Cut Glass Bottles Using a Soldering Iron
89,849
365
34
About: Creating DIY projects
In this instructable I'm going to show you how to cut a bottle with a soldering iron. I also made a video, which you can watch here: https://youtu.be/JF6M9a_bJdo
This method does take quite a bit longer than some of the others. This bottle took me about half an hour to cut. What I like about using this method is that it's been a lot more successful for me, and gives me almost complete control of where the bottle cracks. Sometimes, though, it will crack wrong, but that rarely happens.
A couple things to remember before starting: only use the tip of the soldering iron and not the thicker part. Also make sure there isn't any solder on the tip. These are some of the things I've tried that caused the bottle to crack wrong. I'm assuming it's because the heat wasn't as focused as you want it to be with this technique.
Here is what you will need:
Step 1: Score the Bottle
We'll start with scoring the bottle with a bottle cutter. Remember to get a good score line, and only do one pass. Going over the same score line multiple times will make the cut more difficult. While making the score line you can tell when it starts to overlap when the sound changes to a crunching noise.
This score isn't ideal. There is a section that got missed because the bottle isn't perfectly round, and part of the score line strays off. But with this method of cutting, these flaws are not much of an issue.
Step 2: Start the First Pass
Choose a place to start that is away from the flaws. With a hot soldering iron, place the tip against the score line and hold it there for about 5 seconds; the exact time is not too critical. Then move the tip a bit and do the same. Continue doing this all the way around the bottle. This won't be enough to cut the bottle, but a lot of the time it will start a crack along the score line.
Step 3: Dealing With Scoring Flaws
If you happen to have stray score lines, like I did this time, just follow the line where you want the bottle cut. Also, if you have any places that didn't score, just follow the path where you want it to cut. Alhough I didn't do it this time, it helps to draw a line for the path with a marker, so that you have a visual reference to follow.
Step 4: After the First Pass
When you finish going all the way around, examine the score line and see if there are any cracks started. Sometimes they start with the first pass, and sometimes they don't. The crack will be shallow, and possibly hard to see, so try to get it to reflect. Check from above the score line, and below. If you see any cracks started, goto that spot and continue from there.
Signs to look for a starting crack vary: It could look like an obvious crack, or could look like the score line getting slightly thicker, or it could look like a reflection or glare on the inside of the glass. This time it started by looking like a reflection.
Step 5: How to Start a Crack (if One Hasn't Started Yet)
If you don't have any started, just pick a spot near your starting point. Before continuing, you'll need to get a crack started, which I'll explain how to do now.
Similar to the first pass, place the tip against the score line. This time hold it for longer, about 8-10 seconds for each position. Also, don't go all the way around the bottle, maybe about an inch or so. Sometimes you'll hear the bottle crack and sometimes you won't so check again for any signs of a crack starting then go back to where you started, and start again. Repeat this over and over, until you see signs of a crack starting.
Step 6: Growing/Guiding the Crack
If you can see the glare of the crack while you're heating it with the soldering iron, watch for it to grow. Sometimes it will fade while the crack is still starting, but that's fine. Once it does start to grow, you won't need to hold the soldering iron in the same place as long, so move it away from the crack as it grows. At this point, the crack will follow the soldering iron. If you do happen to have any places where there is no score line, keep following the path you want the crack to go and it will follow the soldering iron.
Step 7: Finishing the Crack and Separating the Bottle
When you get close to the start of the crack, sometimes you will see the two ends meet, but sometimes it will seem like they don't want to meet. If at this point the crack stops growing, the cut may be complete. Try separating the top of the bottle, but don't force it apart. If the cut is complete, it will separate easily. But if it feels like it doesn't want to separate, try heating the crack a bit more. Usually just heating the last bit helps, but sometimes you need to heat random parts of the crack. Just remember to not force it to separate, because that could cause it to crack randomly.
Step 8: What Next?
Now that the bottle is successfully cut, it's ready to be sanded and polished. That needs to be done because right now it's basically a broken piece of glass, and can easily cut somebody. You can go here to see my instructable for that: Polishing-Bottle-After-Cutting
To learn how I made my jig, check out my instructable for that: Make-a-Bottle-Cutting-Jig-Teardown
If you want to see the video version of this instructable, you can watch it here: https://youtu.be/JF6M9a_bJdo
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    34 Discussions
    gerflash
    1 year ago
    Just thinking of how you might speed things up, esp. if you're cutting several bottles: Once you get a bit of crack going in the bottle, stop and dip it in water. Then put it in the freezer while you go to the next bottle. Only a little water will get into that crack, but when water freezes, it expands! That may convince your bottles to crack faster in the long run.
    ericCycles
    1 year ago
    There is a method I read about in the 70s, but never tried. You fill the jar with oil to the place where you want the cut and then insert a heated poker (metal rod). The oil transfers the heat to the glass. I don't believe you needed scoring with this.
    Razanur
    2 years ago
    This method looks nice, but very slow.
    Has anyone tried running a wire along the score path and heating it (running electricity through it)?
    johnebyRazanur
    Reply 2 years ago
    This works nicely using a heavy gauge nichrome wire attached to upright insulating posts. Make connections at the top of the posts to the output of a very low voltage output high current transformer, with a good sized variac supplying the primary. You can let the wire sag to form a cradle to extend the contact around the periphery of the glass.
    Razanurjohneby
    Reply 2 years ago
    I'm not sure if I understood this correctly. You would hang a wire across the glass, then heat it and let is sag onto the bottle? But then you still need to carefully turn it, right? Seems kinda hard to me to keep everything aligned. Why not put a loop around it and then heat it? The wire should extend when heated, so no worries about "squeezing" the bottle to splinters...
    hotamale35Razanur
    Reply 2 years ago
    I believe he was thinking of having the wire hanging in a between 2 points in a " quasi "U" shape and resting bottle in that "U" to do the cutting.... I believe
    Razanurhotamale35
    Reply 2 years ago
    Ah, thanks, yeah, that makes more sense :D
    charliewintersRazanur
    Reply 2 years ago
    Doesn't necessarily need to be a wire. It could be a plate.
    RazanurRazanur
    Reply 2 years ago
    Can you maybe show us a video of your method?
    How Do You - DIYjohneby
    Reply 2 years ago
    I'm glad you mentioned this, it's actually something I've been thinking about trying. I just haven't done the research yet to build it. I was thinking about having a tight wire, kind of like the Styrofoam cutters use, but having a sagging wire seems safer. I appreciate the input!
    RazanurHow Do You - DIY
    Reply 2 years ago
    I was also thinking of a rig as I use it for Styrofoam cutting (usually connect it to an old car battery :D)
    callhow
    2 years ago
    Maybe you could make a "jig/rig" to hold the soldering iron tip - against the scoring line, and simply rotate bottle - while adjusting "in" soldering iron tip ?
    mabrady834
    2 years ago
    Can you cut the side out of a bottle instead of just the top or bottom? I have seen bottles that lay on their sides with slices cut off of them and flowers planted in them. Wonder if this method would work?
    How Do You - DIYmabrady834
    Reply 2 years ago
    I've seen some bottles cut like that too, I think the ones I saw were cut with a diamond saw. I haven't tried a side cut yet, but I am planning an instructable for unusual cuts. I'll experiment and see if I can get a side cut to work. But based on my past experiments, I think it will! :-)
    AOTN2000
    2 years ago
    Good info, I will try it, and cool jig too. Thanks.
    billdeserthills
    2 years ago
    My science teacher Mr Heard used to tie a cotton string where he wanted the cut and soaked the string in lighter fluid and light it on fire. The heat would score the bottle and a few taps would separate the two pieces. He would use sandpaper on any rough spots
    dave_in_delaware
    2 years ago
    I can recall a "home science project" book I checked out from the library maybe 20 years ago that had a glass cutting project. You scored the bottle with a glass cutter, then used the "nichrome" wire from a toaster (plugged in to heat the wire) to cut it. I never tried it, but I'd imagine it would be pretty fast. I've never thought of this method (soldering iron). You must have tons of patience to do it this way.
    saxondale
    2 years ago
    Looks interesting, thanks for sharing. I remember seeing this done on a TV documentary by a guy making a living from it in Brazil. He was turning large jars he recovered from land fill into salad bowls and he used an old record turntable to turn the jars with a small flame mounted at the side to heat the glass, which he then dunked in a bowl of cold water.
    Yonatan24
    2 years ago
    How about a soldering gun? Could be better...
