Bench Vice Restouration
980
5
About: wood working with reclamed wood bicycle mechanic
old bench vice restoration
Step 1: Get an Old Bench Vise
get an old vise from a thrift shop or somewhere else
Step 2: Take It Apart
make shure you take ik apart so you can reassemble it after the paint has dryed
Step 3: Clean It
now clean the surface that needs to be paintet i used an angle grinder with a steel brush to remove the paint after that you need to clean it for the primer with something like White spirit or brake cleaner or any other Industrial degreaser for this purpose
Step 4: Attache Primer
start of with thin layers and let it dry completely before the next layer pro tip use some good primer i used Duplo color they make good paint and primer for Industrial use and yes it is worth the extra money
Step 5: Finaly Paint It
before you start paintingen use some scothsbricht to clean of a thin layer of the primer and clean it again with degreaser then start with the paint make thin layers and let them dry completely before you attache the next layer repeat this till you reach the result you wanted
Step 6: And the Result
ik used some black paint for the handle to make it how i wanted it
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    tomatoskins
    1 year ago
    This is great! I have an old vice I really need to restore. Your's turned out looking wonderful!
