Brushless DC Motor
14,543
115
11
About: We are a supplier of neodymium, rare earth magnets. We also love to conduct experiments with our magnets and build unique projects with them! We have several engineers on staff who are always thinking of new...
Let's make an electric motor that spins using neodymium magnets and wire. This shows how an electric current is converted into motion.
We’re building a primitive brushless DC motor. It’s not going to win any efficiency or design awards, but we like to think a simple example makes it easier to see what's going on.
Materials needed:
-(2) neodymium magnets
-Rotor (we used a 608ZZ bearing)
-Magnet wire
-Steel bolt
-Breadboard
-Electronics - Reed switch, transistor, flyback diode, 20ohm resistor, LED, 6V DC power supply. We used 4AA batteries in a battery pack
Step 1: DIY Rotor
The spinning part of an electric motor is called the rotor. Most brushless motors have permanent magnets on the rotor.
Our rotor spins thanks to a 608ZZ bearing stuck on a pencil. This bearing is commonly used in things like skateboard wheels and fidget spinners.
We stuck two 1/4" x 1/4" x 1/8" B442 neodymium magnets on the outer edge of the bearing, 180 degrees apart from one another. Both are oriented with their north poles facing out. This is different than most BLDC motors which have alternating poles facing out. This simplification made our electronic circuitry a bit easier.
Step 2: Get Moving!
How do we get this thing spinning? We could just flick it with our finger, but we're looking for a magnetic push. Bring another magnet near one of the rotor magnets, with it's north pole facing the north pole of the rotor magnet. This will cause the magnets to repel, or push, setting the rotor spinning.
If we push on the magnet hard enough to spin the rotor halfway around, we can do it again to the next magnet. If we were fast enough, we could keep putting the magnet close and taking it away, spinning the rotor continuously.
This is where the electronics come in. We need to create an electromagnet that turns off an on, pushing the rotor magnets.
Step 3: Electromagnet
A simple electromagnet consists of a coil of magnet wire wrapped around a steel core. We used 24 gauge, single strand copper magnet wire with a thin, enamel insulation. A bolt became the steel core.
When we apply a voltage to it, it becomes a magnet. With the electromagnet positioned just right, it should push the rotor's magnet away. Now all we have to do is turn it on and off at just the right moment.
We want to turn the electromagnet on just after one of the rotor magnet passes the bolt, to push it away. After a little bit of travel, say 30 degrees or so, it should turn back off. How can we do this switching electronically?
Step 4: Magnetic Sensor
We chose a reed switch to tell us when the magnets are in the right position. A reed switch is a glass-encased sensor, where two ferromagnetic leads are almost touching one another. Apply a magnetic field to the sensor with just the right magnetic strength and direction, and it causes these two leads to touch one another, making electrical contact and completing the circuit.
With the reed switch positioned as shown, it makes contact only during the correct portion of the rotor's rotation.
Step 5: Final Circuit - Improved
While the simple reed switch setup worked briefly, we quickly ran into problems. We were running a lot of current through that reed switch and it welded the two contacts together. This is because we were essentially shorting out the batteries.
To fix this problem, we added a transistor. Instead of having all of the electromagnet's current go through the reed switch, we used the reed switch to trip the transistor on and off, so the current goes through the transistor instead. A transistor is basically an on-off switch that can handle a bit more current.
The final setup also includes a diode to prevent backflow from the electromagnet. This is called a "Flyback Diode", which prevents the current from frying the transistor when it turns off.
Step 6: Watch It Run!
With the electromagnet switching on only through a small portion of the rotation, the rotor spins continuously! Check it out in the video.
We added an LED that lights up when the electromagnet is activated to help visualize what’s going on.
In the chart, you can see the measured voltage across the coil, turning on and off!
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    11 Discussions
    AndrewS549
    6 months ago
    This explanation is refreshingly simple and has just the right amount of technical jargon talking about "frying the transistor" ^^, lol I really appreciate how much effort you've put into simplifying the theory behind these complex concepts!! Thanks a lot!!
    P.S - regarding the disclaimer in the beginning, say for interest's sake that you were considering improving the efficiency, etc. Other than bigger batteries, what upgrades could improve this setup?
    KJMagneticsAndrewS549
    Reply 6 months ago
    Thanks! A more frictionless bearing always helps and maybe a better electromagnet are the things that come to mind!
    DreamDabblerKJMagnetics
    Reply 6 months ago
    How about using another coil on the other side, and maybe that thing you mentioned about having the second magnet with the opposite pole outward? I'm thinking having three or more magnets might also help -- but each of these things probably adds a lot to the complexity. At some point you'd have to use something other than reed switches, too.
    icengDreamDabbler
    Reply 5 months ago
    And so begins a real motor design with a stator and multiple phases that may one day outperform a Tesla car motor :-))
    enekosagre
    Question 5 months ago on Step 5
    Hello!!! Nice instructable!
    I have a question which kind of transistor did you use?
    KhamlekH
    6 months ago
    Nice and clears explanation
    DreamDabbler
    6 months ago
    Ah, yes, thanks for the nostalgic moment as I fondly recalled working on a regular old brush motor kit decades ago when I was young. Now THAT was simple. Clear to see, though, the advantages a brushless design can have in terms of efficiency, lower maintenance and longer service life. Hmm, reversibility too?
    RaymondR6
    Tip 6 months ago on Step 6
    Well done! I will suggest using an optical interruptor instead of the reed switch. You can use a commercially made optical sensor, or make one with a photodiode and attaching a paper disk with two cutouts to let light pass through and trip the photodiode. A Hall switch can replace the reed switch, too.
    KJMagneticsRaymondR6
    Reply 6 months ago
    A hall sensor are typically used, but we used a reed swtich to keep things simple...then we had to add circuitry to protect the reed switch anyhow!
    JohnC430RaymondR6
    Reply 6 months ago
    there are many ways to skin a cat. this was his method.
    Gadisha
    6 months ago
    Interesting
