Beaded Pillows (without a Stitch)
3,194
116
6
About: Hi everyone! I'm a hardcore DIY'er, I've published 11 DIY books, just produced my own TV show called Make Your Mark for PBS/APT, I make YouTube videos every week and I'm buried under a mountain of craft sup...
Make beautiful beaded pillows without stitching on a single bead!
Supplies:
Step 1: Watch the Video Tutorial Here!
Step 2: You'll Need
1 yard heavy cotton
1 yard heavy denim
E-6000 Fabri-Fuse
Large stencils
1/3 cup seed beads per pillow
Spray adhesive
Sewing machine
Straight pins
Pillow stuffing
Step 3: Make Your Pillow
Cut two pieces of fabric 19" x 19"
Pin and stitch together using 1/2" seam allowance and leaving a 5" long hole
Clip the corners at an angle
Turn right side out and press flat
Step 4: Stick and Glue
Spray the stencil with a light coating of spray adhesive
Center it on the pillow Fill the stencil with a generous amount of E-6000 Fabri-Fuse
Step 5: Sprinkle and Decorate
Remove the stencil and sprinkle the beads on the Fabri-Fuse
*gently press down the beads if you need to
Repeat with the other areas of the stencil
Add a coating of clear acrylic IF you feel you didn't use enough glue
*This will insure that you don't lose any beads
Step 6: For Larger, More Intricate Stencils
Stick your stencil to the fabric
Squirt a generous amount of glue along the side of the stencil
Spread the glue with a piece of cardboard like a squeegee
Remove the stencil
Sprinkle the beads and let dry overnight
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    6 Discussions
    kimtweiler
    6 weeks ago on Introduction
    What an awesome idea.....faux beaded pillows.....you have increased my production time by 110%......can't wait to try this. Thank you, Kimmie t in MN
    tofugami
    4 years ago
    Super cute and fun way to spruce up any living space.
    Mark Montanotofugami
    Reply 4 years ago
    Tofu! Thanks so much. I was really happy with how these turned out.
    Sending my best, Mark!
    You'd be surprised how comfortable beaded pillows can be. As long as the Fabri-Fuse is flexible, it should be just fine.
