Build Own Secured PHP IOT Website Free - Arduino
27,025
135
30
About: Want to do some thing best with my less resource.
I feel its costly to purchase IOT from websites. So i plan to build our own IOT web page. When come to IOT the security is more essential, So i use MD5 encryption from PHP to secure the page. With the page i design we able to control lot of devices with seperate user name and password for each device. And access the data with the user name of the device.
Supplies:
Step 1: Materials Required
For Programming
1) PC with web connection.
For Testing
1) Link IT one board (Or Arduino UNO with WIFI or GSM Module"
2) ESP8266 WIFI module
3) Wifi hot spot of smart phone with internet connection and WIFI hotspot.
4) Power Supply
5) Relay module
6) Potentiometers
Step 2: Find a Suitable Web Site
Use google and Found a free Website hosting web site. Even with limited size is enough for testing. If we want to expand the project then purchase a space from them. I found 000webhost.Com is a nice web site with free database support. Database is very essential when develop a iot webpage.
The program we going to use is PHP with Mysql.
Step 3: Free Signup and Verification
1) Sign up using your email id.
2) After verify email id in your web page.
3) Use mobile send the unique code listed in the page to the given mobile number.
4) Then your mobile number also verify.
Step 4: Create a Website
1) When login the website.
2) Click the + sign on the web site and enter the website name and password of the website, then click create.
3) Your web site created sucessfully.
4) Use Build web site using three options given. I use upload own website. Because i develop a php web site. I give it in up coming pages.
Step 5: Create a Domain
1) Now its time to create your domain name.
2) In the menu click my domains.
3) Then Click add domain in the screen.
4) In the domains page click Add domain.
5) In the Window click free subdomain.
6) Enter sub domain name and click save.
Step 6: Create a Database
1) Create your PHP data base.
2) In the databases click new database.
3) Enter the database name, username and password.
4) Click create.
5) Your database created.
Step 7: Manage Database
1) Create the tables in the database.
2) Create your tables in the php as per your requirement.
3) I given my DB here.
4) Download the local host.sql in the list.
5) Use import in the page to import the tables from file given.
Step 8: Create Iot Pages
1) I given my php files as rar here.
2) Down load the file and change your dbusername, password, db name in config .php file and upload.
Step 9: Upload to Website
1) Down load the pages i given and upload the pages in the upload own web site.
Step 10: Arduino Program
1) Upload the given program in linkit one (or change it for Arduino).
2) Run the kit and found the sensor value posted on in your database.
3) By use the Sensorvalue.php with your domain name u able to see sensor value any where in the world.
4) By use the Switches.php with your domain name u able change the switch status in the kit.
Syntax for each page:
1) To see sensor value
your web domain name/Sensorvalue.php?id=User name in table&pwd=Encrypted password using MD5
2) To change switch status
your web domain name/Switchesphp?id=User name in table&pwd=Encrypted password using MD5&switch=integer in decimal to control up to 10 digital pins.
In the arduino program u want to change the addresses and wifi settings. Also add program to convert received decimal to binary value and change the digital pin status according to the decimal value.
I php I add only basic pages use the coding add plugins like graph for php from net develop pages to view the details in graph. And use image map send the switch status from php page to database to switch on and off the devices.
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    30 Discussions
    רזד
    4 weeks ago
    Hi there; well done for the write up here.Thanks a lot for your files you shared with us.
    I think there is more little details that missing like how you put it all together in one page and how you can check that the DB is connected and get the info that stored without getting the Arduino on.
    Or I'm doing it wrong?
    sorry for my english.
    Please check there are separate files for configuration to db connection and user lock. All are in php attached in single rar file, unzip it. Even Arduino is not on data is recovered because are the data are stored in the server.
    hemu.katiyar
    2 months ago
    i am getting this error while uploading your database localhost.sql
    1. Missing expression. (near "ON" at position 25)
    May the version varies. But if you know my sql its very easy. Open the localhost.Sql in a notepad and copy all the text to the MS word. You find the script in format. It contain Create Database, Create table, Insert commands. Copy that one by one and run in mysql Query.
    dhanrajs3
    1 year ago
    Hi ...
    First of all thank you for such a detailed explanation. As a beginner to website building domain i found this much helpful. As i am going through building website exactly like the one you shown in php_files.rar i couldn't find index and web config. Is it missing by mistake or is it system generated. Please reply.
    utg_2_2
    Question 1 year ago
    Hello,
    I am using the GET query that is mentioned in the tutorial. My query is GET /Sensorvalue.php?id=sivam&pwd=1955b38f13116a57e4de2134a139d139&s1=10&s2=20&s3=30 HTTP/1.1 HOST:https://dl101try.webhostapps.com
    No change in database upon executing this code
    Please help.
    1 answer
    hsedidin
    1 year ago
    I am using the arduino uno and am getting a file not found error for
    <LTask.h>
    Where do ii find that class?
    online07
    1 year ago
    Its great information....... I want to make home automation using raspberry-pi/ arduino,i also want to develop my own andriod app/website (No third party) which would dynamically control light (i.e.on or off) etc.....waiting for ur kind reply...Thanks
    I want to design IOT based home automation. In this project i want to design my own website (using open source software) and android app (using open source software).This project can control all the appliances of the home (on/off).
    1. How to design website which can dynamically change. (i.e. it can display data from sensor and it can on/off devices in home )
    2. I want to use Raspberry pi.
    syariff
    1 year ago
    invalid library..where do you get the library(LTask,LWifi,LWifiClient).. can you give the link
