ball in balance on a plate. A webcam films the system and a python program analyzes the images to find the position of the ball. The python program calculates the tilting of the tray to prevent the ball from falling.
A proportional-integral-derivative (PID) regulator is used to compensate the movements of the ball. The position and speed of the ball are measured by the camera and these measurements are used by the PID regulator in the python program.
Sorry about the English faults, it’s not my mother tongue.
Step 1: PCB
PCB manufacturing
I drew the pcb with eagle then PCBWay.com manufactured it.
PCB assembly :
I soldered all smd components without paste flux. I don't recommend you to do like me. Instead, follow this tutorial to solder smd components: https://www.instructables.com/id/SMD-Hand-Soldering/
The PCB is powered with a 5-6v 2A power supply.
PCB components :
Role of the PCB
The PCB communicates with the computer continuously. This PCB serves only to control the servomotors.
Step 2: 3D Printing
Warning : inferieur.stl, superieur.stl and plateau.stl files are not 3D printable. inferieur.stl and superieur.stl are made of acrylic. You can use a CNC to make these parts, but you can also cut them yourself in an acrylic sheet because these parts don't have a very complicated design. plateau.stl can be cut in cardboard.
Step 3: Parts Assembly
Step 4: PCB Programming
The PCB contains the same microcontroller as the arduino leonardo. Therefore it can be programmed with Arduino software. The code can be downloaded here.
Before programming the PCB, you have to burn the bootloader: Arduino as ISP and Arduino Bootloaders
Burning the Bootloader
  1. You need an Arduino
  2. Upload the ArduinoISP sketch (arduino software / Examples / ArduinoISP) onto your Arduino board
  3. Make the connections as in the picture
  4. Select "Arduino Leonardo" from the Tools > Board menu.
  5. Select "Arduino as ISP" from Tools > Programmer
  6. Run Tools > Burn Bootloader
  7. The process can take several minutes.
  8. Disconnect all cables.
After this step you have to connect the pcb to the computer with a USB cable and upload this code.
Step 5: Python Program
The most important code is in the computer that controls the system. You can find the code here.
How does it work. The first step is to find the position of the ball. The camera sends the computer live video. The python program receives the video and has to process it. I use the OpenCV library to do the image processing. The program detects the ball thanks to its color. Here the ball is orange, the program will then average the position of all the orange pixels of the image to find the position of the ball. With OpenCV all this is quite simple. I recommend this tutorial for color recognition with OpenCV: https://www.pyimagesearch.com/2015/09/14/ball-tracking-with-opencv/
Now that we have the ball position we can calculate the inclination of the board with PID (proportional, integral, and derivative) control. The regulation is done in three stages. The first step is the simplest. Imagine that we want to stabilize the ball in the center of the board. The further away the ball is from the center, the more it will be necessary to tilt the board. Then you have to measure the speed of the ball: the faster the ball moves away from the center, the more you have to tilt the board.
Step 6: Conclusion
Thanks for reading! If you have any questions, do not hesitate to write a comment.
You can also vote for me in the PCB contest.
PCB Contest
First Prize in the
PCB Contest
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    158 Discussions
    AmélieG3
    Question 14 days ago
    Salut Johan,
    Je suis étudiante et je me suis mise à faire ton projet avec un pic24fv16km202 à la place de l'arduino. J'ai donc regarder tes équations qui sont dans ton dossier en annexe mais je sais pas pourquoi il y a des cos(30) et sin(30) pour déterminer les angles teta des servomoteurs.
    Si tu peux me l'expliquer j'en serai très reconnaissante.
    Merci d'avance,
    Johan LinkAmélieG3
    Answer 11 days ago
    Hello,
    Le but de toutes ces équations est de trouver le lien qui existe entre les angles alpha, beta (angles qui détermine l'orientation du plateau) et les angles teta des servomoteurs. J'ai fais un schéma qui devrait t'aider à comprendre d'où viennent les cos30 et sin30. Sache que même si tu n'arrives pas à utiliser mes équations tu peux directement utiliser le fichier "data.txt" qui est une table de correspondance entre les angles alpha, beta et les angles teta.
    J'espère que mes explications vont te permettre de mener à bien ce projet.
    N'hésite pas à m'envoyer des photos du projet, ça m'intéresse beaucoup :)
    GK93
    Question 17 days ago on Introduction
    Salut Johan,
    dans le cadre d'un projet, nous reproduisons le Ball balancing PID system
    peut-tu nous fournir plus d'informations sur les equations si possible
    cordialment,
    1 answer
    letitgo
    4 weeks ago
    Hi Johan,
    I constructed your Ball Balancer, but I am getting the following error code thrown up every time, can you help?
    cv2.error: OpenCV(4.0.0) /Users/travis/build/skvark/opencv-python/opencv/modules/imgproc/src/shapedescr.cpp:272: error: (-215:Assertion failed) npoints >= 0 && (depth == CV_32F || depth == CV_32S) in function 'contourArea'
    Johan Linkletitgo
    Reply 4 weeks ago
    Hello,
    I noticed that you have to replace line 421 ("cnts = cnts [0] if imutils.is_cv2 () else cnts [1]") by "cnts = imutils.grab_contours (cnts)" when using OpenCV 4. This solution works for me, I hope it will work for you too.
    AreJayJay
    6 weeks ago
    Hi Johan, I have a question regarding the camera. I've included a image so that you can tell me if the frame width is OK. Seems a bit wide to me but I may be wrong.
    I installed everything on a Raspberry pie thanks to Adrian @pyimagesearch.
    Johan LinkAreJayJay
    Reply 6 weeks ago
    Hi,
    Does the system work ?
    Is there latency with the Raspberry pie?
    It looks nice!
    AreJayJayJohan Link
    Reply 6 weeks ago
    Hi Johan,
    I haven't completed my tests yet, but it looks promising. I can see some latency, so that can be an issue I guess. FPS is 24.
    What do you think?
    AreJayJayJohan Link
    Reply 5 weeks ago
    Hi Johan,
    Is the default ball color supposed to be orange ?
    I find that the color is blue on my RPi, which is kind of the complementary color.
    Is this normal?
    Johan LinkAreJayJay
    Reply 5 weeks ago
    Hi,
    There is no default color. You have to right click on a color to select it.
    AreJayJayJohan Link
    Reply 5 weeks ago
    Hi Johan,
    OK for the right mouse click to store the color but what are the HSV sliders for on the interface program?
    AreJayJayAreJayJay
    Reply 6 weeks ago
    Hi Johan, please forget that question, I simply forgot to consider that the 'plateau' will raise to a position that centers it.
    GarryTaank
    6 weeks ago
    Great work!!
    Best example to demonstrate the effectiveness of the PID control algorithm.
    Jerryolsen
    3 months ago
    John, again great work, very impressive.
    I had to make some modifications to get the
    python code to work my Windows 10 system.
    1) Line 527: Removed background=black so the button will show.
    BConnect = tk.Button(controllerWindow, text ="Connect", command = connectArduino)
    2) I’m using an Arduino Nano for servo control. My system does not return “Arduino” in the port description. I printed the port and it returns “CH340”. I modified line 273 in the connectArduino() module to account for it:
    if "CH340" in p.description:
    Hope this will help anyone else using Windows.
    Johan LinkJerryolsen
    Reply 3 months ago
    Thank you for those modifications that will help many people !
    Araujo04Johan Link
    Reply 7 weeks ago
    Hello! Beautiful design, congratulations! I'm reproducing.
    I'm using an Arduino Uno with Ubuntu Linux system. I can already do the mapping of the ball, but I can not establish the connection with the arduino. I made the impression of the port "ttyACM0" and replaced in line 273 of the code "Arduino", but it did not work. Any tips to help?
    Johan LinkAraujo04
    Reply 6 weeks ago
    Hi,
    Did you write "print(p.description)" to print the port ?
