Bluetooth Speaker Cnc-milled
4,218
57
4
About: DIY, 3Dprinting,Concrete, Electronics, Maker http://www.kims3diy.com
Hi everybody, I recently got access to an Inventables CNC-mill so I decided to learn how to mill and make a DIY bluetoothspeaker that was light to bring and long batterytime
Parts used:
Bluetoothstereo-module (10$) - https://goo.gl/Hm5u7r
Step up converter (2$) - https://goo.gl/pGDQdv
2 x Batteryholder (2$)- https://goo.gl/uhgSPu
2x Batteries 4000 mAh - (13$) https://goo.gl/aR71OZ
Switch - https://goo.gl/Miu6hZ
USB-chargingboard (2$) - https://goo.gl/7J3ZxF
Speakers (bought mine on secondhand, but here is similar) - https://goo.gl/cyY1tq
Microusb to usb - https://goo.gl/rj8KZu
Scrapwood,putty and spraycans and coating
Tools:
3D-printer (200$) - https://goo.gl/vxSLFA
Solderiron - https://goo.gl/SE2Kiz
Solder helpinghand - https://goo.gl/nwfH0x
Cutting Plier - https://goo.gl/nwfH0x
Cnc-mill - inventables X-carve
Small cnc-mill - https://goo.gl/jJ7Vds
Videoinstructions:
Step 1: Sketch
First i sketched up my parts in Easel the i chose to have my geometry cut on the outside of my geometry, i setup the cutting deep and choose what drillbit to use, i got a 1/8 inch cut bit and a v-groove bit to chamfer the edges.
Step 2: Milling
I made sure the wood was fixed and hade no chance of moving, and then just picked my origo and started to mill. I milled holes on top of the boombox and 3D-printed buttons for the bluetoothmodule.
Step 3: Break Edges
Remove sharp edges and sanding it.
Step 4: Glue
I used PVA glue to glue the box and clamped it together.
Step 5: Putty,sand and Paint It
I bought some cheap putty and spraycans and clearcoat and applied 4-5 times to make the finnish look better.
Step 6: Assembly
Assamble and tight the speakers to the front. Put the front on something soft to avoid scratches in the coating.
Step 7: Assamble the Electrics
Im sad to say i dont have many pictures from the electronic part, but i made a schematic and hope you understand how i made.
Step 8: Almost Done Now!
Glue and clamp the front to the box.
Step 9: You Are Done!
Just charge it,pair it with your phone and you should be good to party like there is no tomorrow!
Hope you have enjoyed my tutorial! :)
    • Organization Contest
    • Build a Tool Contest
    • Paper Contest
      Paper Contest
    4 Discussions
    Cekpi7
    1 year ago
    With all tools you used for it, it isnt really cheap, but on the other hand you can do almost same thing without 3d printer and mill, which is good
    Kims3DIYCekpi7
    Reply 1 year ago
    Yes you are right, only your imagination sets the limit how it can be built! :) im a part of a maker-organisation so i only pay 10 dollars a year to use the machines.
    jdhitc
    1 year ago
    nice, i thought you where using a suitcase, i think i am going to try this with one
    Kims3DIYjdhitc
    Reply 1 year ago
    thank you, yes it was very funny to make, and for the pricetag im happy with the batterytime and sound :)
