Bicopter / Dualcopter
11,954
91
14
About: I love making things. I have for as long as I can remember liked to make stuff. Now days I have two kids (Thomas and Emma) and most of the things I do are safe for them! I love electronics and Microchips, I ...
Dualcopter.
Plywood construction using common A2212 brushless motors and Hobby Power 30A ESC’s with 1045 propellers. Servos are high speed metal geared standard sized servos. And lastly the flight control board is the simple to use KK2.1.5 board.
Step 1: Design and Build
The construction of this model is mostly covered in the
Tricopter build. It uses the same servo arm as the tricopter but uses two of them on a special twin hub.
The video shows a few more details about the arm construction but it is a very simple build. The tricky bit was getting this thing to fly!
But let’s start with the construction. As with most of my builds I design on a free cad program running on my raspberry pi, I then save the drawings as pdf’s and print out using a scale of 100%. Then I stick the plans to the 3mm plywood and double up all the parts. Again this model easily fits on a piece of plywood 300mm by 600mm.
Once all the bits are cut out then clean up the edges and stick all the bits together but like the tricopter don’t stick the arms into the hub. (Mainly because I wasn’t convinced this was going to work so wanted to use the arms as spares for my tricopter) once all the bits are glued together you can add the servos and wire up the speed controllers and add the flight control board. As you can see in the video my first attempts at flying this machine didn’t go well! I persevered for 3 evenings and most of a Saturday before finally accepting that the weight was all wrong.
Following a quick redesign I added the vertical battery holder and now the machine was able to fly and be controlled! This extra bit is shown in the 4th and 5th PDF’s. this kind of messes up the fitting onto one sheet of plywood 300 by 600mm, but if I get time I will see if I can make it fit.
Step 2: Electrics
Nothing really fancy about the wiring. The motors were soldered directly onto the ESC’s. And the power cables were lengthened and soldered together into the battery connector.
The Back motor ESC (more by mistake) is connected to channel 1 and the front motor ESC is connected to channel 2. The back servo is channel 3 and the front channel 4.
Step 3: Setting Up the Flight Controller. KK2.1.5
So there are two ways this machine could be flown. The first is with both propellers in front. This is the standard dual copter configuration. I started with this layout and instantly found i had to make adjustments, firstly to the servo offsets which needed to be at 50 and then the rudder needed to be reversed in both the two servo channels.
Or if you wish you can fly this like a Chinook with one propeller in front of the other. To make this change I had to move the fight controller around by 90 degs and change the settings on the mixer.
Whilst testing I quickly discovered that the motors were fine and the flight controller was able to control the motors to allow changes in direction. However the servos were not working well and because of this I had to separate the PI channels so the Aile and Elev were adjusted independently. This was obvious after all in one direction the motors change and in the other axis it’s the servos so it really was daft to have them set to the same values in the PI settings.
So where next? I think I will revisit one of my early bicopter designs, but move most of the weight to the bottom, which means moving the servos to the bottom and the esc’s and anything else I can lower!
In hindsight I think the dualcopter/bicopter is one of the least desirables models due to the pendulum effect of the required weight below the propellers and whilst it is fun to make these machines and even more rewarding to get them to fly I don’t think it is worth pursuing anymore!
Settings Flown As Chinook.
Mode Settings
Self-Level : Always
Link Roll Pitch : No
PI Settings
Roll (Aileron)P Gain : 80P Limit : 100I Gain : 50I Limit : 80
Pitch (Elevator)P Gain : 48P Limit : 100I Gain : 8I Limit : 80
YAW (Rudder)P Gain : 30P Limit : 95I Gain : 2I Limit : 2
Mixer Editor
Channel 1 (back motor ESC)Throttle : 100Aileron : 0Elevator : -100Rudder : 0Offset : 0Type : ESCRate : High
Channel 2 (front motor ESC)Throttle : 100Aileron : 0Elevator : 100Rudder : 0Offset : 0Type : ESCRate : High
Channel 3 (back servo)Throttle : 0Aileron : 50Elevator : 0Rudder : -100Offset : 50Type : ServoRate : Low
Channel 4 (Front servo)Throttle : 0Aileron : -50Elevator : 0Rudder : -100Offset : 50Type : ServoRate : Low
Step 4: Plans
I have added the 5 PDF's of the plan. you may have to play around with the design?
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    14 Discussions
    GregS261
    9 months ago on Introduction
    thanks I know that was a challenge to fly but have very good skills flying and building!
    Keep pushing and building!
    GregS261
    9 months ago
    With the bad press that drones get, Why build one that can't be controlled.
    Bravo for getting it off the ground at all. But I hope you never take it out of
    your back yard and no higher than you did in the video! Make a good quad.
    mr_fidGregS261
    Reply 9 months ago
    in the end the model was controllable.... but it was more the challenge of building it and getting it to fly. this model would be useless if there was just a slight breeze. I think the bad press of drones has come from persons buying phantom type models and flying out of sight on FPV. I fly always insight and make sure at all times that i can land safety and not lose control.
    Thorondor95GregS261
    Reply 9 months ago
    The press can go cry in their offices and complain about something else being a threat to humanity. ;)
    GregS261
    9 months ago
    I am impressed by your skills building aircraft that work I couldn't do it at all.
    I can build a kit ha ha. Do you build fixed wing planes? The way you make these
    reminds me of a kit I had for a glider. Keep making new stuff!
    mr_fidGregS261
    Reply 9 months ago
    I have a couple of planes, but i like the drones more! planes are so cheap to buy it seems pointless to make your own.
    power000
    9 months ago
    Really nice you finally did it and well done , what is total weight RTF but without battery??
    mr_fidpower000
    Reply 9 months ago
    560 grams. i have tested the A2212 motors with different timing and discovered you can get 1.4Kg from each.......but they get very hot and i don't think the battery would last long?
    Thorondor95
    9 months ago
    We have yet to fly something upright with only one spinning airscrew (3D flying aside)......
    mr_fidThorondor95
    Reply 9 months ago
    I am thinking about making an upright model. Something with a directional motor/ propeller at the top and a motor at the bottom.
    I wonder if having a ducted fan at the top and ducting part of the thrust to counteract the turning motion??
    Thorondor95mr_fid
    Reply 9 months ago
    Man, you get to build all the fun stuff. Sounds like a good concept.
    JohnC430
    9 months ago
    Thanks for sharing. I appreciated the video. it shows the steps you took to stabilize it.
