Bubble Machine
157,581
634
59
Making your own bubble machine is a really easy and fun project. It can be made from almost anything, glued and screwed together with an end result which will keep kids (and adults!) amused for hours.
With basic electronics of just a fan and a motor, a bubble machine is also a really easy first electronics project. This one I threw together with spare minutes here and there across the period of a week. The longest part was waiting for the centrifugal fan to arrive from Amazon, the best part was making a lot of mess in the Instructables office before realising that the shower would be a better place to blow bubbles while testing.
My bubble machine was made to keep my friends' toddler amused. She loves bubbles but is at an age where blowing them herself is rather hit or miss (not to mention messy). She spent a VERY happy 15 minutes running through and around them in the street outside, afterwhich the adults stepped in to play with heating the bubbles to see if they'd go higher, or experimenting with different bubble mixes to see if any where noticably better.
Earn 3 months pro membership: Anyone who makes their own bubble machine and posts a photo in the comments will get a code for 3 months of pro membership from me.
Step 1: Tools & Materials
These are the tools and materials that I used for my bubble machine. Yours will differ greatly depending on what you have available. This is a great project to do with scraps, and odds and ends all hacked together. It doesn't have to look amazing to be a lot of fun, it just has to work.
To make it easier for others to reproduce this, I've done away with my normal format of exactly what to use and instead broken it down into the five main components the machine's made from. The 5 steps after this talk about what alternatives you could use and what each has to do to make a great bubble machine. I then give details on how to assemble it if you did it exactly like mine.
Trough: To hold the bubble solution. It needs to be waterproof and not too shallow, that's it.
Bubble Ring: A ring of holes that will spin slowly through the trough picking up the bubble solution. As it lifts out of the trough the holes pass before a blower to form the bubbles.
Motion: A slowly moving motor to spin the bubble ring. A continuous servo is perfect for this.
Blower: Something with a bit of puff. Will force the bubble liquid out of the holes in the ring, forming BUBBLES! I used this 12V centrifugal server fan from Amazon.
Power: A power source or two for the blower and spinner.
You'll also need nuts, bolts, hot glue or superglue to hold everything together.
The files I used for laser cutting are included in this step.
Step 2: Trough
This component could be a cut down milk carton, a tupperware food storage box, some plastic food packaging or an over-engineered, laser cut,  orange acrylic, finger jointed trough. I went this road as I enjoy using CAD and the laser cutter, tools a lot of people don't have.
All that matters is that it'll hold the liquid and you can mount your motor of choice onto it.
Mine was drawn in Alibre Design then the tabs were adding using a beta version of 123d plate which will hopefully soon be available as part of 123d. I then laser cut it in 1/8" acrylic and used super glue to hold it together. To waterproof the joints I ran a line of clear packing tape down the outside. I also included in the design some slots raised above the trough on which to mount my servo. Hot glue would have worked equally well!
Step 3: Bubble Ring
Next you'll need something that will rotate through the trough to pick up the bubble liquid. Taking the wands out of a bumper pack of bubbles would be a great idea, then glueing them in a circle and mounting the motor at the middle. Of course.... I didn't do that, it had to be laser cut to make use of a tool I had but didn't need.
Mine's cut from 1\8" acrylic with 16 holes around a 6" perimeter. Each hole has slots cut into it so that it'll hold more liquid. There are holes cut in the middle to mount it to a standard servo arm with self tapping screws.
Step 4: Motion
Next, spinning your bubble ring in the trough. You'll need a motor that you can screw or glue your bubble ring to.
I went for a modified servo, it has a nice slow rotation and requires just two AA batteries. This tutorial by robomaniac  shows you how to modify a servo to not require the control signal. You could also use any geared motor from an electronics store or even a standard K'nex or Lego one.
Step 5: Blower
I chose to use a $5 centrifugal fan from Amazon. It runs on 12V and has an air flow similar to a standard PC fan but over a much smaller area. Running at 9V it wasn't strong enough, but on 12V it was perfect.
You could also use a hair dryer, heat gun on its cold setting, a small desk fan with a cone on it. I don't recommend reversing a vacuum cleaner, it made a lot of mess in the Instructables office!
Step 6: Power
The power you'll need for your bubble machine will depend on the motor and blower you choose. I used 2 AA batteries for the servo motor and a 12V drill battery for the blower.
What motors you choose to run will determine what battery or adaptor you need.
Step 7: Assembly
And here's how mine went together:
Photo 1: The servo is bolted to the trough with two M4 machine screws and nuts. The AA battery holder is hot glued to the trough and wires to the servo are soldered and insulated.
Photo 2: The bubble ring is screwed on to the servo with 4 self tapping screws. Note how close to the bottom of the trough the ring must go so that it picks up every last bit of bubble liquid.
Photo 3: A rear view of the ring on the servo.
Photo 4: A centrifugal fan is glued onto the back, pointing at the holes in the ring. Test where it has to point before glueing it, see where you get the best bubbles. I found that with it pointing there the bubbles shot up as well as out. For testing I used a bench top power supply, outside I switched to a 12V cordless drill battery.
Step 8: Operation
So as you can see, I had a lot of fun building and playing with my bubble machine. It started out as a project to amuse a toddler and ended up also amusing a lot of business men/women in downtown San Francisco as we blew bubbles off the Instructables fire escape.
A 12V cordless drill battery made a great portable power supply for the bubble machine, they're easily available and easily rechargable and much more convenient than trailing wires from a benchtop supply.
The bubble solution I used was 1/2 dish washing liquid and 1/2 water as I soon ran out of the original bottle of miracle bubbles. This 50:50 mix worked really well, though some people also recommend a spoon full of glycerine thrown in too.
Once whatever kid that the machine was intended for has grown bored and moved over, the adults get to play! It turns out that pre-heating the air with a hair drier or blasting it high speed with a reversed shop vac is a lot of fun, though I'll leave you to find out why.
4 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Pocket Sized Contest
  • Arduino Contest 2019
59 Discussions
E_Alves
7 weeks ago
Great project . Could provide a pdf file with bubble ring in real size ? The files you provide are for machines i dont have . Also trying to export as pdf is not working.
Thanks
CreativeBlossom
2 years ago
This is AWESOME!!!!!!!!!!!!!! ;D ;D ;D
SWJTUyuhui
2 years ago
So interesting,I love it.Thank you for sharing.
I'm making one but I don't have a laser cutter. I'm cutting the circles out of about 1mm thick sheet of plastic. The problem is I'm using a cutter and even the most careful cutting sometimes leaves miniscule sharp points. This doesnt let the bubble form.
Anyone got any ideas how to cut out perfect circles sans a laser cutter?
I made a bubble machine and purchased the 'old fashioned' bubble wands (the 'stick' with the round ring at the end - the kind that came one to a small bottle of bubble solution) and added them to my wheel.
If you were to use acrylic sheet or Plexiglas, a spade drill bit does a surprisingly good job of making holes. Sand the edges a bit, and you're good to go.
This comment is 2 years late, but it got my gears spinning... I tried the build then but failed because the material was too flimsy and circles imperfect. Maybe I'll give it another go...
I did. They came out oddly shaped and slightly better at making bubbles but still not good enough.
Laser cutting is much more accessible and cheaper now than when I posted this comment. That is probably the best way to go about making this.
anteinoAntzy Carmasaic
Reply 3 years ago
You're probably right. I know that is true for 3d printing. If you'd like to print some parts you should check out 3dhubs.com something similar for laser cutting might also exist. It would at least be way cheaper than having it made by a professional company.
cameraeyes
4 years ago on Introduction
I love the design. As simple as can be.
One question: do you have a problem, or foresee the problem with all-day use, with bubble solution dripping onto the servo or the shaft, and gumming everything up? Or causing a short? Offsetting the disc from the servo with a spacer might fix this, but have you seen the need?
Bowtie41
4 years ago on Step 8
I'm wondering what effect making a nozzle from the fan outlet tapering to a round shape the same diameter as the holes and fitting close to the disc would make?I'm guessing it would be way more efficient.
CurtR
Why not attach a fan/pinwheel blade to the soap wheel between the fan and soap wheel. That way you won't need a servo motor to turn the soap wheel.
chipnut
Why not just spin it with the drill on very low speed? Spinning it by hand is just as effective. Mount the wheel on an axle attached to the basin. A Dremel or drill with a rubber tip can spin the wheel. or buy a servo with a wheel and drill the holes. https://www.servocity.com/html/precision_disk_wheels.html
JayefuuLukaszkos
Reply 5 years ago on Introduction
Brilliant! I wonder if you used a hair drier instead the heat would make the bubbles rise better rather than dropping to the floor.
FlipFlop
5 years ago
I cannot download the .dxf file provided by you? Can you please check and see what's wrong? Or can you upload it again maybe in a zip file?
Thank you very much
