Tweeting With Raspberry Pi
4,456
56
About: ​M.Sc. in Electrical Engineering in Rochester Institute of Technology at USA and CMO of Embarcados.
In this instructable, I will explain how to make your Raspberry Pi tweet!
To run this tutorial you'll need:
  • Raspberry Pi - I'm using Rasp 2B
  • USB Mouse
  • USB Keyboard
  • Monitor
  • HDMI Cable
  • USB power supply for Raspberry
  • Internet
I based this tutorial in the following texts:
https://www.instructables.com/id/Tweeting-Doorbell/
https://www.raspberrypi.org/learning/getting-start...
http://pythoncentral.io/how-to-use-the-twython-twi...
https://gofedora.com/how-to-install-use-twython-py...
http://www.makeuseof.com/tag/how-to-build-a-raspbe...
http://stackoverflow.com/questions/17309288/import...
https://pypi.python.org/pypi/twython
https://www.instructables.com/id/How-to-Send-Tweets...
So, let's start!
Step 1: Creat an App at Your Twitter Account
Go to your twitter account. You'll need the following parameters to make your Rasp Pi Tweet, that you'll get from this app
  • Consumer Key (API key)
  • Consumer Secret (API Secret)
  • Access Token
  • Access Token Secret
Step 2: Insert All Informations and Create an App - Fill the Form
Step 3:
Access Keys and Access Tokens tab in your app, that you just created.
Get all the tokens and create a file in Raspberry Pi, inside your working folder, called keys.py with all your information in it.
consumer_key = "aaaaaaaaa"
consumer_secret = "bbbbbbbbbbb"
access_token = "cccccccccc"
access_token_secret = "dddddddddd"
Step 4: Install Twython in Your Raspberry Pi
Open a terminal in Raspberry Pi, choose a working folder and run the following commands to install Twython, a python package that is required for this experiment.
sudo apt-get update sudo apt-get upgrade
sudo apt-get install python-setuptools
sudo easy_install pip
sudo pip install twython
sudo pip install requests
sudo pip install requests-oauthlib
Step 5:
Open a file and your working directory in Pi and rename it to twitter.py.
import sys
from twython import Twython
from keys import (
        consumer_key,
        consumer_secret,
        access_token,
        access_token_secret
twitter = Twython(
        consumer_key,
        consumer_secret,
        access_token,
        access_token_secret
message = "Meu primeiro tweet - a conta do tpfslima foi invadida poruma plaquinha Raspberry Pi bem espertinha!"
twitter.update_status(status=message)print("Sua mensagem foi twittada com sucesso: %s " % message)
Save it and run it using
python twitter.py
Step 6: Your Raspberry Pi Is Tweeting!!!
Your Raspberry Pi will tweet!
That's all folks! Happy Hacking!
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    joelm145
    2 years ago
    Hi,
    How can I connect a Blackberry Bold Q10 nano-keyboard to a raspberry?
    I want to make my raspberry portable console with a nano-keyboard of a Blackberry Bold Q10 but i don't know how to connect it XD
