Baked Banana Tart
767
57
This is a great treat for banana lovers. With a sweet gooey center and lovely crisp pastry this is a fabulous dessert.
Step 1: Ingredients
Tart shell:
  • 1 egg
  • 225g flour
  • 125g butter
  • 1 tsp lemon juice
  • 1 tsp water
  • pinch of salt
  • 1 tsp baking powder
Filling:
  • 2 banana's
  • 1 egg
  • 30g butter
  • 60g sugar
  • 1 tsp lemon juice
Meringue:
  • 4 tbsp castor sugar
  • 2 egg whites
Step 2: Rubbing the Butter
Cut the butter into cubes about 15 millimeters square. Sieve your flour, baking powder and salt into an empty bowl and add the butter cubes.
Use your fingers to rub the butter into the flour mix until the texture becomes like large bread crumbs. Set aside.
Step 3: Eggs Now...
Beat the egg with a fork and add lemon juice and water. Add this to your pastry mix and form it into a ball.
Step 4: Prepare Your Pastry Dough
Flatten the dough into a thick square and cover it with cling film. Put the dough in your refrigerator for about 1 hour and it's ready to use.
Remove the cling film and using a rolling pin flatten the dough into a sheet about 5 millimeters thick.
Step 5: Shaping Up Nicely
Using a small baking tin with a removable base, approximately 10 cm round and 6 cm high. Cover the removable base foil then lay the sheet of pastry on top of your tin and mold it into shape.
Step 6: Baking Beads
To stop the pastry from rising out of shape I have used some baking beads to retain it's shape. You can also use uncooked rice for this task.
Bake the pastry case at 180C (360F) for 10 minutes or until golden brown. Leave the pastry in the tin until it is filled.
Pro tip: Baking beads are made of ceramic and are a great addition to your baking equipment.
Step 7: Banana Filling
For the filling you will need:
  • 2 banana's
  • 1 egg
  • 30g butter
  • 60g sugar
  • 1 tsp lemon juice
Step 8: Butter and Sugar
Put your butter into a shallow pan over a low heat and add the sugar and lemon juice. Cook until it becomes a semi-thick paste.
Step 9: Egg
Beat the egg then add in 1 teaspoon of the butter and sugar mixture.
Step 10: Fulfilling the Tart
Add your egg mix to the butter and sugar paste and mix to a smooth consistency over a low heat.
Mash the banana in a bowl and blend it into the pan mixture and cook for a further minute then remove from heat.
Step 11: Filling the Tart
Pour the banana filling into the tart shell, (which is still inside the tin).
Step 12: Meringue
For the meringue combine your sugar and egg white and whip it until it has soft peaks. Scoop this onto the top of your tart. Any left over meringue can be baked on a piece of baking paper and enjoyed later as pavlova.
Place the tart in the oven for 10 minutes at 180C (360F) until lightly browned.
Step 13: Cooked and Ready to Eat
Here we have a finished 'Banana Tart'. With a gooey filling and pastry shell this treat is for those who enjoy a banana treat.
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    He Se
    2 years ago
    Wow this looks very tasty!
