Band Saw Boxes
2,076
42
5
About: Love making things and using my workshop.
Materials
-band saw
-Log (Whatever size box you want is determined by the log size.)
-pencil
-wood glue
Step 1: Cut Log to Length
(I drew these pictures to make it easier to understand.)
Step 2: Remove Bark
(I was able to just peal it off with a knife on some of them.)
Step 3: Slicing Segments
Step 4: Removing Core
Step 5: Gluing Seam
(I wrapped it twice for a tighter grip.)
Step 6: Top and Bottom Inset
Step 7: Cutting Scribe Lines
Step 8: Sanding
Sand the edges, and make it really smooth on outside. DO NOT sand on the bottom inset's sides, but DO sand on top and bottom of it.
Step 9: Locate Top Inset and Glue
Step 10: Gluing Bottom Inset
Step 11: Done!
It is pretty easy to make once you get going after a couple. I probably broke 2-3 before I was able to get the finale product. But trial and error is a great thing.
-If you have a question about something leave a comment and I will address it.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    5 Discussions
    uncle frogy
    3 years ago
    wow I wish I could handle a pencil as well as you can the drawings a good by themselves.
    I have made band saw boxes a little differently.
    I cut the top off blank then core the box out then cut a piece off of the top of the interior blank to glue on the bottom of the top and cut a piece off of the bottom of the core to glue in place of the bottom I use epoxy and am left with a larger interior piece to make a smaller box with. the best ones are made with very complicated grain. like that found in stumps and multiple crotches
    uncle frogy
    kbc2
    4 years ago
    did a box like this using a bridge port mill, cnc router would not accomplish the depth i wanted. but dig your design and method! very cool.
