Best Jewelry Box
860
6
About: Hello, My Name is Matthew, I have 8 (almost 9) siblings. I LOVE Woodworking (DIYing) me and my family are the Galicinski Family Band. Me and my brother Micah love composing music, please check us out on yout...
I made this Jewelry Box a little ago, and I Thought that I should make instructions for them so here they are, very VERY EASY to follow, pictures are GREAT.
Wood Needed
  • 57 x 27 inches needed of Plywood
  • 57 x 2 inches of wood needed for compartments
Tools Needed
  • Jigsaw
  • Hand saw
  • Sander
Other
  • Stain
  • Black Paint
  • Pencil
  • Paper
Supplies:
Step 1: Making the Sides
  • Cut four pieces of plywood, 11 inches long by 3.5 inches wide.
  • Then cut angles on the ends so the wood can fit together.
  • Then sand the wood.
Step 2: Measurements for the Compartments
Measure this on a spare piece of plywood or paper, this is to help with layout (You won't need to keep this piece of wood).
Step 3: Easiest Way to Sand Small Pieces of Wood With a Electric Sander
Clamp the sander in the clamp then start sanding.
I find this very helpful for sanding small and light pieces of wood.
Step 4: Cutting the Wood for the Compartments
  • Cut 6 pieces of 9 1/2 inch by 2 inch wood. (Can be from 1 1/2 inch to 2 1/2 inch mine is 1 1/2 inch)
Step 5: Measurements for the Notches
  • Measure halfway down the wood.
  • Then cut it about 1/4 inch wide, just to make room for the other piece of wood. To do this you must cut halfway down the wood. Then move the saw 1/4 inch to the side and cut halfway.
Step 6: Making the Bottom
  • Measure 11 x 11 inches.
  • Then cut it out with a table saw or a jigsaw.
  • Then sand the ends.
Step 7: Adjusting
Put the four sides of the box and the compartments together.
Adjust the ends of the compartments to fit into the sides of the box.
All the parts are not nailed or stapled together, the compartments are not glued but are put together.
Step 8: Connecting the Bottom and the Sides
  • Put the bottom on the sides (as shown in photo)
  • Then staple it down and for support I nailed three nails in each side (as shown in photo)
  • Flip the box over and nail one nail in each side (as shown in photo)
Step 9: Putting the Compartments in the Box and Adjusting It
Step 10: Optional Step
After I finished the box I figured out that I had made a mistake. You should put the felt on before you stain all of the box (under the compartments) and when you stain it you should stain the compartments separately. Then you should glue the compartments to the felt and put on some wood filler.
But if you want to do what I did you can. All the steps are for my way but you can easily do the OPTIONAL STEP.
Step 11: Connect the Compartments
Glue the Compartments to the back of the box.
Step 12: Wood Filler
Follow the photo.
Step 13: Staining the Wood
Stain the wood with any stain you want.
After it is done drying stain it again.
(Read next step to figure out what to do when stain is drying)
Step 14: Making the Lid
Cut a piece of plywood 13 inch by 13 inch.
This is the lid.
Step 15: Painting the Lid
Follows the Photos instructions I will supply a link to the image that I used.
https://www.polyvore.com/cgi/img-thing?.out=jpg&size=l&tid=12032572
Step 16: Connecting the Hinges
Screw the hinges onto the lid, then screw the other side to the box.
Step 17: Optional Step
If you followed my way, this step is for you, if the followed the other way, you are done.
  1. Cut the felt to the size of each compartment.
  2. Then Glue the felt on the bottom of the box.(compartment by compartment)
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    2 Discussions
    MatthewGalgnomedriver
    Reply 1 year ago
    Thanks for your Encouragement.
    Yours is Great, I bet you will be in the WINNER'S CIRCLE
