Brazilian BBQ Churrasco Beef
3,556
38
5
About: Science fiction and fantasy author. Once-archaeologist. Foodie. Mom. Occasional woodworker and beginning gardener.
Rio Grande do Sul is the birthplace of the churrasco, a barbecue tradition centered on beef at its best. There are plenty of churrascarias around where I live in the US, but doing it yourself and taking your churrasco outside is immensely gratifying. You only need a few simple things:
Beef (I'll talk about picking out beef next)
Food-grade ice cream salt or extra-coarse salt
A really big skewer
Hardwood natural lump charcoal
A BBQ, firepit, or other safe, legal place to burn said charcoal.
A meat thermometer (optional, but so helpful!)
Supplies:
Step 1: Select the Beef
Thankfully, you don't need an expensive cut of meat for delicious churrasco. Look for some marbling of fat throughout the meat, and a nice layer of fat on one side. I also like to find cylindrical-shaped cuts, as these cook a bit quicker and more evenly than rounder cuts. You want about a half pound to a pound of meat per person.
Step 2: Salt the Beef
Ice cream salt is generally used for cooling down ice, allowing for old-fashioned ice cream making. I just learned that not all of it is actually labeled for consumption, though it's considered safe for food contact (such as chilling down a watermelon in salted water). Read all the fine print and seek out food-grade ice cream salt, or baring that, use the very coarse salt intended to refill salt grinder. Liberally press this all over the meat. These chunks will partially melt and do their magic when the meat cooks. It's essential! Use the chunkiest salt you can find!
Step 3: Beef Meets Skewer
You need a hefty skewer to hold up a huge chunk of beef -- something akin to a small sword (except without the sharp edges). My method for obtaining awesome skewers was marrying someone who had lived in Rio Grande del Sul. I've never seen skewers this big in any store in the United States, and I don't know how available they are elsewhere in the world outside of Brazil. There are internet suppliers of churrasco skewers, or you might be able to re-purpose a rotisserie skewer or other grilling equipment to this end.
Step 4: Cooking the Beef
Get some hardwood lump charcoal going. Avoid propane. Avoid chemically-bound briquettes. Really, the only flavors here are beef, salt, and smoke, so you want the smoke to be tasty, too.
The thickness of your beef will determine how far away it needs to be from the coals. You don't want the outside to be burnt while the inside is still raw. Here, you can see the park BBQ just wasn't deep enough, so we improvised and used horizontal distance to keep the beef cooking slowly enough. In the past, in fire rings, we've also used bricks and rocks to prop up skewers a little higher. If the outside is turning golden in the first ten minutes, get the beef further away.
Once you're set up, feel free to fiddle, turning the meat over regularly so it all cooks evenly. We cooked this two pound roast about eight inches away from the coals, for about forty-five minutes until medium-rare.
You can try just prodding at the meat to feel for doneness, but I like to bring a probe thermometer and check two or three of the thickest places around the roast. I've found it's much more accurate, especially when I'm hungry. You can cut into the beef to check it, but this lets juices run out and toughens the meat.
Rare is 125F, medium rare is 130F, and medium is 140F, and medium well is 150F. If you have a group with varying preferences, the ends are going to be somewhat more well-done than the center.
Step 5: Rest and Eat
Here it is -- all delicious and ready to go. If you are patient, you can wrap this in aluminum foil, cover with a towel, and allow the meat to rest for ten minutes. If you are not, slice and eat!
Another traditional part of a churrasco is whole grilled pineapple -- pineapple supposedly helps you digest all that meaty goodness. I hope to have an instructable up on that process soon.
Meat Contest 2016
Runner Up in the
Meat Contest 2016
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    5 Discussions
    BorisT12
    2 years ago
    I'm from Brazil's south region (very close to Rio Grande do sul) and I can ensure that your instructable is accurate (and I bet it is also DELICIOUS).
    The essence of brazilian churrasco is its simplicity + select the correct meat, and you have captured it perfectly.
    Brazil is a huge country, like the US, so it's normal to have diverging opinions regarding "the correct way to make a churrasco", but in the end of the day, the principles are the same.
    Thank you very much for sharing your recipe!
    vsolymossy
    2 years ago
    Sorry, but your instructable is not very accurate.
    First, it is not "Rio Grande del Sul". We speak Portuguese instead of Spanish. The correct is "Rio Grande do Sul".
    Second, this is a tradition in Argentina and Uruguay as well. Even in Brazil, barbecue is quite traditional in many other states. It is not a easy topic, because everyone claims to be the original (and best) one.
    Not all barbecue is made with big chunks of beef (ok, the best ones are). You may chop it in small chunks, like one inch cubes or slices (just Google "churrasquinho" and go for images). In this last option, you will not need any skewer.
    About the beef itself, I personally would not go for this roast beef kind of cut... It becomes quite not easy to chew. But you're completely right when you say that you need a nice (and not expensive) cut.
    About the salt you're right, but many people like to season the meat as well.
    You forgot to mention the sausages, chicken, pork... And vegetables as well! Brazilian bbq is not only about beef.
    Best regards from a brazilian person.
    mkhutchinsvsolymossy
    Reply 2 years ago
    Thanks for catching my spelling -- my resident Portuguese proofreader missed it. Fixed!
    I know there are many similar traditions, but Southern Brazil claims itself as the origin of churrasco, and Wikipedia, at least, agrees with them (see the first sentence under "Latin America": https://en.wikipedia.org/wiki/Churrasco). Ricardo Penna, author of Alquimia do Churrasco, traces churrasco back to the destruction of Jesuit missions in Rio Grande do Sul in 1768.
    Everyone my husband knew there frowned on additional seasonings on beef, and cutting up the meat was seen as less traditional -- an invention of Sao Paulo.
    I realize this is just one recipe. I've had lots of people ask me over the past decade "how'd you make this!" and thought I ought to lay out the simple beef + salt + fire recipe for success. Googling "churrasco" -- at least in English -- always seems to bring up fancier, less traditional approaches.
