Bentwood Ring. Driftwood From the Oregon Coast and Douglas Fir.
36,366
852
26
About: Instagram: oregonwoodworks. Dental school class of 2019 DIY-er.
This ring is entirely made form wood found in the neighborhood and at the Oregon coast in Lincoln City.
Materials and Tools Needed:
1. Wood. a straight stick, at least an inch wide or more.
2. Block plane. any hand or finger plane will do, it just depends on how much muscle you want to put into it.
3. Vise.
4. CA glue... (super glue) I use the cheap stuff from the dollar store.
5. Oil. I used to use olive oil because everyone has it at home. I use boiled linseed oil. Both are good. .
6. sandpaper.
7. something round.
Step 1: Find Some Wood.
I found my wood from a tree in the neighborhood, and at the Oregon Coast in Lincoln City. Great gift for anyone you know who loves the outdoors. choose some wood from a significant place. This is my new wedding ring. We spent our honeymoon in Lincoln City.
My favorite thing about this project was finding what the inside of the wood looks like! It's always a surprise. Especially with the driftwood. Driftwood has some great detail, depending on how long it's been soaked, and how many cracks it has in it.
Step 2: Plane the Wood.
Most crappy looking wood or sticks look like gold once you find a smooth flat spot in it.
1. cut a mostly straight piece out of the wood. preferably with less branches growing out of it to avoid knots. Though I managed to get a great one onto the face of my ring, and love it.
2. carve the stick or whatever you find, to see what the inside of it will look like. I brought this knife to the beach to see what pieces of driftwood fwere worth taking home. Pretty fun treasure hunt.
3. plane the wood flat. I used a block plane and a little finger plane. both stanley.doesn't matter. At this point, I wish I had a draw knife. If you have a draw knife, then you know what to do. A spokeshave would have also been nice. But, for me, I just used a knife and some small planes, because that's what I've got.
Step 3: Create the Ring Blank
1.If you used a plane or a spokeshave, try to get some shavings like so... Thin shavings but not see-though. These work better than store bought veneer because they are thinner. When glue-ing, they encorporate super-glue into the ring better with more and thinner layers. This is why DIY is better than buying veneers... they usually come quite a bit thicker. The bentwood process usually calls for boiling or steaming the veneer, and 2 layers is already quite thick. Using this process you can get 4-5 layers at the same thickness, and they are thin enough that you can use them dry.
2. When Glue-ing, always wrap the shaving opposite the way it naturally curls.. >IMPORTANT< On every shaving, there is a smooth side and a rough side. wrapping opposite the curl makes sure the smooth side faces out. Also, as you glue, add glue then hold tight only about an inch or less (half the ring) at a time, and let the glue dry a bit before you continue. Make sure you line it up good and wrap it tight. you can't re-adjust as you go. if you try to bend to wood straight as you wrap, you will have large gaps in the sides of the ring.
3. Glue up the ring. I use a socket to size my rings while glue-ing. >IMPORTANT TIP< don't glue on the bare socket... it will be stuck forever. I usually wrap the socketwith inside out scotch tape. that gives it somethings to wrap around that will be quite easy to slip off after the glue dries, and scoch tape will easily come off of the inside of the ring.
4. Shape and Sand the ring. I use a jeweler's saw to cut the sides off, and then run it along a piece of sandpaper flat on the bench. I use 80 grit for shaping, and up to 400 before continuing to the next step.
Step 4: Add More Veneer
Make the outer Veneer.
1.This step is similar but more involved than step number 2.
Once the wood is flat, you need to cut out a thin layer of it. You won't be able to do this thick enough with a plane, because the wood will crack. I cut under from the side with a coping saw. any saw will do.
To thin it our further, I put some blue tape over the smooth side, (The side I want to show on the outside of the ring) and used some double sided tape to stick it to a flat surface. NOW, you can use a finger plane, block plane, rough sandpaper (glued to a hard block)... whatever, to get it pretty thin and flat. It's going to need to be as thick as you can keep it and still flexible enough to bend around the circumference of the rings without cracking. The tape also helps it from cracking before you glue it to the ring.
2. Glue the veneer to the wood
Once your veneer is thin and flat, glue it to the outside edge of the ring.
I did a few different segments, combining 2 or 3 different pieces of driftwood from the Oregon Coast.
The liner (inner core just used in the previous steps) of the ring was made from the douglas fir branch.
Step 5: Sand Sand Sand
By this point, you can sand it up as much as you want, shaping as you go. I use 150, 220, 400, 800, 1200, 2000..
Pictured above are some of the sanding tools I've made for the process.
I like to round all the edges so it's nice and comfortable, and doesn't snag on anything.
Step 6: Polish
Here's where your ring really shines!
ok, but seriously, watch this video, I'm not claiming this one, but this is the best way to polish your ring, accept I don't use a lathe, I jsut hold it in my hand and rub it on. Works like a charm.
BLO/CA GLUE POLISH Video
Above is the finished product, along with a few other rings I've made.
Hope you're inspired! Check out my website if you're too lazy to make one yourself.
www.etsy.com/shop/naturalbentwoodrings
If you want more details I've already made a much more in-depth tutorial with many more tips and tricks on bentwood rings here. picture are not as good but the information is great. I've upraded my camera since.
Rings Challenge
First Prize in the
Rings Challenge
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
26 Discussions
FuzzyDuckling
2 years ago
This is really cool, I've got a collection of oregon driftwood myself that I carve. I use Bondo rotted wood restorer on the wood and it really helps with the brittleness. I wonder if it would strengthen the rings when they are finshed...I'm gonna experiment!
Thanks for the posting!
NerdyGirl79
3 years ago
I have been breaking my neck looking for veneer sheets here in Canada. But no luck. I live in an area with a lot of trees - will absolutely try this when I go take my walks in the afternoon! I just need to purchase plane and I'm good to go!
Thanks!
adenda2NerdyGirl79
Reply 3 years ago
yes a hand plane is very helpful, to do it this way takes practice, to get the blade set to just the right thickness. another option is to plane one side, and cut a longer this strip with a saw, and use double sided tape to stick the flat side down, and use 80 grit block to sand it to thickness.
NerdyGirl79adenda2
Reply 3 years ago
Got my hands on a decent plane. Been practicing using it on some old wood pieces I've had lying around - trying to get the technique just right. Thanks again for the tutorial. Can't wait to start making rings again.
adenda2NerdyGirl79
Reply 3 years ago
another option is to get a sample veneer pack online
NerdyGirl79adenda2
Reply 3 years ago
I've tried online. Most of the places don't ship to Canada (for whatever reason). You're method is a lot easier and least expensive. I see thick/large branches all over the place so it's super easy to get supplies.
adenda2adenda2
Reply 3 years ago
make sure it's the stuff with no sticky on the back
Madison hirst
3 years ago
I didnt have a block plain and just used a chizle, i couldnt get the long thin strips like you did. Im a little cofused if i should boil the strips that i got or just get some veneer...
a few options... if you really want to use your own wood, you can still cut it pretty thin with a saw then sand it down thinner iwth a block and sandpaper. I did this a few times, but it gets finicky when it gets thin... I used double sided tape to keep it on the table while sanding. If you're going for easy, then get some veneers, not the sticky backed stuff. it looks great. Most of the inlay wood I use is from a veneer pack I got a few years ago, though I think it's fun to use wood I've found myself. you can get packs of veneers of 40+ kinds of wood online or from stores like woodcraft for about 20-40 bucks.
adenda2MadisonH1
Reply 4 years ago on Introduction
to CUT the veneer ( if you already have veneer) I just used a ruler and an exacto knife. Important to cut lightly and make multiple passes, or it will just crack with the grain pattern. Don't go all the way through it in 1 pass. I personally use about 1/2 inch to almost an inch wide, just in case I don't line it up perfectly when I wrap and glue it.
for MAKING the veneer, I use a hand plane. (specifically a stanley block plane) OR, for thicker veneer, I use a coping saw and sandpaper. Maybe I should make a vidoe someday.
GormbyG
what are u making the ring from? the planed wood?(shaved pieces) i dont get what you're doing?
not too descriptive? I see just to the wood, u are using, nothing more..
adenda2GormbyG
Reply 4 years ago
the woodshaving made from planing the Douglas fir (thinner branch) was wrapped and glued to make the core. the planed thicker branch (driftwood) was cut off thicker and added to the outside as a veneer. both pieces were planed flat first..only the thicker veneer has to be actually cut off instead of using the shavings
temp_-221805939.jpgtemp_886132015.jpgtemp_-233627703.jpgtemp_-1468275458.jpgtemp_1247806567.jpg
ArticAkita
4 years ago
Finished myrtle wood is like the tree version of the tigereye gemstone.
ArticAkita
4 years ago
Love your designs! Need to try it with myrtle wood, that would look awesome!
adenda2rosalie.pekinrigby
Reply 4 years ago
ok. so when you glue the ring up in layers the edges will be uneven and too big... so, with either a saw or a knife cut it to width.. slightly big... then sand it on a piece of sandpaper flat as pictured to true up the edges, and to sand it to the final width you want. quick pictures but I hope it gets the point across.
NathanSellers
4 years ago
this is beautiful. my one concern is how strong/brittle it is. I have had wood rings break in the past. how do you prevent that?
