Bluetooth Controlled Robot With Spy Wireless Camera
15,974
146
80
In this instructables i will show you how to make wireless robot controlled with Bluetooth module.the best feature of this robot is wireless camera working over wiffi.in above picture you can see my phone working as camera.my phone is connected to home wiffi and the Android app named AirDroid is used for Wireless camera.
for remote control over Bluetooth i have used this application Bluetooth Electronics
MUST WATCH VIDEO MUST WATCH VIDEO
Don't forget to like and subscribe
Step 1: Components Required
1.arduino uno
2.bluetooth module hc-05
3. DC Motors (4)
4.Robot base
5.motor driver l293d
6.android phone
7.12v battery
8.ultrasonic sensor hc sr-04
9.jumper wire's
Step 2: Schematics
as shown in have connected two Dc Motors in parallel combination for turning the robot.for turning to right. left side Motors will be on and for turning left. right side motors will be on.
connect ultrasonic sensor vcc pin to digital pin 12
trigger to pin 8
echo to pin 9.
connect tx of arduino to rx of Bluetooth module and rx of arduino to tx of Bluetooth module.
During uploading the program disconnect Bluetooth module.
as shown in figure for running Dc Motors supply external 12v power supply.
for arduino you can use regulated 5v supply but i have used Mobile phone otg power supply.
And i have used 12 v battery for running motors only.
Step 3: Arduino Programming
I have uploaded arduino program file.you can edit it according to your requirement.in this program i have used millis function instead of delay.when i used delay function it stopping all the program.this program is combination of two program one for motor driver and other for ultrasonic sensor.
for running millis function you have to install libraries. i have uploaded zip file. extract it and paste it into libraries folder of arduino ide.
Step 4: Configuring Android App
Download Bluetooth Electronics app from google play store
I have uploaded my kwl file of panel.you can import it as shown.you can edit it according to your requirement.
Step 5: Configuring Wireless Camera
Download AirDroid app from google play store.connect your phone to your home Wifi then enter above ip address shown in app. on other browser of other device connected on same network. click on camera icon shown in picture.you can see live streaming.
THANK YOU FOR WATCHING
DON'T FORGET TO VOTE FOR CONTEST
    • Weaving Challenge
      Weaving Challenge
    • Build a Tool Contest
    • Epilog X Contest
      Epilog X Contest
    80 Discussions
    NishanthM4
    Question 4 weeks ago
    rather than using my phone can't i use a wireless wifi controlled camera like the one's available on amazon and can u share with me all the information of the project i would like to do it.You can mail me at nishanth.molleti9@gmail.com . I would really like to hear from you
    YuvrajJ3
    1 year ago
    Sir please tell me IN AIRDROID APP WITH PICTURE STREAMING AUDIO WILL BE THERE??
    Kumar Shiva
    1 year ago
    in which version of the airdroid the camera can be accessed
    Kumar Shiva
    1 year ago
    give us the version of airdroid to be used
    Kumar Shiva
    1 year ago
    how to link the arduino program with arduino board which u have given
    Kumar Shiva
    1 year ago
    Sir,we have taken your project from instructables and we have completed half of it.We are getting defects on the motor driver and we have already lost two boards.So please give us the connection of the motor driver to motors and arduino.
    SprasanthKumar
    1 year ago
    sir,here in #include <elapsedmillis.h> its showing error what should do
    ARI RAJESH
    2 years ago
    how to connect mobile with arduino ?
    kathait
    2 years ago
    Did this also avoid obstacles
    saurabh47Aadarshsrivas
    Reply 2 years ago
    I haven't hc08 .i don't know.
    Try my code.if this works for hc08 late me know.
    saurabh47Kamal rjn
    Reply 2 years ago
    #include <elapsedMillis.h>
    elapsedMillis timeElapsed;
    char BluetoothData; // the Bluetooth data received
    int switch1 = 11;
    int switch2 = 12;
    int trig_pin = 8;
    int echo_pin = 9;
    long echotime; //in micro seconds
    float distance; //in cm
    unsigned int interval = 100;
    void setup() {
    Serial.begin(9600);
    //Set Digital Pins 4 to 7 as Output
    pinMode(4,OUTPUT);
    pinMode(5,OUTPUT);
    pinMode(6,OUTPUT);
    pinMode(7,OUTPUT);
    pinMode(13,OUTPUT);
    pinMode(12,OUTPUT);
    pinMode(11,OUTPUT);
    //Set State of Pins all to LOW (0)
    digitalWrite(4,0);
    digitalWrite(5,0);
    digitalWrite(6,0);
    digitalWrite(7,0);
    digitalWrite(11,0);
    digitalWrite(12,0);
    digitalWrite(13,0);
    Serial.begin (9600);
    pinMode(trig_pin, OUTPUT);
    pinMode(echo_pin, INPUT);
    digitalWrite(trig_pin, LOW);
    void loop() {
    motor();
    sensor();
    void motor()
    if (Serial.available()){
    BluetoothData=Serial.read();
    if(BluetoothData=='F'){ // Red Button Pressed
    digitalWrite(4,1); //Turn diital out 4 to High
    digitalWrite(5,0); //Turn digital out 5 to Low
    digitalWrite(6,1);
    digitalWrite(7,0);
    if(BluetoothData=='B'){ // Yellow Button Pressed
    digitalWrite(5,1);
    digitalWrite(4,0);
    digitalWrite(6,0);
    digitalWrite(7,1);
    if(BluetoothData=='f'||BluetoothData=='b'){ // Red or Yellow Button Released
    digitalWrite(4,0);
    digitalWrite(5,0);
    digitalWrite(6,0);
    digitalWrite(7,0);
    if(BluetoothData=='L'){ // Green Button Pressed
    digitalWrite(6,1);
    digitalWrite(7,0);
    digitalWrite(4,0);
    digitalWrite(5,0);
    if(BluetoothData=='R'){ // Blue Button Pressed
    digitalWrite(4,1);
    digitalWrite(5,0);
    digitalWrite(7,0);
    digitalWrite(6,0);
    if(BluetoothData=='l'||BluetoothData=='r'){ // Green or Blue Button Released
    digitalWrite(7,0);
    digitalWrite(4,0);
    digitalWrite(5,0);
    digitalWrite(6,0);
    if(BluetoothData=='G'){
    digitalWrite(13,1);
    if(BluetoothData=='g'){
    digitalWrite(13,0);
    if(BluetoothData=='P'){
    digitalWrite(12,1);
    if(BluetoothData=='X'){
    digitalWrite(11,1);
    Serial.print("*XR241G232B248");
    if(BluetoothData=='x'){
    digitalWrite(11,0);
    Serial.print("*XR000G000B000");
    if(BluetoothData=='p'){
    digitalWrite(12,0);
    delay(10);// wait 10 ms
    void sensor()
    if (timeElapsed > interval)
    digitalWrite(trig_pin, HIGH);
    delayMicroseconds(10);
    motor();
    //get the result
    echotime= pulseIn(echo_pin, HIGH);
    distance= 0.0001*((float)echotime*340.0)/2.0;
    Serial.print("*D"+String(distance,1)+"*");
    timeElapsed = 0;
    /*try this code.
    i am also getting same error on arduino IDE 1.6.12.
    which version of arduino IDE are you using??
    use 1.6.5 version of arduino IDE*/
    saurabh47Kamal rjn
    Reply 2 years ago
    I think now problem is your arduino.please try to upload simple code like blinking LED and if you succeed then try my code.
    Kamal rjnsaurabh47
    Reply 2 years ago
    Arduino: 1.6.5 (Windows XP), Board: "Arduino/Genuino Uno"
    Sketch uses 7,240 bytes (22%) of program storage space. Maximum is 32,256 bytes.
    Global variables use 247 bytes (12%) of dynamic memory, leaving 1,801 bytes for local variables. Maximum is 2,048 bytes.
    avrdude: stk500_recv(): programmer is not responding
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x60
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x60
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x60
    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x60
    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x60
    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x60
    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x60
    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x60
    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x60
    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x60
    Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
    This report would have more information with
    "Show verbose output during compilation"
    enabled in File > Preferences.
    saurabh47Kamal rjn
    Reply 2 years ago
    are you able to compile the code ??
    i think now the issue is due to the drivers or your arduino is not working properly.
    install drivers properly .
    Kamal rjn
    2 years ago
    hi pls help me...i need to sumit the project on monday...pls help me
