Bench Tool Stands
35,620
147
16
I have a few bench tools that I previously had sitting on an old wobbly side table. I decided it was time to improve their stands for safety and usability reasons. Here are some pictures of the stand construction.
More Details
Supplies:
Step 1: Bench Grinder - Top & Bottom Plates
For the bench grinder, the top and bottom of the stand were made from 1/4" plate with a few holes. Both plates were 6" x 8".
Step 2: Weld Plates to Tube
Here you can see the plates are now welded to the tube. The tube is 2-1/2" square tube w/ 1/8" wall.
Step 3: Drill Press Top
For the drill press, I decided to make a rectangular frame from angle iron.
Step 4: Drill Press Tube
To place the angle iron from on top of the tube, I made up a small 'platform' by using angle welded to the tube.
Step 5: Drill Press Finish
To add a bonus feature, I welded a couple of 'hooks' to store the drill press vice.
Step 6: Finished
Pained and Anchored.
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    16 Discussions
    Mihsin
    4 years ago on Introduction
    This is what I needed for a long time, a stand for my bench grinder. Great Instructable.
    Best regards from Beirut
    mikelewin
    10 years ago on Step 6
    quick material question. what was your source for the steel plate? i'm in ny and can't find many places to get 1/4" or 1/2" plate that doesn't cost an arm and a leg
    Ttalosmikelewin
    Reply 6 years ago on Step 6
    There are a couple of online places that can help you. They will even cut to size so you aren't paying for more than you need.
    www.onlinemetals.com
    www.discountsteel.com
    Mindmapper1
    6 years ago on Introduction
    This is a good instructable however I would suggest three things to make it much safer a) the bases are too small for the height/weight of the machines especially the drill press b) the use of 1/4" bolts is way too small also to cope, it would be easy to send the drill over if something got caught or the drill snagged the material. c) the cables should always be higher than the working area of the machine just in case something drops/fall off and catches the lead.
    abstracted
    7 years ago on Introduction
    very nice....luv the bench grinder and vise hooks....your inspiring instructable has inspired me to do one "no weling required"... but i was pondering , if u purchaced the steel instead of upcycling donor steel, wouldnt it have been easier to buy just alonger tube to covert the bench drill press into a floor model? but i just got a welder n itching for more welding projects. thnx AWESOME!!
    stephenniall
    9 years ago on Introduction
    Going to look for some steel square Tubing this year for this project ! already got the angle Iron .
    Im also going to mount a dimmer Switch and a Foot pedal for speed control for Pillar drill or Sander etc
    TFTD
    At our shop we used some old 16x7 steel wheels as a base for a 6" bench grinder/wire wheel. Works pretty good.
    #Liam#
    10 years ago on Introduction
    I like the wheel rim style bases too, for portability. Too bad it turns out they need to be bolted to the floor to pass OSHA safety inspections. -Liam
    dukemasterc
    Nice garage workshop. It's even painted. My dad made some of these when I was a kid. Instead of bolting to the floor, he used old wheel rims from a dump truck for the bottom. Nice and stable but portable.
    DanteDante
    12 years ago
    Forgot to ask... how did you anchor them to the floor? And has your anchoring method seemed to work out OK? Thanks again.
    DanteDante
    12 years ago
    Nice work! Impressively simple.Very neat and clean looking, and easy to clean up around them, too. I like it a lot. I have to clear off my workbench before using my grinder, or everything walks off the table from vibration. Annoying. Seems like the PERFECT reason to get a welding set-up. Thanks, gt-man! Also, IMHO, I think these these would sell. Shipping would probably be ridiculous... but locally? Maybe so.
    robotJones
    12 years ago
    Nice, makes it look really good. Is that in your basement?
