Brushless Gimbal Balancing Robot
37,040
311
88
About: Hi! You can call me Matt. I'm a problem solver with interests in many fields. I will try to post some of my more interesting projects when I have the time.
The following project is a result of viewing the Cubli video and becoming interested in the control of unstable equilibrium using brushless motors. The simpler inverted pendulum problem was decided on in order to complete the project before loosing interest. Many people provide better descriptions than I can, therefore I will only focus on the build and try to offer useful links when needed.
Step 1: Parts
As the project title hints, the robot uses parts from a brushless gimbal camera stabilizer. This is ideal as the motor controllers and microcontroller are on the same circuit board and already setup to work with the included brushless motors and inertial measurement unit (IMU). The chosen gimbal system is designed to work with GoPro sized cameras with several iterations found cheaply online.
    • Gimbal control board BGC 2.0, look closely at the provided picture (2X L6234 brushless motor control ICs, mega328p microcontroller, Silabs CP2102 USB to serial)
    Note: other boards may work, it will need to be programmable using the Arduino IDE, therefore must contain a compatible microcontroller and ISP header to burn the bootloader
    • gy-521 IMU (MPU-6050 3-axis gyroscope and 3-axis accelerometer)
    • 2X 2208 brushless gimbal motors (fasteners to mount motor, they were included with my gimbal)
    • LiPo battery 3S (Turnigy nano-tech 460mAh 25-40C 57X31X17mm)
    • Colson Performa wheels 2" X 7/8"
    • 5/8" aluminum plate or bar to CNC robot body from, body made of two halves with finished size 2.50X4.89X0.55" (1/2" plate or bar also works, body will be 0.1" thinner)
    • 2X 6-32 X 1" button head screws
    • 1/8" X 3/4" dowel pin
    • 6" X 1/2" double sided Velcro strap to hold battery in
    • Other assembly stuff: double sided foam tape, hot glue, hook-up wire, 0.8mm piano wire to lengthen Bluetooth antenna, sticky rubber bumpers, battery plugs, indicator LEDs and stuff I have not thought of
    Step 2: SolidWorks Model
    The SolidWorks models are provided for machining and reference and .STL files of the body and wheel for 3D printing. Make sure your electronics, battery, motors and other parts work with the design before starting. Some modification might be needed.
    Step 3: Machining
    The inside diameter of the wheels need to be opened up on a lathe to allow for the motors to be pressed into the wheels. Measure the outer diameter of the motors and turn the inner diameter of the wheels about 0.001-0.002" smaller for a press fit. The depth should match the dimension of the outrunner motor bell. The wheel core is made of a hard plastic and holds decent tolerance. I held the wheels by the rubber exterior, in a six jaw chuck and indicated in off the plastic face.
    Remove the motor bell/shaft assemblies by pulling the snap ring off the shaft on the back side of the motor and drawing the assembly out of the bearings. Press the bells into the wheels by putting pressure on the edge of the bell (not the shaft).
    The body consists of two identical halves except for the alignment pin holes and the fasteners (see provided drawing). The two halves are CNC milled from 5/8" (1/2" also works but robot will be 0.1" thinner) aluminum plate. The SolidWorks part is provided to use with your CAM software of choice. I marked the motor mounting holes, alignment pin hole and fastener holes on the CNC using a center drill before the parts were separated from the plate. The parts should now be deburred and cleaned. I then complete the drilling, tapping and countersinking (this can also be accomplished on the mill before the parts are removed from the plate).
    Step 4: Assembly
    Look at the provided picture for part orientation.
    • Press the dowel pin into place
    • Attach the control board using double sided foam tape on the webs of the aluminum body
    • Attach the brushless motors to the body with the wires on top
    • Hot glue the IMU into place making sure it sits flush on the aluminum tabs and the IC is located inline with the motor shafts
    • Create a full wave antenna (~12.5cm) out of the piano wire for the Bluetooth module and attach so it goes outside the body (I drilled a small hole through the module allowing the antenna to go out the backside and provide more support)
    • Attach the Bluetooth module using double sided foam tape
    • Reset the default values on the HC-05 using AT commands and these instructions. My Bluetooth module had a pushbutton instead of a "KEY" pin, that needed to be held during power up and programming. The device name and password are reset and the baud rate is set to 230400.
    • Connect the Bluetooth TX to RX, Bluetooth RX through a voltage divider to TX to reduce the voltage to 3.3v and supply the needed power
    • Attach a battery connector (I added a 2amp fuse inline to offer a little more protection)
    • Hookup the IMU and motors to the control board (they came with attached connectors)
    • Attach an indicator LED to pin A1 using a 1k ohm resistor (I attached two and pointed them out the bottom of the robot)
    • Other optional stuff: Velcro straps on the top to hold the battery in, hot glue the wires for strain relief, rubber bumpers to protect the floor
    • Both halves should now fit together and be held in place using the two #6-32 fasteners
    Step 5: Arduino Code
    -The code is running on a mega328p and was compiled using Arduino 1.6.6
    -The code cycle time is a constant ~250Hz
    At the heart of the code is a counter that is advanced every time TIMER1 overflows and triggers an interrupt routine. This counter triggers other events at specific intervals allowing the code to run at a known rate and simplify math in the control loop.
    The tilt angle of the robot is calculated using a complementary filter with gyrometer and acceleration values from the MPU6050 IC. This is fed into a control loop with three other values: the time derivative of the tilt angle, robot velocity (acceleration integral) and robot displacement (velocity integral). All four values are added with preset gain to get an output term proportional to robot acceleration. A good explanation of this control loop by David P. Anderson and more information on his balancing robot.
    To move the robot an offset is added to the displacement value in the control loop. To turn left or right an offset is added/subtracted from the left and right wheel velocities. The wheel velocities are fed into the the motor control portion of the code.
    Brushless motors require 3-phase power. Look at this explanation of how angle control of brushless gimbal motors is achieved. The motor control portion of my code is based off of the BruGi brushless gimbal control code. All three timers are set to output 31.25KHZ phase correct PWM (6 PWM outs). A useful article on adjusting Arduino timers.
    A lookup table containing space vector PWM values is used to pull three values with 120 degree phase separation. The values pulled from the lookup table are advanced at a rate proportional to the needed left or right robot wheel velocity.
    The code handles motor power adjustment to correct for torque falloff at higher speeds and greater needed torque during higher acceleration. The battery voltage is monitored to prevent damage to the LiPo batteries. The code also handles Bluetooth communication between a smartphone.
    Step 6: Tuning Control Loop for Balance
    The control loop has four gain values that need to be set.
    1. kp angle gain
    2. kd angle velocity gain
    3. kv velocity gain
    4. kc position gain
    This is how I tuned the robot for balance, it is probably not ideal but it worked. Start with all gain values set to zero. Slowly increase kp gain until the robot no longer falls forward, now increase kd gain until the robot stands but slowly oscillates with growing amplitude until the robot falls over. Increase the kv value until the robot no longer oscillates and recovers from a light push on the top. At this point the robot should have the desired performance. It should stand in one place and recover from a disturbance. Play with the three values to get a better feel for how they behave. Now increase kc gain until the robot returns to the same place after a disturbance but not too large resulting in decreased performance.
    I reset all values to zero and started over several times until I achieved decent results. If it looks like the loop is completely failing make sure all the calculated values in the loop have the correct sign and behavior and the feedback values have the correct sign.
    Step 7: Bluetooth Control
    The android app Joystick BT Commander is used to communicate with the Bluetooth device on the robot. The app is setup to display the robot battery voltage, relative motor output power and the code cycle time. The cycle time is important because it must not exceed the time interval between calls (~4ms) in order to maintain proper timing for derivative and integral calculations. The app also has two buttons setup. A power button "ON" turns on the motor control portion of the code when activated. The second button "Fast" increases the robots top speed by a factor of two when pressed.
    Step 8: Finished
    When the robot is first powered it needs to be set on its front or back within 5 seconds. At this point the indicator LED will flicker for 10 seconds as 1024 gyroscope readings are averaged to obtain a calibration value. If the battery is charged the indicator led should now start to turn on and off every 2 seconds. A connection can now be made between the smartphone Bluetooth application and the robot. Press the "ON" button and place the robot within 1 degree of vertical to start balancing. Use the joystick to drive the robot. Once the battery is depleted the robot will no longer balance and the indicator LED will stay on.
    Robotics Contest
    Second Prize in the
    Robotics Contest
    4 People Made This Project!
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    88 Discussions
    esmk2
    Question 5 months ago on Step 3
    i uploaded code my bgc v3.0 board . but not turn on . you can send me a wire-ring diagram A1 AND A2 PIN go to where ? please help ... thanks
    1 answer
    271828-esmk2
    Answer 5 months ago
    A1 has an LED attached using a 1K resistor for indicating code progress. A2 is used to measure the battery voltage. Use a voltage divider to reduce the battery voltage below 5V when fully charged. The resistors chosen will depend on your battery voltage. Lines 42 and 43 in the code will then need to be adjusted to set the low voltage cutoff and restart.
    chris543_lin
    hi~ If I want to use DC motor that can generate PID output range -7000~+7000. How to ajust motor power base on yourPID calculation
    code?thank you.
    1 answer
    271828-chris543_lin
    Answer 5 months ago
    Hello, The variables R_Speed and L_Speed could be scaled to the needed output range after the PID calculations and movement controls. A lot of the code is for controlling the brushless motors; I would recommend looking at the link http://www.geology.smu.edu/dpa-www/robo/nbot/bal2.txt to get a better idea of the PID structure and possible writing your own code.
    dcolemans
    8 months ago on Introduction
    Very nice project and very cool design. I learned a lot following in your footsteps, in particular use of the timer interrupt to get more precise timing. It's amazing what you made the little gimbal controller do! I have a link to a video of mine in the I Made It section.
    chhristophher
    Question 11 months ago
    I also had problems with the joystick, I decided to change the speed of the serial to 57600 in the sketch and bluetootch and worked perfectly.
    JanuszS7
    1 year ago
    Hi. I just figured out that i have missing voltage divider on A2 pin - after fixing this Android app is showing right voltage and robot started to balance...
    However, is not moving exactly like described by f4gmu - anyone found the reason?
    f4gmu
    Question 1 year ago
    Very nice projet !
    I build it and it .... works :
    I'm using android joystick app v5.2 and the ON/OFF button works but not the joystick. So my bot don't move.
    Is there a way to fixe that ?
    1 answer
    271828-f4gmu
    Answer 1 year ago
    Thank you for posting your build! I'm not sure why the joystick would not work while other parts of the app work. The current version on my phone is v5.5, possibly something changed between versions. As a side note, I have the refresh interval on the app set to 25 ms. You could add a serial print to the code and see if the joystick values are making it to the robot?
    271828-docman100
    Reply 1 year ago
    I'm not sure what module you have without further details.
    271828-docman100
    Reply 1 year ago
    The setup instructions for both kinds of modules are covered here https://www.instructables.com/id/AT-command-mode-of-HC-05-Bluetooth-module/ Hookup in the robot should be the same. Apply the needed power lines, connect the Tx on the Bluetooth module to Rx and Rx on the bluetooth through a voltage divider reducing to 3.3 the Tx on the microcontroller.
    docman100
    1 year ago
    ok I have someone in my class and he said he knows where the pins go, but I still don't have a + or - pin
    docman100
    1 year ago
    the board uses a micro b is that compatable for the programing?
    271828-docman100
    Reply 1 year ago
    It should work for programming if there is already an Arduino bootloader installed, if not you will need to flash a bootloader to the chip.
    docman100
    1 year ago
    currently building...
    docman100
    1 year ago
    you should enter this into the make it move contest
    271828-docman100
    Reply 1 year ago
    Thank you for the suggestion, but I believe one can only enter contests if publishing while the contest is open. Hopefully your parts arrive soon!
    docman100
    1 year ago
    the parts have taken longer than I expected...-
