Blinking LEDs to Music
230,341
257
214
This is a fairly simple project for anyone with some electronic skills.
Plug this circuit into an audio source and the LEDs will blink to the rhythm of the music. All it is really is using the voltage from the audio input to activate a transistor and turn on the LEDs.
This is circuit is very customizable. The setup of the lights is really up to you. The main thing to consider when choosing layout for the LEDs is your audio source and the power supply you will be using.
For this particular one I choose to make it run off a 9v battery and use an IPod for input.
Supplies:
Step 1: What You Need
Depending on the configuration of you setup you may need to modify the number of parts below.
Parts:
Superbright LEDs, the number and color is up to you (I used 4 blue ones).
2 x TIP 31 NPN Transistor, the heart of the project.
Audio cord (a headphone cord will do or just an 1/8 inch jack)
case (I used a spare thick cardboard box)
9v battery clip (or the power supply you are using)
Tools:
Soldering iron
Wire cutters/Strippers
Step 2: Hooking Up the LEDs and Transitors
1.Solder 2 of the LEDs together in series. Connect the anode (long pin) of the first LED to the cathode (Flat side/short pin) of the second LED.
***NOTE you can add more LEDs in series or a resistor depending on the voltage of the power supply.
2. Now connect the Cathode of the first LED to the middle pin of the TIP 31 (the collector).
3. Repeat steps 1-2 again (for the second part of the stereo input)
4. The Anodes of the last LEDs go to positive voltage.
5. The right pins of the TIP 31s (emitter) go to ground.
Step 3: Hooking Up the Audio Input
Take the audio cable, strip the ends, and determine which wire is right and which is left. Red is usually right and white is usually left.
Another way to determine the sides is to take a multimeter and do a connectivity test with each wire and part of the jack
The tip of the jack is right.
The middle of the jack is left.
And the bottom of the jack is ground.
NOTE****
Decide which set of LEDs will be right and which will be left.
Then connect the corresponding wires to the left pin of the TIP 31s
Step 4: Final Assembly
Connect the positive part of the battery clip to one side of a switch and the positive ends of the LEDs to the other.
Then mount it all in a case (i used an old jewelry case).
I used a hot gluegun to secure everything, and some electrical tape to protect against any shorting.
Step 5: Testing and Modifying
Plug the jack into an audio source and turn it up until you see the lights. Some players will not be powerful enough to drive the lights. I suggest any song with a distinctive beat. (I used Crazy Train)
If you want to listen to the music as well you need to get a splitter.
Now its your turn. This is just one of many ways to wire up this circuit. Good luck and be creative.
Thanks to the following for some of the original ideas:
http://www.danielandrade.net/2005/12/06/howto-blinking-leds/
https://www.instructables.com/id/LED-Music-Sync-Lamp/
This is my first instructable and i would appreciate any feedback.
Step 6: Updates
Here are some additions/modifications that people have been suggesting and asking for.
1. The first addition is adding an output jack wired in parallel to the audio input wire. Unfortunately the case I used was a little too small for this.
2. Different configurations of LEDs. Many people commented on using different numbers/colors of LED. The main thing to be careful of is VOLTAGE that you draw. (Series vs parallel). The next step I am going to try is maybe using a RGB LED.
3. Transistors. I am not an expert at transistors. Use a NPN that is rated for the appropriate voltage.
4. Mounting the LEDs in interesting cases. I am going to try mounting them in a pair of portable speakers.
Thanks for the comments and good luck!
  • Arduino Contest 2019
  • Woodworking Contest
    Woodworking Contest
214 Discussions
ReefSTheReplay
Reply 3 years ago
I think he just used the wrong symbol for a switch.
NipunS1
3 years ago
I need to build this without audio jack input.. With a positive and negativ iput. +,-
AaronniehausNipunS1
Reply 3 years ago
I think you can get adapters from headphone jack to +,- leads. If not, the internal layout of an aux cord can be found online, there should be a lot of diagrams.
SirajH
4 years ago on Introduction
please someone help me to build this without audio in , instead can use a microphone.
AnnanasiSirajH
Reply 3 years ago on Introduction
You can try it like this picture shows, if the microphone generates enough voltage to trigger the transistor (0.7Volts) it will work.
Therelslmsheedy
3 years ago
What does splitter mean? How do I make this and hear sounds from a speaker??
I made it, I use 2 channels, four LEDs each Channels.
I use 12 V power source.
Here is the video
ausieking
5 years ago on Introduction
could i power this using usb i know a usb gives off 5 volts but if i just use two LED,s would it work
would this work using a left and right rca feed as the inputs? want to make it but with a few more leds so i can decorate my sub box in my car
cheers
SIR, i have a problem on what type of audio cord am i going to used .. . i have a headset cord but i don't know how to connect it into the ground and into the emitter of the transistor coz i find it hard determinig which one is the groud and which one is from the right of from the left. . what am i going to do sir?
do i have to buy an audio cord?? if so, then please tell me what is the cord needed for this. .
ADVANCE THANK YOU SIR, GOD BLESS
I don't understand what you mean by output voltage of the transistor. You would be better off with a power transistor like a 2n3055 for that as the LED strip will draw a lot of current and might overheat the small transistor
mariaa ahmed
i want complete list of components with specification please it would be very useful for me..thanks..
mariaa ahmed
5 years ago on Step 2
very useful...:)
i want complete list of components please..so i can purchase them..please help me...:)
mra02135
hi everyone,
is it possible to make a simple passive rc filter for either of the led branches? it would be nice to throw a couple capacitors in there and get different frequencies to affect each side, but I am not sure where to begin with figuring out capacitor values and if anything else needs to be taken into consideration. thanks
ThaXified
Video of my Working Prototypes! i maked 4 DIFFERENT WAYS!
http://www.youtube.com/watch?v=VsuG48KyaKI
