Battery Powered USB Charger
12,585
140
16
About: I have always enjoyed taking things apart and putting them back together as a child, and learning how they work. As I got older I began to fix electronics and when I was 13 I bought my first soldering iron. ...
In this instructable I will be making a tutorial on building your own portable battery powered charger to charge all your USB devices!
Supplies:
Step 1: Obtain Parts
-9v battery clip (two is better but one works fine)+ batteries (rechargeable are more efficient)
-Female USB port (salvaged mine from a USB hub
-7805 regulator (or any other regulator that outputs 5v@1-2 amps.
-Altoids tin (or any other housing)
-Optional switch
Step 2: Identify Pins
You need to identify the pins for the positive and negative on the USB and also the input/output of the regulator.
Step 3: Begin Soldering/Assembly
-If you are using one battery skip this step: solder the positive of one clip to the positive of the other battery clip and do the same to the negative (series)
-Solder the negative coming from power to the first pin of your regulator
-Solder the negative from the USB and the negative from the power to the middle pin of the regulator
-Solder the positive from the USB to the third pin of your regulator
Step 4: Schematic
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    16 Discussions
    krruiz
    4 years ago on Introduction
    I can get it to charge another USB device but not an iPhone 4 or 5. What did I do wrong?
    Typicalinventer719krruiz
    Reply 3 years ago
    because you need to use two 100 ohm resisters connecting between the D-, D+, and 5+ volt terminals
    xaenonkrruiz
    Reply 4 years ago on Introduction
    iDevices are unique in their charging ports. They need a voltage on one of the data pins, in addition to the typical 5V USB current, to charge correctly. I don't have all the details but I'm sure you can google for this information.
    sammydogjjkrruiz
    Reply 4 years ago
    Make sure the batteries are putting out at least 5v overall, and make sure the charging cable works. If you need anymore help, feel free to comment again ^.^
    xaenonchetan pujar
    Some newer Android devices (and iWhatever gadgets, too) need higher charging current. I know my Transpyre won't charge with the USB adapter from my little brick phone, even though both are 5V USB chargers.
    isssam
    is there any other steps. im using the free account
    jcagle2
    5 years ago
    When storing multiple 9v batteries together always electrical tape the ends. Just a safety tip to prevent possible fires.
    sammydogjjjcagle2
    Reply 5 years ago on Introduction
    I just stuck them in the box to show how it all fits. I would never store them bare. I store them by removing the wire off a 9v battery clip and subsequently attaching the batteries to the clip.
    sammydogjjuzziah0
    AAs would hold their charge longer, but are more expensive and bulkier than a single or a pair of 9v batteries.
    you would get a better result if the batteries were in parallel instead of series. Parallel would incerease the amp output which is what you would want for more charging
    I literally logged in to change my mistake, and I got a notification from this comment. Thanks for the tip! You are one of my favorite instructables user!
    No problem! Just trying to help out when I can. And thank you! Your kind words are very nice to hear :) made my day
