Bicycle USB Output
19,788
460
33
About: Please support and share our mission; the Plant Doctor is a non-profit, open source online research laboratory specializing in electronics+plants. Our vision is to bring together nature and technology in a s...
hello everybody,
please support our mission;igg.me/at/smartplants
i use portable usb powerbanks for most of my projects (usb heated clothing, smart plant pot). and i also bike a lot. so i decided to create a very cheap, "clip on" power source to charge these batteries. it can then be used to charge a smartphone, tablet basically anything that needs a usb plug to recharge.
the goal is to reach 5V-500mA to charge these batteries. our design is using a dc motor found inside of an old all-in-one paper printer. the biggest one in there.. you could easily add another motor in parallel to boost the current. at 1-2amps we are now able to charge all new smartphones and tablets directly from the handle bar. but remember, we can easily, with a single motor, still charge a powerbank which then can charge any electronic device you may have.
when you apply power to a dc motor it starts to spin. and if you spin the shaft manually either by pedaling, gravity, water, wind etc. then your motor starts giving out electricity from the wires. i can easily generate upto 10-13V constantly while biking. you can implement the same idea in a different scenario such as a wind powered generator.!!
parts needed;
- dc motor
- female usb port
- boost/buck adjustable voltage regulator
- mini voltmeter (optional)
- powerbank
- frame (3D printed, DIY case)
let's get started..>
Step 1: Frame
i needed to design a clip on piece based off the dimensions of my bicycle. i used sketchup, a free VERY easy to use 3D design software. you can download and use the 3D printed frame i have designed - https://drive.google.com/folderview?id=0B8bvYGugxv...
or you can easily get creative with pipe holder clamps, nuts & bolts. any round object with some hot glue can be your wheel disk..
find a place on the front fork where you think it is safe to install the dc motor, and imagine a disk rubbing against the wheel attached on top.
also another housing was designed for the handle bars. this will house the voltage regulator, voltmeter and usb. you can easily use any tiny plastic container as housing.
Step 2: Adjust, Test, Wire
before we solder, let's do some tests
using a voltmeter check the polarity of the dc motor pins while the bicycle wheel is turning the forward moving direction. on your voltmeter screen a "- minus" will appear telling you that your polarity is reversed, simply change the wires around and now you will have the correct polarity.
find a 9V battery or any dc adapter that is higher than 5V. we now must set the output of the voltage meter as 5.1V. to do this simple attach a higher voltage power source as input and turning the little screw to see the voltmeter as 5.1V as output.
now we know the correct polarity of the dc motor with the correct direction, we are able to get a reading of voltage generated and our regulator is set at 5.1V. once you are sure everything is figured out, go ahead and solder all the wires for a permanent connection.
this step may be a bit confusing for beginners. ask questions in comments.
read; basic electronics, how to solder
Step 3: Conclusion
we are simply generating electricity from the motion of the bicycle moving. it is a very simple dc circuit.
the voltage regulator is pretty much taking care of all the work. keeping our unstable input voltage at a constantly set voltage output of 5.1V - which equals to enough power for charging a usb powerbank.!!
similar products are sold online for upto $50. you can make your own for under $5 and learn basic electronics, intro to 3D printing and design. go ahead give it a try..
second version will include a better motor mount, possibly by the back wheel and house 2 in parallel DC motors to be able to directly charge a smartphone. remember to like, share and follow.
Digital Life 101 Challenge
Grand Prize in the
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    33 Discussions
    agrassi4
    Question 10 months ago
    Where would be a good place to buy these supplies? Also, can someone translate this into basic english so my non-engineer/electronic brain can understand?
    MahendraB12
    1 year ago
    sir i m not getting ,how to fix the motor to the bicycle
    please reply ASAP
    Mase13
    2 years ago
    i went ahead and added a recitifier circuit. so i can go backwards.
    BicycleBlueBook
    2 years ago
    This is the most genius addition to a bike I've seen in a long time! For a list of other bicycle accessories that are must have check out BicycleBlueBook!
    Willy™
    3 years ago
    Tebrik ederim,güzel çalışma.
    LucaU
    3 years ago
    Hi, how did you make the shaft disc? My problem is how to connect a disc to the rotor.
    Akin YildizLucaU
    Reply 3 years ago
    hello LucaU,
    the disc is printed as well, you will find it in the attached file. then it's just hot glued to the motor shaft. it fits perfectly on top of it. depending on the motor you find, the design might have to be adjusted however..
    raskoe
    3 years ago
    one problem if you turn your dynamo back
    then there is a negative input voltage
    is there any protection ?
    Vishnu Menonraskoe
    Reply 3 years ago
    just we can use a diode before the input feed(output power from motor)
    ahmet_024102
    3 years ago
    hocam dinamo olarak 12 voltluk herhangi bir dc motor olur mu=
    Akin Yildizahmet_024102
    Reply 3 years ago
    evet, olur. motorun 12V olmasina gerek yok, daha dusuk yada buyuk olabilir, elektrik uretimi ona gore degisecek ama. daha cok volt, daga cok amperaj
    question: will any 12V dc motor work.?
    answer: yes it will. however you can use and size motor, smaller or larger. electricity generated will change due to size, more volts mean more amps
    juntjoo
    3 years ago
    This is cool and all but if money isn't an option, which is better, this or a dyno hub?
    Akin Yildizjuntjoo
    Reply 3 years ago
    dyno hub. this is just a proof of concept project. good thing about this is that you can find these motors anywhere for free. but you will need a lot of them to create enough current. they are best for making small wind, water powered phone chargers, good intro to electronics. dyno hubs are more efficient, powerful and designed for bikes specifically.
    jeanniel1
    3 years ago
    Now that's really harnessing power efficiently. I'd often felt that bicyclists could power quite a few things, but didn't think about batteries... good one! Great 'ible.
    Akin Yildizjeanniel1
    Reply 3 years ago
    :) it is pretty cool to be able to plug in your phone with the map on the screen. you can take a very long bike ride and still not run out of battery
