Book Shelf / Cabinet
756
8
About: Hello, My Name is Matthew, I have 8 (almost 9) siblings. I LOVE Woodworking (DIYing) me and my family are the Galicinski Family Band. Me and my brother Micah love composing music, please check us out on yout...
With this Book Shelf / Cabinet I was inspired to make it because of ____ You will find out what at the end.
Step 1: Tools and Material Needed
Tools Needed:
Jig saw or table saw
Drill
Drill bits
Miter saw
Tape Measure
Pencil
Clamp
______________________________________________________________________
Material Needed:
Tons of plywood
2x4x30 inch piece of wood
3 5x24 inch pieces of wood
3 5x26 inch pieces of wood
4 2x34 inch pieces of wood
Wood for the sides
Step 2: Cutting for the Bottom
Cut three 24x5 inch pieces of wood.
Step 3: Cutting for the Top
Cut three 26x5 inch pieces of wood.
Step 4: Cutting for the Side Corners
Cut three 34x2 inch pieces of wood.
Step 5: Cutting More
Cut four 2x4x15 inches long.
Step 6: Screwing the Top
Screw the Top pieces into the 2x4(Top pieces = 26x5 inch pieces).
Step 7: Screwing the Bottom
The Bottom is the same as the top just don't leave 3/4 inch of space off the end.
Step 8: Screwing in the Sides Corners
Screw the Side Corners in the 2x4(as shown in photo).
Step 9: Screwing the Top Into the Side Corners
with a little effort the Top should pop in than you can screw the Side Corners to the top.
Step 10: Making the Sides
You can use some scrap wood then screw it together with a piece of wood(Like what I did). If you do you must leave a little bit of the wood that you used to screw the side together off the end, so you can screw it to side corners at the end.
Step 11: Making the Back
Cut some plywood to fit the back of the cabinet as shown in photo.
Step 12: Making the Doors
You can cut the doors as tall as you want I did 19 3/4 x 11 3/4. Follow photo for hinges. follow photo to screw the doors in.
Step 13: Making the Shelf
Cut a piece of plywood 24 x 14 3/4 inches.
Then I used some pieces of plastic (as shown in photo) to hold the shelf up, but if you have some pieces of metal like that it wood be better to use those. Then screw it in to the side corners and the 24 x 14 3/4 inch piece of wood.
Step 14: Sanding
Sand all of the pieces.
Step 15: Screwing the Back
Screw the back in to the top, bottom, and side corners.
Step 16: Screwing the Sides
Screw the sides into the the shelf, side corners, and the bottom 2x4.
Step 17: Making the Handle for the Doors
Cut two dowels 1 inch long. Now screw it into the doors and you are done with the building. Now for the staining!
Step 18: Staining!
I Stained it with minwax honey stain.
Stain the Doors separately.
Step 19: Done!
You Are DONE!
(Look at the next step to see what inspired me.)
Step 20: This Is What Inspired Me
A doll changing table.
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
