Battery Heater
5,852
6
12
This will use a 9v battery, battery connector, and paperclip to make a battery heater that will heat up the paperclip!
Supplies:
Step 1: Materials
You need a 9 volt battery, a battery connector, and a paperclip.
Step 2: Unravel the Paperclip
Unravel the paperclip to make a metal rod.
Step 3: Battery Connector
Connect the battery connector to the battery.
Step 4: Put It Together
Wrap the red end of the battery connector (where the copper wire shows) around one end of the paperclip. Then, wrap the black end of the battery connector around the other end of the paperclip.
Step 5: Done
The paperclip will start heating up!
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    12 Discussions
    NeilRG
    1 year ago
    just what we dont need is some noob trying to scale this up and trying it with a lipo battery or other larger battery to their ultimate detriment. Instructables should pull this post. I have commented many times and have always respected the be nice policy but this non invention is moronic.
    Nmoleo­tomatoskins
    Reply 2 years ago
    You should not try this; a paperclip has a very low resistance and the battery could combust if you do this for too long...
    hafizan89
    3 years ago
    Being nice,
    This is a very dangerous thing to do. This is basically short circuit on the battery. If you keep this up it'll make the battery combust and your home/pants/life will be on fire. Fire is no play thing.
    MikB
    3 years ago
    You missed:Step 6: The battery will then go bang.
    Lavoz24
    3 years ago
    Not trying to put you down or anything but isn't this the same as the hot wire foam cutter just on a smaller scale? I believe so, If so, what's the difference, besides the foam cutter being bigger, between the two? I mean, I've seen them hooked up to batteries and no one complain about fumes or it blowing up. Why complain here?
    MikBLavoz24
    Reply 3 years ago
    Big difference. A hot wire cutter has resistance wire that heats up along its length. A paperclip is practically a dead short.
    I wouldn't run a hot wire cutter off a tiddly battery like a PP3, they are not built for it. Needs a power supply, or a bigger battery.
    Also: Batteries say "Do not short circuit". I can vouch for PP3 batteries going off like firecrackers when shorted. They may not have much energy, but when they let it out all at once it's not fun.
    Green gadgets
    3 years ago
    Isn't this sorta dangerous ??? I once put a 9v and a mgnet in my pocket and it blew up in my pants and it really burned
    spacepymp
    3 years ago
    Nichrome is toxic, do not use it. This is dangerous though, as a battery is not suppposed to be constantly shorted, it could disrupt the akaline reaction in a bad way
    Dalton63841spacepymp
    Reply 3 years ago
    Fumes from Nichrome when welding are toxic, but Nichrome wire is used in almost all heating elements, from electronic cigarettes and space heaters to blow driers and stoves. (A lot use Kanthal, but Nichrome is still very common.)
    Dalton63841
    3 years ago
    Use Nichrome wire for a better effect. The paperclip is providing almost a dead short, and the only thing preventing the battery from blowing up is the 9v battery's high internal resistance.
