Basic Beginners Mini 3 Axis CNC Mill
38,187
508
12
I've been a CNC machinist just short of 20 years. Owned a Fadal 4020 with extended Z made some neat gadgets with it. About 5 years ago after illness I started back working and looked into and purchased some micro-controllers. All with the idea of building my own little machines. And explore what makes it all tick. Above are two pictures of where my build started and ended over a 24 day period. I'll be doing updates and more instructables around this project in the future. Please enjoy and criticize where needed my first Instructable and CNC competion.
Step 1: CD Tray Axis Mods
I pulled 2 of these trays from CD players in my junk pile. Purchased the 3rd at a thrift store for $7.
Remove the CD spin motors and set them aside for spares.
Cut 4 x 1/4-20 all thread 1.25" long. Gather 12 nuts as well.
Small hardware for limit switches:
2 x 2-56 screws (x & y axis)
4 x 2-56 nuts
1 x 6-32 stud (z axis)
2 x 6-32 nuts
(use what's available or necessary due to variations)
Pic one show all the materials less the small hardware.
Pic two shows on-board limit switch, 6pin port, and 5v motor.
Pic three shows the various switches found in the lids of CD player.
Pic four shows the pinouts we can use (use for referance later on).
Pic five shows the all thread stabilizer mount.
Pic six shows tray variation on stabilizer mount.
Pic seven shows the screw and switch used for X and Y axis.
Pic eight and nine shows switch positioning. Used an existing hole on both X and Y axis trays for attaching. Had to open diameter up for clearance on my screw(2-56).
Pic ten we wire the new add-on limit switches to CD spin motor points on PCB.
Pics eleven thru thirteen show bracket and other limit switch variation. As well as pit falls to hopefully avoid.
Step 2: Lower (Y Axis) Mount
This here is the lower base(Y axis) and should/could be the base plate for all axis's.
Pic one gives basic dimensions
and shows parts list.
1 x 1/4 plate per dimensions
4 x 1/4-20 all thread 2" long
12 x 1/4-20 nuts
8 x 1/4 flat washers
Pic two shows all thread stud construction. Screw into plate till their flush on bottom. Use a nut to lock it to plate from the top.
Pic three shows fitting an axis tray. Watch the limit switch we added. I had some minor interference and adjusted around them.
Pic four shows completed build and dimensions to hold.( 1.375" for reference).
Step 3: My Crazy X Axis Cradle
I made this early on it looks good and works well but is unnecessary. You can use previous lower plate and add the 6-32 all thread as shown in pic four. Follow pics for theory. Note the 1.250" dimension in pic three.
If you go with all plates for holding the axis trays, use 4.00" x 3.15 for outside dimensions.
Hardware you'll need:
4 x 1/4-20 all thread 1.750" long
12 x 1/4-20 nuts
1 x 6-32 all thread 1.625" long
2 x 6-32 nuts
1" x .75" x .125" square washer with .145 dia. hole thru(custom made)
Step 4: Joining the X and Y.
Pic one shows the thru hole. Also there were some tabs that stuck up here. I filed them down to have my cradle sit flush. When we fit the table I'll show you how to avoid the file job.
Pic two shows the custom washer plate and 6-32 all thread holding axis's together.
Pic three is the completed lower assembly.
Step 5: Z Axis Plate
Pic one shows hole patterns for the U bolts and hole sizes. Also note we drill .250" thru holes instead of 1/4-20 thread for axis tray attachment.
Pics two to four show the build.
Pic five shows our 1st booby trap. Had to bend tab out if the way.
Step 6: Main Base and Column
Pic one shows an old indicator base I've had around for awhile.
Pic two shows the axis assemblies mocked up on it.
Step 7: H Bridge Motor Drivers, 555 PWM Circuit, and Manual Control Buttons.
Pic one is one if three H bridges you'll need. I've shown where signals go in. Note that one yellow wire is of position by one from the 1 k resistor this is wrong sorry.
Parts list for one H bridge:
4 x 4401 NPN transistors
4 x 1N4007 diodes
4 x 1k resistor
Various jumper wires
Pic two shows the three H bridges and corresponding axis.
Pic three is a 555 PWM circuit. I have this here just for manual speed control. It's some what functional I found myself bypassing it for more power.
Parts list:
555 timer IC
100k potentiometer
.01 uF capacitor
.1 uF capacitor
2 x 10k resistors
Pic four is the manual button control.
Pic five is the connections between button and H bridges.
Pic six shows an overall layout.
Step 8: Motor Wires and Manual Tests.
Pic one has the 6pin port scavenged along with CD tray. It has been connected to a barrier strip. I've cut wire and connected to the other side of barrier strip.
Pic two shows wires used green/white for limit switches and black/red for motor.
Pic three shows the X axis connections. Once its wired up you can use 5v power from microcontroller to test it. If the limit switches are set right you'll get a bounce back effect. If their backwards it will jam the gears. Reverse your green wires to fix.
Pic four shows testing of other H bridges and buttons.
Pic five shows 6pin port in use.
Make sure to check all axis's and H bridges.
Step 9: Attaching the Table
Pic one shows hole diminsions for depths. The all thread attachment screw should be centered on plate. The other two are for attaching fixtures/subplates.
Pics two thru five show the build.
Pic six the finished assembly and mock up candy chuck.
Step 10: Mechanical Encoder Wheels for X and Y Axis.
Pic one shows a PS2 mouse I picked up for .99 cents(grab a few actually). I found all kinds of neat parts in there.
Pic two shows the front and back of the mechanical encoder wheel.
Pics two thru nine show the build and pit falls I fell in. This is a work in progress. I'll be investigating these devices abit.
Step 11: Original Test Spindle and New Revision
The spindle is my bane so far. Needs more work. But I've had some success.
Pic one shows some initial test parts and manual work.
Pic two shows my simple flex shaft holder. Worked fairly well.
Pics three thru five show some details on my new spindle holder also a work in process. Almost decided to make a CNC lathe to avoided it.
Step 12: Secure the Axis's to Main Base and Column
Pics one thru four show securing the axis assemblies to base and column.
Pretty simple here.
Step 13: Wiring Axis Trays and Encoders to Microcontroller.
Pic one reminds me of my Z axis bane.
Pic two has us adding a barrier strip to both encoders. Only one is shown here.
Pic three shows the X axis motor/limit switch hook ups. Used zip ties to secure barrier strip.
Pic four shows the Y axis motor/limit switch hook ups. Left it un secured Y axis motor stays stationary.
Pic five shows the Z axis motor/limit switch hook ups.
Pic six details the X axis encoders barrier strip.
Pic seven details the Y axis encoders barrier strip.
Pics eight thru ten show the hook ups to microcontroller and breadboards.
Step 14: Final Wiring of Motors, Limit Switches, and Microcontroller.
Pics one thru three show wire management for microcontroller to H bridge. And motors/limit switches to H bridge.
Pics four and five show hook ups for the Vdd(positive+) on the limit switches.
Pic six show the motors to H bridge hook ups.
Pic seven shows the limit switch normal open wires. This takes some debugging to get right. I flagged wires with tape(yellow arrows) once i knew what was what.
Pic eight is the microcontroller hook ups it also required some debugging to get right.
Step 15: The Candy Chuck and Manual Cuts
I turned up the candy chuck on my mini lathe. And used it for some manual test cuts.
Pics above show some drilled orange candy and a cherry "rune" stone.
Step 16: Safety Shield and Pbasic Code
Pic one is a safety shield i added on an adjustable arm.
Pic two is a screen shot of my Pbasic instructables MDI CNC test terminal.
Pic three the over all end for now.....
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    12 Discussions
    jdelaney44
    4 years ago on Step 16
    Bravo! These things involve a mind blowing number of wires huh?
    Do you know if the "wonkyness" of the tool path is from the spindle, the x/y platforms, both? Something else?
    Thanks for the write up!
    Unclejakejdelaney44
    Reply 4 years ago
    Couple factors overzealous manual button operator(me), using a center drill .032 point, and materials (wood had grain issues, candy melts at high speeds). I'm cleaning up the wires and testing my code. Making videos and how to operate manual.
    jdelaney44Unclejake
    Reply 4 years ago
    Thanks for the reply!
    I did a CNC conversion of a Bridgeport a few years back. I still think I am having issues with noise either adding or blocking some steps. I get creep on x/y during long (10 hour) operations. Short programs work fine.
    Bigger machine yeah. Same control problems ...
    One other guy thinks, and I agree, that regulating my power supply will help too.
    I'd be interested to see if cleaning up the wiring helps. I had some problems early on that I did isolate with a scope to noise. After shielding the crap out of everything and putting ferrite doughnuts on everything I could not shield I got that to go away.
    Again, good work man! I really like that you did so much with old CD & mouse parts!
    geraldpaxton
    4 years ago on Introduction
    I'm always tinkering on projects and researching, 25 years ago I built automated welding systems with a custom multiplexed serial terminal and Galil servo controllers running amps to motors as large as 10 HP, using an 8086 processor programmed in Forth in an STD card cage. It is amazing how much control costs have come down and what's available for repurpose....that $6000 filled card cage can now be replaced by an Atmel microcontroller on an $80 card with 'free' software platforms. Progress...Amazing! Some thoughts on heavier hardware...check out the ballscrews from hospital type beds and power lift chairs and the shafts from dot matrix printers.
    dollarseed
    I love the idea of starting small, and proving the concept. I myself built the CNC Monster pictured. Have still yet to get it running, but will be using Mach3 as the running platform on an old WinXP computer. I began this build last November, and still have a ways to go with it. Sure wished I'd of learned about Arduino, that would have saved me a fortune in parts and time. Great build and concept. Love the use of old parts.
    Unclejakedollarseed
    Reply 4 years ago
    I think it was 1998 when i saw the Smithy 3 in 1 with Mach3. Probably in a popular mechanics issue. Had planned on building a few. Goofed and bought a big machine. The costs to move are huge. Now like you said so many microcontroller options. Attached is a pic of some Anilam screws( they are new but shop was gonna throw away i took em home) and a bridgeport style 220 spindle motor. It will be a bit before they get built into a good size machine. My Father just retired he was and old tool and die machinist. Once we finish his old 44 GMC flatbed, I'll Shanghai him for my projects.
    Unclejake
    4 years ago
    I'm using an old gateway with Windows xp, a parallax BS2 developer board, and BASIC stamp editor 2.5.
    I have code I'm working on for the encoders. I'll post that soon in it's rudimentary state. I'm still reading up on and studying embedded languages. I was doing light test cuts in candy lastnight with the Y axis using the encoder as an off/on counter.
    Im happy with it it's definitely a good tool to study and mess with code so far. Will be a long term project to improve and have fun with.
    Ty all for the comments.
    padbravo
    Sorry if i missed it... but, what software (pc and controller) are used here? for what OS?
    MA2IK
    man.... that tight as shiz!!!!! Im impressed bro... have you heard of the tinyg?? I picked it up from inventables and it sure is bad azz ...runs g-code!!! I just ordered some nema 34 stepper motors and drivers to try out with it. Ive been programming cncs for about ten years now and just started getting into electronics myself. I like seeing stuff like this. motivates me into making my own instructable. keep up the great work man!! looking forward to see you next project.
    acheide
    You put a lot of effort into this! I like the way you encorperated various used technology bits.
    Thank you.
