Bonus: Papercraft Skull Mask
102,978
480
28
Turning my Papercraft Skull into a mask was something that was pretty obvious. So here it is:
My Papercraft Skull-Mask!
You can leave it white as it is and be a reaper or use it as a base to draw a Día de Muertos Mask. Or both, or...
Step 1: The Template
You start with this template. Print out the PDF, it's 3 A4 Pages.
Alternatively you can use a plotter/personal cutter to cut out the pieces with the SVGs.
Either way, you'll end up with a bunch of pieces that have to be glued together.
Step 2: Score-lines
All the parts have score-lines that have to be folded either up or down. The skull is built inside out, so that you won't see the print on the outside. So most lines have to be folded up. The skull is basically a ball with convex folds.
Only the lines that have to be folded down are marked with red.
Score and/or fold all the lines before you continue.
Step 3: Locate the Right Parts
I labeled all parts with a name and used two symbols to mark where to align the parts to be glued.
Circles mark self connecting faces of a part. If a part has two circles, these two go together. I start with those. Check all parts and see if there are circles on it - if so, glue them together.
Squares mark where two different parts go together. They are each marked with the name of the part they connect to.
Step 4: Step by Step
Start with the nose and eyes. Then add cheeks and temples.
When you've added the skull caps you might want to stop here without the lower jaws.
For the full mask, add the remaining parts.
Step 5: Reinforcing the Mounting-holes
Before you put a string or rubber-band to the mask it is a good idea to reinforce the part where the hole will go.
Take a piece of scrap paper, fold it and glue it together. Then cut out a triangle roughly the size of the triangle you want to put the hole in.
Then take a hole-punch to make the hole for your mask.
tie in a string or rubber-band and have fun. Either wear it as it is or use your imagination to draw or paint on it.
Have fun!
4 People Made This Project!
  • Jewelry Challenge
    Jewelry Challenge
  • Fat Challenge
    Fat Challenge
  • Pie Contest
    Pie Contest
28 Discussions
Benstar
5 months ago
I made it! Distinguishing the blue vs. green was really had, if there's any way to recolor the pdf that would help. Also I had a hard time figuring out the cheek, mouth and jaw junction. I colored the mouth black to hide flaws and make it look more spoopy.
AxelT13
2 years ago
Debería estar en español
MelissaH54
3 years ago
So....there are teal lines and bright blue lines. Which are the valleys and which are the mountain folds?
kakang_anip
3 years ago
do you mind to teach me how to make the templete of animal shape such as grizzle or t rex maybe fox
krummreykakang_anip
Reply 3 years ago on Introduction
Take a look at my other instructable:
https://www.instructables.com/id/Create-faceted-paper-objects
krummreydfckngpwr
Reply 4 years ago on Introduction
I must have changed the colors somewhere along the design process.
What is red on the photos is blue on the PDF, sorry for that.
krummreyAlbertaB
Where does the instructable become unclear? I've tried to make it descriptive, where does it need to be more precise?
AlbertaBkrummrey
im just a little confused on all of the folds. as in what way to fold unless i missed something
MKris2183
I love this idea. Amazing job. My daughter wants to be a sugar skull for Halloween. We bought some temporary tattoos, for it. Now, that I seen this, I think I am going to make one for her and maybe use paper mache or mod podge to make it more permanent, so maybe she can hang it on her bedroom wall after. Anyone, have any suggestions.
krummreyMKris2183
Paper mache should work well. Just make sure not to soak the mask too much, it will warp then. work in layers and you'll be fine.
TacticalTrumpet
4 years ago
Awesome work! I tried this today with an old shoe box (I had no suitable cardstock on hand), and I think it turned out pretty well. Great template; I could follow it pretty intuitively without even reading the text!
Oh, and I patched up the nose hole; I didn't like my nose showing through when wearing it. ;P
eeVee
4 years ago
Amazing work. Love when the coolest projects come from the least amount of materials!
